Results 1 to 33 of 33
Thread: Battery dying
    Oct 15 2008
    07 RS4
    New York
    Battery dying
    I had the battery replaced about 6 months ago and up until 10 days ago I noticed when starting up the car that the cranking was slower than usual but eventually started on 3 separate days, and this past weekend I go to start the car and the battery is dead. Radio comes on but car barely turns over. Any ideas what it can be? Possibly faulty battery?
    Veteran Member Four Rings ryanhmusic's Avatar
    Aug 05 2014
    jack stands, a power washer, hand tools, bones of my fallen enemies, etc
    Quote Originally Posted by Hotazlava32 View Post
    have you tested the alternator?
    I'm living for the day I can park something Italian inside of my house.
    I had one wild summer on match.com. -some jackass
    01100010 01100001 01101110 01100001 01101110 01100001 00001010
    Oct 15 2008
    07 RS4
    New York
    Haven't gotten a chance to test anything yet
    Aug 05 2014
    I would start there. Most likely that's your problem.
    Oct 15 2008
    07 RS4
    New York
    Forgot to mention that the car only has 38k miles, even though the alternator can go at any point.
    Veteran Member Four Rings badbluers4's Avatar
    Oct 27 2011
    Atlanta, GA
    How do you know the new battery is dead? Did you test the voltage on the battery? I'm only asking because it sounds more like a starter issue, and these cars are known to have starter issues. I'm still on OEM battery but replaced my starter last year after a few delayed starts, now it starts like a champ every time.
    Oct 15 2008
    07 RS4
    New York
    I'm assuming its the battery because when I changed from the last one (which was the original), it was having the same exact symptoms.
    Oct 27 2011
    Atlanta, GA
    Then yes, I would have a look at your starter. If a new battery is giving you the same issues, then I don't think the battery is the problem. Run a battery test just to confirm.
    Senior Member Three Rings musasabi's Avatar
    Aug 11 2014
    Chicago, IL
    Fwiw, I've had cranking issues since I bought mine a year and a half ago. Sometimes it'd crank slowly, sometimes not at all. But, only if I didn't run in for a few hours. Weirdly, if I leave my key in the On position for like 10-15 minutes, the car starts right up like normal. Or, if I don't have the time, I can hook the terminals in front up to a wall charger and in after a minute or two of charging, the car will start. AutoZone said the battery is dead according to their tests in like April 2015, and I've been going through this foolish routine ever since.
    I only mention this so that you'll try the "key in On" strategy and maybe have the same results I have, haha. My car's at 85,000 miles, though, so there's that.
    2014 S4 | 6MT, Moonlight Blue, Black Optics, Sport Diff, Navi+, B&O
    2008 RS4 | Daytona Grey, Titanium, Exclusive
    2013 Jetta TDI | 6MT, Fender Audio, Sat Nav
    2003 Passat GLS | 5MT, APR 93 Tune, Koni FSD/Eibach Pro Kit, Magnaflow Muffler
    Oct 27 2011
    Atlanta, GA
    yea i bet you a beer, its the starter. I've always thought I should change my battery since it is the original and its heavy as SHIT LOL and I only got delayed starts when cold. The battery is very strong, I can run just the radio while washing the car etc and don't have issues. But as soon as I replaced that starter, it starts so good now, no delay ever! I still will replace the battery here very soon just because lol
    Aug 11 2014
    Chicago, IL
    How long was that starter job for you? I'm not even sure where it is, tbh. Haha.
    Oct 27 2011
    Atlanta, GA
    Quote Originally Posted by musasabi View Post
    I honestly don't remember since i had it done under warranty, but it wasn't a bad job maybe 3 hours. My shop is real good tho, they know how to get it done! LOL
    Aug 11 2014
    Chicago, IL
    Nice. =) I'll have to look into it. It's super annoying to have my wall charger as a permanent accessory, haha.
    Oct 27 2011
    Atlanta, GA
    yea thats weird, and actually does sound like a battery issue.
    Aug 11 2014
    Chicago, IL
    Even though if I let it "warm up" by leaving the key in On for a few minutes (presumably draining more battery via accessories) the car starts?
    Veteran Member Three Rings Avus RS4's Avatar
    Apr 09 2015
    Niwot, Colorado
    How long has the car been sitting between starts?
    2007 Avus Silver Rs4
    Bone Stock
    Oct 15 2008
    07 RS4
    New York
    Usually a few days, a week the most
    Apr 09 2015
    Niwot, Colorado
    You might need to get yourself some trickle charger...
    Bone Stock
    Veteran Member Three Rings AvusPdx's Avatar
    Jan 17 2015
    Portland, OR
    Ive noticed a struggle starting in very cold weather, but that was with most cars I've had. Who has changed their OEM batteries here?
    Current - Audi B8.5 S4 2013, Mercedes Benz GLE350 2016, Volvo XC60 T5 2015
    Mods - H&R RSS Clubsport, APR stage 2 + pulley, Roc Euro intake, AWE Touring 90mm, ECS RS4 Gloss Black Grill, VMR V705 19x8.5 matte black, Blizzak LM32 225/40/19 (winter) OEM Q5 Peelers 20x8.5 et33, Dunlop Sportmaxx 245/35/20, EBC Slotted/Drilled rotors F/R, EBC redstuff brake pads, Motul RBF 600 brake fluid, Enlaes rear CF spoiler, LED interior light swap, LED fogs, H&R rear sways,
    Apr 09 2015
    Niwot, Colorado
    Quote Originally Posted by AvusPdx View Post
    I've replaced mine but since I'm not the original owner, the battery my car had was one made in Spain, and a recycled one to boot!
