Results 1 to 31 of 31
    Senior Member Two Rings acsgp's Avatar
    Jul 17 2014
    Singapore
    Supercharger cooling
    Just a couple of questions that I can't seem to find an answer for.
    1. Is there a specific heat exchanger for the supercharger? If so, if the stock system is single loop, so there are 2 heat exchangers for the combined engine + supercharger loop?
    2. I've been wanting to improve cooling without having to put in a new heat exchanger in front of the existing radiator. I'm concerned that this will impact the cooling capability of the existing radiator as airflow will decrease, and it will be hotter downstream of the new heat exchanger. Is this a valid concern?
    3. I've been in contact with both AWE and their local distributor, but they don't seem interested in just selling me the reservoir and upgraded pump alone. But I've gone on to read that the new reservoir will separate the loops, so how can it be sold separate from the new heat exchanger?
    At this point in time, I just want to increase volume and flow to improve cooling.
    Any thoughts?
    2010 S4 Avant, Forged bimotos, Brembos, Revo GB tune
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    This is very good thought. I want to do this to mine as well. If you can just separate the S/C cooling loop from the engine loop. It will run much cooler than what it is now. I will have to pull up my pics. But should be pretty easy to separate the systems. Just need some fittings. And you will need a pump that runs constantly when the engine is running. Or you need to know the logic behind the factory pump. The radiator that's in the car now should provide enough cooling if you separate the system. You won't be trying to cool down 212F coolant. The coolant will be much lower temp your trying to cool and will be cooler after exiting the radiator and will absorb more heat from the air charge than being at a higher temp. I want to do this but never got around to it.
    Dec 19 2014
    Virginia
    ive done some research on this myself here is what ive gathered.
    this is where the engine coolant seperates from the charger coolant
    [IMG][/IMG]
    if you were to cap the left side off and add a reservoir to the right you would be covered here.
    then you can put this pump inline with the supercharger cooling and there you have it a closed cooling system
    [IMG][/IMG]
    http://www.cxracing.com/mm5/merchant...gory_Code=AWIC
    16 s3 eurodyne stage 2 ecu/tcu
    Jb4 Methanol Intake exhaust
    2010 s4
    Epl stage 2 ,test pipes non res downpipes custom exhaust , intake , dual pulley setup torque monster .
    Gone:
    07 a3 , unitronics stage 2 , water meth .
    Feb 20 2006
    NC
    following. Looks like divorcing the system and new pump would be a low cost solution for increased cooling!
    2021 BMW M340i
    2021 Tesla Model Y Performance
    GONE - 2019 RS5 Sportback
    GONE - 2021 Audi Etron
    GONE - 2019 Audi Sq5 - JB4 Rev9 intercooler
    GONE- 2013 S4 DSG - DP stage 2 EPL
    May 09 2012
    2013 s4, 2008 cbr1000rr
    United States
    Interesting points. Subbed
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    I bet that the single point that the two cooling loops connect, does not transfer a significant amount of engine heat into the supercharger cooling loop. Because it is a single point, no fluid flows between the loops. Audi made a single point connection so that both loops get filled at the same time at the factory.
    Apr 04 2012
    MSP
    There are several systems available and lots of information on here for each. Plus you can visit their web sites.
    AWE, APR, Alpha (what I'm running)... etc. I'm very pleased with the Alpha system I have.
    None of them will reduce engine cooling.
    Some have a segregated loop... only issue with that is that if and when coolant levels get low (leak etc) on the Boost cooler segregated loop there is no warnings that you would otherwise get with a combined loop.
    There are no proven benefits that I am aware of for separating the loop either and they way you are suggesting separating them may do a worst job a cooling in fact especially if keeping the OE hardware.
    You can buy full systems with pump etc or you can buy partial systems. i don't really see the point to buying a partial system though...
    They are proven work well...
    Feb 20 2006
    NC
    Current offerings are a joke....the product does not justify the cost, not even 50% of the cost.
