edit: Had a bad battery, changed it and car started up just fine.
P1215 - Cylinder 3 Fuel Injector (N32), Circuit Short to B+
Anything I can easily look into at home for this or do I need to get towed to a shop?
Car has just under 68,000 miles.
Little back story. I had just pulled the car into the drive way from off the street. I hooked up my OBDII adapter and changed the air settings to display on the big MMI screen rather than the little LED bar by the controls. Then I checked the fault codes. First time I checked the fault codes there was no P1215. I unplug the adapter, go to start my car and it doesn't start. I check the faults again and the P1215 comes up. I was using Carista to do all of this. Just seems sort of suspicious that this happened after my car hadn't been driven for nearly 24 hours and right after I mess with the settings for the first time in months.