    I put a good quality battery in it.
    Bone Stock
    Oct 27 2011
    Atlanta, GA
    Quote Originally Posted by Avus RS4 View Post
    my car sits a week easy without me driving it and no issue on startup, oem battery, new starter. I'm telling yall new starter is the key lol
    Apr 09 2015
    Niwot, Colorado
    Quote Originally Posted by badbluers4 View Post
    Within the realm of possibilities, the starter could be the issue, sure.
    I've just brought that up because being in the same situation a few years ago, my battery died as a result of not having a trickle charger on my Z06.
    But, that's easy to diagnose before he goes out and gets a new battery
    Bone Stock
    Mar 14 2014
    E46 M3 [sold] | Audi RS4 [sold] | 2010 GTI [sold]
    Northern Ohio
    You might have a parasitic draw on your electrical system that is draining the battery between periods of inactivity. There are components of the car that are always drawing some power - but it should be low - like .03-.08 amps. Finding it can be somewhat of a challenge - but identifying if you have a problem is pretty easy.
    - First thing you need to get your battery charged up to 100%.
    - Get out your multi-meter that measures AMPs and hook it up inline between the battery cable and the battery (negative terminal). So, disconnect the negative lead, hook it to your multi-meter and hook the multi-meter up to your battery. Make sure its on Amps (10/20 amp setting) and measure what is going on. Be sure to have a multi-meter that is strong enough that will be able to handle the load of the electrical system under load. Be careful (Don't) of trying to start your car while you have this hooked in series - because your entire electrical system is running on those little cables running into your multi-meter - and you might burn them out or blow up your multi-meter or worse - like starting a fire...
    -Shut all the doors, make sure the lights are all off, etc. lock it up. You'll need to wait for all of the systems to turn off - like parking lights, interior lights. Usually that's 5-10 minutes in my experience. Since my battery is in the trunk, i just flipped the trunk lid catch to fake it out that it was closed.
    - look at your the reading and if its more than .0x something - you likely have something drawing power that shouldn't be.
    So, finding it is the next step. leave everything where you have it. one by one you will need to pull fuses (and replace them one by one) and check to see if that reduces the draw - or eliminates it.
    Once you find the right fuse, you'll need to look at what is on that circuit and trace it from there - which is likely the most difficult part of the process.
    2015 Sepang S3
    APR Stage II [ ECU & TCU ] AWE SwitchPath Exhust | APR downpipe | Neuspeed RSe102 wheels
    Veteran Member Four Rings Mistro's Avatar
    Jun 19 2011
    Hotazlava32, your issue sounds like parasitic draw somewhere
    musasabi, your's sounds like the pretty typical starter problem (especially the part where if you try again after a few minutes it works)
    Aug 11 2014
    Chicago, IL
    Quote Originally Posted by Mistro View Post
    That was the diagnosis last time I posted about it but didn't do anything about it. Haha. Eeeeeeeventually.
    Jun 19 2011
    lol as long as you don't get stranded somewhere. I kept putting mine off too and luckily it completely gave up at at my house.
    Oct 27 2011
    Atlanta, GA
    which replacement did you go with? I'm still trying to decide....
    Aug 11 2014
    Chicago, IL
    I'll probably go with the JHM one, because OEM/retailer I've worked with before/etc
    Oct 27 2011
    Atlanta, GA
    I meant the battery lol
    Aug 11 2014
    Chicago, IL
    Haha. Threadjack fail. =D
    Oct 15 2008
    07 RS4
    New York
    UPDATE: It was the battery.....apparently Bosch batteries really suck.
    Nov 12 2015
    Oregon
    Glad to hear that the battery took care of it for you. Have you done a voltage drop test on your alternator wire and your starter wire? That would tell you if you have corrosion developing in the cables (can cause poor charging and/or slow cranking) its unlikely, but might be something to check. On my s4, i had a similar situation and after a battery change, not much was different. I upgraded my alternator wire and the car has never even so much as flinched while cranking.
    My build log
    Senior Member Three Rings webmouth247's Avatar
    Sep 08 2014
    California
    Im having a battery/starting issue. Recently took the car on a 1000 mile round trip. It's was hot all weekend 90 to 100 degree weather. Come back and the next day Myou car slow cranks. Ran some errands and came back home with no issues. Had to take off again and the battery slow cranked and died (click click click). Had the battery/alternator/starter checked for issues and neither autozone or Lexus dealer where I do my oil changes at showed issues of beine bad. I do notice the lights take a minute to become fully bright now during these slow cranks. It feels like a dead or weak battery but just not sure. Any ideas?
    Also this is a s4 not rs4 so it's auto if that helps.
    2006 artic white s4 avant black/white recaro's. Jhm tune. Jhm catted down pipes 18x9.5 et 39 tws bathurst
