Results 1 to 7 of 7
Thread: CTS DIY info?
    Veteran Member Three Rings TEB's Avatar
    Sep 19 2010
    '70 Cutlass, Yukon, MDX, Pilot
    Ponte Vedra Beach, FL
    CTS DIY info?
    I did search, but didn't find anything on replacing the CTS. Is there an illustrated DIY that anyone knows of? I know people say it requires some contortionist skills to get to, but I haven't even been able to find the damn thing. I know it's on the back of the engine, but where specifically is it located and what's the best way to access/replace it?
    Veteran Member Four Rings badger.'s Avatar
    Mar 31 2014
    '18 RS3 | '05 S4 Avant
    KY
    slightly towards passengers side on back of engine. hard to see in the car; the wiring harness has a huge bundle that runs across right over it and there is a vacuum line that runs over top of it as well.
    green thing here. yours might not be green? I think some stock were black but I might be wrong on that.
    as far as DIY I don't have one handy. No idea how people change that damn thing in the car. which is unfortunate because I had to ziptie mine in when reinstalling the engine because the clip broke and now it drips slowly and I cant reach the damn thing to fix it
    '18 RS3 Glacier White: DS1 Stg 2 | Wagner EVO1 IC | 034 4" Turbo Inlet | 034 4" Intake
    '05 S4 Avant Brilliant Red: JHM Tune | JHMv1 Headers | Fast Intentions Catback | Ported IM & Spacers | JHM LWCP | JHM ATF Cooler | Thor Skid Plate | Koni Yellows | Apikol Rear Diff | JHM LW Rotors | AudioQ 1200D w/Dual 10" CVRs
    Sep 19 2010
    Thanks, that's very helpful. That looks like the new CTS I bought. I had one person suggest that it's best to access from below with the passenger side heat shield removed. Looking at your picture, that seems logical.
    Is the clip in your picture? How did it function?
    Veteran Member Three Rings jakeoboy67's Avatar
    Oct 21 2013
    mk2 Jetta Tdi
    NB , Canada
    SAI valves/hoses make it really hard to reach from the top,
    I suggest completely draining your coolant to change it , as "swapping" the sensor quickly for the new one can make quite a mess if you take too long to do it
    Mar 31 2014
    KY
    Quote Originally Posted by TEB View Post
    Here is the clip.
    https://www.ecstuning.com/ES2586934/
    You can kinda see it in my pic above if you look closely; the opening of the C shape is towards the driver side (left side of pic)
    Veteran Member Four Rings bmwpower603's Avatar
    Aug 30 2015
    Derry NH
    Nice picture of the location. Speaking of cooling. Any idea where the water pump/ t stat is??
    Veteran Member Four Rings pwest15's Avatar
    Sep 15 2013
    2017 S3
    Denver, CO College Station, TX
    Quote Originally Posted by bmwpower603 View Post
    Right here
