Originally Posted by
danky
thanks ctc for your help thus far!
So you have had NO fluid loss? No fluid loss. I checked last night and it's just under max.
After shutting the motor down straight after are there bubbles in the fluid? I did not see bubbles last night when I turned it off (was a little dark though) but didn't see them when I restarted the car last night
Can you get the car up on stands at the front, idle it and go lock to lock, is there bubbles in the fluid then? I don't have stands unfortunately. Just ramps which wouldn't allow me to turn the wheel.
Have you cleaned the filter at the bottom of the reservoir? I have not done this.
Do you still have the first pump that failed? Was it cracked open and checked? I do not have the first pump to look at unfortunately.
I started the car up this morning and there was a glimmer of hope. I can turn the wheel a little with no resistance and then it makes a loud screeching sound when I get too far and I lose power steering.
Based on the fact I don't have stands, do you think I can just do it on the ground, idle, go lock to lock etc to see if there are bubbles (are bubbles good or bad?). I can also trying to clean the reservoir and the priming tonight when I get home.
Thanks again.
Listen,
I had exactly the same problems as yours, except that I also noticed that my speedo was going crazy above 70mph. The needle in the speedomater gage was then fluttering between 70 and 80mph, and the faster I was going the crazier it was....
Soooo, all in a sudden I realized why I was always losing Power Steering.
It's because we have adaptative power assist: the faster you go the firmer the steering is.
But guess what, if my speedo was wrong and not precise, it's because I had a randomly faulty ABS sensor (no lights in the dash). Then if ABS sensor is sometimes bad ---» your PS is acting weird. Sometimes it's ON, sometimes it's off...
So to resume:
I had a PS pump replaced for nothing, an expensive relay under the dash (Servotronic Steering Control Relay 638) for nothing, and then I saw my speedo acting weird over 70mph so I decided to have it fixed because it must had something to do with my random PS failures and BOOOOOOOOOOM: problem solved with a new abs sensor!!
So at this point, you may try two other things:
1/ see if your speedo doesn't go crazy above any speeds (please choose a straight line ;-) )
2/if not, try a new servotronic relay (I work at Audi dealer, and many techs told me that they have ever seen some faulty ones acting like this. Unfortunately, I can tell you that this thing is not refundable 'cause it's electronic. So if you need one, tell me, i replaced mine and it wasn't the problem for me)
Hope this helps
