I have a B8.5 S4 and there is just way too much body roll. So I am planning to upgrade the suspension.
After a bit of research I am down to deciding between the Bilstein B16 Ride Control coilovers and the KW DDC setup.
They seem to be comparable in specs, but why is there such a price difference. Is there some difference between the two that I am missing? the prices I have found are around $2800 for the Bilsteins and $4325 for the KWs. So what would make the KWs more than $1500 more?
I am looking to end up with a system that I can easily change the damping by pressing a button or using my iPhone that is why I have chosen these two as the final two choices. I want to have a stock, somewhat comfortable setting for when I have passengers as well as a setting that lets me corner as flatly as possible when I'm by myself. I haven't ever tracked a car before, but I'd like to start doing so (although it won't be that often). So this setup is basically for the streets.
Any insight would be very appreciated.
Also, I plan to change the sway bars an end links when I do the coilover install. Any recommendations here as to what brand and model to go with?
Edit: I forgot to mention, I do not have the factory adaptive damping suspension.
