    Active Member One Ring Ericdhvac's Avatar
    Nov 25 2012
    01' Santorin S4
    Urbana, Md
    Wheel swap question
    I need new wheels and tires on my b5 S4 but also wanted to get new wheels and tires on my B8.5 S4 (19x8.5"), I would like to swap the combo from the new car to the older one and put AG M590 20"x 10" on the new one........if that makes sense.
    Has anyone put 19x8.5 (ET43 I believe) in a B5?
    Thanks,
    Eric
    BTW, I did do a thread search but only found where someone put 18" B8 wheels on a B5 not the 19's.
    2001.5 S4 Santorin Blue 6sp
    2014 S4 Nogaro Blue 6sp
    2015 Macan S
    2015 S5 Sapang Blue
    2011 Grand Cherokee
    2011 Mini Cooper S
    2014 BMW K1300s
    2015 BMW R nine T
    2010 Ducati Monster 696
    2017 MV Agusta Brutali 800 America
    May 16 2008
    WA
    are you trying to use the original b8 tires as well? I would guess the tires would be too tall, as 19s are already large in themselves, but without numbers it would be hard to know for certain. With et43 and 8.5" you will likely need something like a 8-10mm spacer if memory serves.
    Dec 10 2013
    Borden, Ontario, Canada
    Put on 225/50r17 B8 Sport wheels onto my B5. Clearance issues in the back for some reason so I had to use 5mm spacers.
    You'll want at least a 35 profile tire to fit a 19 properly, but that'll make it much easier to bend the rims
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    Nov 25 2012
    01' Santorin S4
    Urbana, Md
    Yes, I want to just swap the B8 wheels and tires to make it easy, the tires on the B8 wheels are 255/35 ZR 19, the car only has 10k miles on it so the tires have a fair amount of tread. I was hoping to get away with just needing spacers and a hub bushing.
    2015 Macan S
    2015 S5 Sapang Blue
    2011 Grand Cherokee
    2011 Mini Cooper S
    2014 BMW K1300s
    2015 BMW R nine T
    Registered User Four Rings Skyler@Achtuning's Avatar
    Feb 14 2007
    Redmond WA
    Try a soft test fit first as it's possible the 19" peelers will not clear the wide HP2 brake calipers on the B5. You could use 3-5mm spacers if you need a bit more room. You'll also need 66.56mm to 57.1mm hubcentric rings to correct the centerbore.
