I'm having some serious airlock issues on my B6. About a month ago, I started having issues with no heat at idle or low rpms. I checked the coolant level and it was good. I drove it for a couple weeks and it got progressively worse, where I would have to rev the engine first to 2500 rpm and then 3000 rpm to get heat. I bled air out of the Allen bolt hole and the heater core bleeder. Heat was good at idle and while driving for the first day. The next day it was back to no heat below 2500 rpms. I unscrewed the coolant bottle and lifted it up with a bungee cord to the hood. Ran the engine at idle and bled some air out the bleeder screw. I took the lid off the bottle and then let the car run. I got a few small bubbles. I had great heat at idle at this point. I then revved the car to about 5000 rpms for 15 seconds. There were no bubbles. When I let it go back to idle, huge amounts of bubbles came out. I still had great heat. That was last night. This morning, I drove to work and had better heat but still nothing at idle. Also, the car will randomly go almost all the way cold and then back to normal within a minute or so and will go almost all the way hot for about 30 seconds before going back to normal. I did a 0-110 mph run at wide open to see if i could get it to overheat. Temp stayed right at the middle through the whole run and then went all the way cold for a few minutes before coming back to normal. I know I am getting air in the system but I cannot figure out where or how. There was a small leak where a rubber hose goes into the top metal pipe that I fixed. I do not think head-gasket as it doesn't overheat under load. I am out of ideas. Any help would be appreciated.
