Results 1 to 6 of 6
Thread: New A3 Intro
    Jan 01 2016
    New A3 Intro
    Hey guys,
    I recently picked up a 16 season of audi a3. I've been really enjoying the car since I picked it up, but I have a few questions regarding VCDS(vag-com) and tuning.
    I did a few VCDS mods:
    -gauge sweep
    -oil temp
    -lap timer
    I browsed several different forums and I couldn't find out how to turn off the amber light in the headlight housing. I plan to eventually get a set of E-codes and I understand this vcds modification is necessary to avoid the bulb out error on the dash.
    Also regarding tuning the car, does anyone have the JB4 or APR tune installed? Is it a night and day difference? I'm hesitant towards tuning it since it is a lease. Any insight on this?
    Thanks in advance !
    Here are the pics of the car:
    http://imgur.com/a/5Cu1W
    Quote Originally Posted by ibis_a3 View Post
    Hey guys,
    -gauge sweep
    -oil temp
    -lap timer
    Thanks in advance !
    Congrats on your purchase!
    May I ask how you programmed the oil temp via VAGCOM? I have a dealer visit next week and would like to ask them to do this, but not sure they would know the coding...
    Cheers.
    Sent from my SM-N920W8 using Tapatalk
    Jan 01 2016
    Quote Originally Posted by MuchoQuattro View Post
    Cheers.
    Thank you!
    It really depends on your dealer. They're all able to do the vcds modifications. On vcds click on instruments(17)-> Click on long coding-> byte 10 and click on the box next to display oil(bit1).
    I just got this from the thread with the list of vcds mods.
    Veteran Member Four Rings phillyquattro's Avatar
    San Francisco, CA
    As far as I've seen there isn't a way (yet) to disable the amber light via VCDS. I also don't think any coding is needed when swapping between US lights and ecodes. There could be some differences though between Xenon and LED housings.
    2019 GT3 Touring
    2019 SQ5 Premium+ (Build Thread)
    2016 S3 Premium+ (Build Thread)
    IG: brandongray
    Jan 01 2016
    Quote Originally Posted by phillyquattro View Post
    Wouldn't I have a bulb out message ? The euro headlights don't have an amber light, which would most likely need vcds coding to remove the error message. I may be wrong though. I'm just going off of past cars and the experience I had with them.
    San Francisco, CA
    That's been my experience with previous cars as well. From all the swaps I've seen on here thus far the e-codes are just plug and play, no VCDS needed. Which could also help explain why no one has been able to figure out how to disable the amber in the NA headlights. Benji did a Xenon e-code swap and mentioned that he doesn't think the shop had to do any coding with install.
    2019 GT3 Touring
    IG: brandongray
