Results 1 to 6 of 6
    Active Member Two Rings [RS4]fsu16a's Avatar
    Oct 31 2009
    Auburn, MA
    Variable valve timing solenoid problems?
    So I recently brought my car in to get fixed cause my car seemed to be misfiring when I would get up to speed on the highway. After 3 weeks at my mechanics he said there's was still an issue with my variable valve timing solenoid and that it's not circulating my oil back through. He said there might be some sludge so he put a solution in my oil to try and fix it. I after I left I noticed that now when I get up to speed my car seems like it's misfiring again at 2000s rpms and my check engine light flash but once I go below 2000s rpms the light goes out. Anyone have any idea what could be happening. I also had my fuel injectors and spark plugs replaced about 2 months before this all happened.
    Feb 24 2004
    Minneapolis
    I think you need a different mechanic. Might be some sludge so he put an additive in the oil? He's spit-balling. I know 3 or 4 good indy techs here in town that have VCDS and know how to use it. I'm sure there are plenty more in the Boston area. If not, take it to the dealer.
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    Haven't heard about an issue like that. What are the codes?
    Veteran Member Four Rings ryanhmusic's Avatar
    Aug 05 2014
    jack stands, a power washer, hand tools, bones of my fallen enemies, etc
    Quote Originally Posted by [RS4]fsu16a View Post
    I'd start by reading your codes with VCDS.
    I doubt any oil sludge bullshit is gonna help.
    If you're not comfortable doing the work yourself -- there's a handful of shops in the Boston area that do fantastic work and are reasonably priced.
    I'm living for the day I can park something Italian inside of my house.
    I had one wild summer on match.com. -some jackass
    01100010 01100001 01101110 01100001 01101110 01100001 00001010
    Oct 31 2009
    Auburn, MA
    So today the codes where P0011 and P0303
    Oct 31 2009
    Auburn, MA
    The p0303 is most likely a bad coil pack but the p0011 is an intake camshaft position timer
