Results 1 to 9 of 9
    Veteran Member Four Rings impulse's Avatar
    Mar 06 2014
    2006 B7 A4 - 2.7t Swapped. 2008 8P A3 - 3.2L VR6
    Connecticut
    WTB: 034 or JHM HFC
    Delete for title update
    Joe
    @jg_iii_
    Check out my progression thread - http://www.audizine.com/forum/showth...Picture-Heavy)
    Stage 2 Banner Advertiser Four Rings Hugh@EuropaParts's Avatar
    Aug 22 2010
    Piscataway, NJ
    I have a bunch... $330.00 and you'll have it tomorrow.
    034MOTORSPORT HIGH FLOW CATALYTIC CONVERTER (A4 B7 2.0T)
    Hugh
    EuropaParts.com, Your Trusted Audi Parts Source
    Facebook: Like Us on Facebook
    Instagram: Follow Us on Instagram
    Mar 06 2014
    Connecticut
    Bump
    Joe
    @jg_iii_
    Mar 06 2014
    Connecticut
    bump looking for one used, might settle on a test pipe
    Joe
    @jg_iii_
    Mar 06 2014
    Connecticut
    Bump, considering a test pipe
    Joe
    @jg_iii_
    Senior Member Three Rings johnruan's Avatar
    Oct 01 2014
    Audi Q5
    chicago,il
    Saw you have DP-Y you best bet to mate with is go with jhm test pipe or hfc. Other brands cat will not have clearance will rub against trans crossmember bar. Few of us having this problem with 034 on dp-y. Just giving you heads up what you should look for or you could cut and re-weld the DP for clearance.
    Sent from my SM-G900T using Tapatalk
    Mar 06 2014
    Connecticut
    Quote Originally Posted by johnruan View Post
    I would rather not cut and reweld so looks like JHM tp or HFC!
    Joe
    @jg_iii_
    Aug 31 2011
    C7 A6 3.0T Prestige - AEV JKUR
    Lathrop
    Quote Originally Posted by impulse View Post
    We have them in stock if you want to go new
    Mar 06 2014
    Connecticut
    Quote Originally Posted by Jake@JHM View Post
    I might wait a little to see if I can get a TP. Need to save money for a tune, and still trying to decide which route to go
    Joe
    @jg_iii_