    2021 BMW M340i
    Apr 04 2012
    MSP
    Quote Originally Posted by scottycs View Post
    They work...
    DIY if you have the time... Just like any aftermarket product - typically over priced for what they are. Look at the cost of exhausts... lol... same thing... if you can build one yourself that sounds good have at it...
    Feb 20 2006
    NC
    exactly why I have not bought an exhaust on any of my recent cars. Unfortunately I do not have the time to DIY, so I am hoping someone else does the leg work and posts a DIY :)
    2021 BMW M340i
    Veteran Member Four Rings jran76's Avatar
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    Several people have DIY'ed both a coolant system and exhaust if that is what you are after. I'll agree with MrFunk in that everything like this is overpriced if you are paying someone else to conceptualize, design, engineer, test, procure, assemble, market, ship, warranty, and support a product. It's the nature of the beast.
    What do you think it would take to cobble together your own kit? Maybe $800? For something like this, I'd rather pay $1600 to AMS to do all the steps I listed above. You get a system that is engineered to a really high level in terms of brackets, mounting, fitment, the wiring is fully plug and play, etc. The level of detail is way beyond what you'd ever accomplish with a DIY. You'd probably say that doesn't matter for something like this, but if you installed both, I think you would probably change your mind.
    2018 S4 : Daytona Gray : Black Nappa : Carbon Atlas : S Sport : Black Optics : 034 Springs/Rear Sway Bar/Inserts : 19x9.5" BBS CH-R Wheels : EPL tune : Wagner Intercooler
    2002 S4 : Black : Black Leather : 6-Speed : Stage 2+ ...
    2022 Q7 : Mythios Black
    Feb 20 2006
    NC
    $800 to put together my own kit? I would say half of that at most...
    2021 BMW M340i
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    Several people have posted DIY's on here and the radiators run in the $400-600 range, the pumps, $100-250, and reservoirs maybe $50-100. Add in wiring, silicon hoses, clamps, fittings, brackets, etc. If you think you can do it for under $400, I'd like to see what you come up with. Post some links for the radiator, pump and reservoir you'd use. I'm going to say you can't get close to $400. I'm not trying to give you a hard time, but several people have said the same thing, and then they look for the parts and realize they're pretty far off.
    Edit: I should add.... I have no doubt you can find a radiator, pump, and reservoir for $400, but I don't think you are going to find parts on par with the existing kits for anything close to that.
    Mar 28 2009
    Minneapolis, MN
    Quote Originally Posted by skywagon
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    ^^That's what happens when you start thinking too much about things....
    Jan 14 2009
    pasadena md
    Quote Originally Posted by jran76 View Post
    I looked up awhile back and i priced out a radiator for like 250-300 that was close to the size of AMS.
    Honestly the best way to see whats going on is to get the car at operating temp and temp out the inlet to the S/c radiator and see how close it is to normal coolant temp. That will tell you if its going in a loop. But it has to use the engine coolant and cools it down and sends it to the S/c I think from what i remember after the S/C it dumps back into the normal cooling loop.
    Jul 17 2014
    Singapore
    Thanks for the responses everyone.
    The idea i was mooting was to keep the stock loop with 2 heat exchangers, with increase volume via a reservoir and increased flow via the upgraded pump. I'm not gonna track the car, just want to improve cooling out by the equator where I am, and potentially to offset heat soak when I chip to stage 1.
    I also have ADS, and don't want to touch that cooler if need be.
    Thoughts on that?
    Jan 14 2009
    pasadena md
    Well depending on what B8 you have. If you have a B8 you have an additional radiator in the drivers fender well bumper area. If you have a B8.5 they deleted it. What your trying to do could upset the flow dynamics to the stock system if you want to add a bigger faster pump in the system. It would cause cavitation and you can overheat or destroy your engine. if i would do anything like that would be to add a 2nd radiator after the 1st one then pipe it to the S/C That would be the only way to help cooler coolant to get to your s/c. But adding volume won't really help much. Its still going to run at the same temp unless you isolate the system.
