Results 1 to 4 of 4
Thread: ECUs
    Established Member Two Rings blkd_outA401's Avatar
    Dec 13 2010
    Black B5 1.8TQM Revo stage 2
    OC, Oregon
    ECUs
    Am I able to use an ecu from an 01 S4 tip in a 01 allroad?
    Nov 16 2014
    ovid ny
    The thing to look at is the numbers. Don't worry about the last letter. If you have more questions look at nefmoto.com
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    If apb allroad, it should be fine.
    The keys in the connector are slightly different so you need to remove them from the ecu connector.
    It is a little tight in there with all the pins around it, but I did it once with a mini pencil dremel gizmo.
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
