Originally Posted by
14S4GWM
On the s4? If so you've put that thing through the ringer!
This particular incident put my right hand through the ringer, but the car was no worse for the wear. A quick anecdote so that others do not make the same stupid mistake:
I used the OEM scissor jack to lift the rear driver side corner. I had used the OEM joack many times successfully, knowing that it was not the best tool for the job, but it was convenient and seemed to do the job. Wheels were not chocked, car was not on a jack stand. Everything that I could have done incorrectly was done incorrectly. Rear driver wheel was being stubborn just as reported by the OP. I gave the tire a couple good whacks top and bottom with a deadblow mallet and saw it move a bit, so I grabbed the OD of the tire with my gloved hands and started push/pulling it to rock it off the hub. I looked over and saw the scissor jack tipping and did not get my right hand off the top of the tire quickly enough. The car rolled off the jack and crushed my hand between the tire and the fender. That was about 5 weeks ago and I will refrain from posting a photo of my hand directly following the incident. I am lucky to still have use of my right hand.
Let me reiterate: Before doing ANYTHING, including wailing on a stuck wheel, put the car in gear, engage the parking brake, put the lifted corner securely on a jack stand and firmly chock the other 3 wheels. Push the car back and forth to make sure it is stable before manipulating the wheel.
More to the point of this thread - has anyone had success applying anti-seize to the bore of the wheel to prevent it from getting stuck on subsequent wheel removal?