    Apr 04 2012
    MSP
    LOL - enjoy your stock S4...
    Nov 19 2013
    Someone mentioned Killer Chiller in a similar thread. Why the heck isn't this platform all over that idea for cooling? It's pretty cheap and appears to be way more affective than any cooling system currently offered for the B8. It connects your supercharger to the AC line and consistently drops IATs 30-40 degrees below ambient. I'm guessing you have to divorce the SC from the engine coolant line though. They even have a kit for the B8. Anyone using it?
    Jan 26 2015
    2017 XC90, a workbench
    CO
    This is why I started a thread recently on the killer chiller. I emailed Joseph Kincaid (the developer) and he said he is not sure if their b8 a4 system would fit the S4. Still deciding if I want to try it but may do it in the summer. Based on my research, it works great for a DD but using it with an upgraded HE is counterproductive since the HE will try to get the temps back up to ambient. Our stock HE is quite small so it may work well. One guy on the MB E55 forums said the S/C was cool to the touch at normal operating temps in the summer. I honestly think there could be a market for this for our cars. Someone just needs to try it and report back.
    I personally would not divorce the system as there is no way to monitor it, but I can see the possible benefits.
    2018 S6 - stock for now
    2014 S6 - Stage 3 - Gone
    2013 S4 - Dual Pulley e85 - Gone
    Veteran Member Four Rings rtl5009's Avatar
    Jul 28 2009
    Philadelphia PA
    How do we know the pump mentioned above is better than the stock s/c pump?
    b5 s4 built bottom stg3 on E - Sold- Never felt happier
    c8 a6 allroad
    Jul 17 2014
    Singapore
    Quote Originally Posted by Steve416 View Post
    Quote Originally Posted by Hofahome View Post
    Interesting. That being said, would it affect the a/c performance in the cabin? Zero sum game after all.
    Jan 26 2015
    CO
    From what I have read, not that much at all. I thought about that too. Also, running the AC compressor uses about 8hp and the decrease in IATs more than makes up for it by gaining back the "lost" hp associated with high IATs.
    May 03 2008
    Ohio
    We have at least 5 or 6 ECU tuners that can completely remap engine parameters. Perhaps one of them could develop a (clean oem-ish) method for coolant sensor connection using some existing un(under)used accessory wiring, etc. to at least give you a dash indicator. Do our cars have washer fluid level indicator? (think my b5 did - haven't looked/experienced yet on my b8)
    Just thinking sensing coolant loss in a divorced circuit shouldn't be a deal-breaker, if splitting the system were the best thermal solution.
    Sent from my SM-N910P using Tapatalk
    Jul 28 2009
    Philadelphia PA
    If you lost all the fluid in the S/c circuit your car would be dogish slow with your foot down for extended periods. You would realize immediately.
    c8 a6 allroad
    Feb 20 2006
    NC
    Those prices are grossly inflated, even for custom made parts.
    2021 BMW M340i
    Feb 20 2006
    NC
    Not sure what that means... I refuse to by cat-back exhaust because I prefer a quiet car and there is no noticeable performance gain. I ran stock exhaust with VRSF downpipes on my 335i.
    Quote Originally Posted by MrFunk View Post
    2021 BMW M340i
    Nov 05 2014
    houston, tx
    Do you have sources ? I've paid for custom made parts and those prices actually seem low to me. 50-100 for a custom reservoir is cheap. I paid 150 for mine. The price I paid was one of the best quotes I recieved at the time.
    Feb 20 2006
    NC
    The reservoir is a about right, 100-150. Radiator and pump is high. The more I think about it, I will just go with a upgraded radiator for a few hundred. There is a ton of custom shops near me, living 30 minutes from the "home" of nascar.
    2021 BMW M340i
    Senior Member Two Rings lowjonathan's Avatar
    Jun 30 2015
    do you have how the end product reservoir look like? do they sell it online?
    thanks
