Results 1 to 18 of 18
    Sep 26 2013
    San Jose
    What sort of "jack pad" is used with hydraulic lifts?
    Found a local shop that rents garage space when I was helping a buddy do suspension work. Anyone jacked up the car on a lift before? What sort of attachment/pad/holder is needed? The hydraulic lift is just a flat plate. My buddys BMW had some specific jack pad for hydraulic lifts.
    I found something on ECS for the B5, but nothing for the B8.
    http://www.audizine.com/forum/showth...i-Jack-Pad-Set
    2012 Stronic | Sports Diff Pkg | Chipwerke Pro | aFe Pro Dry | Forgestar F14 18x9 | EBC USR Slotted Rotors | EBC Yellowstuff Pads
    SOLD 2010 B8 A4 Tiptronic | Stasis Engine Tune | Michelin Pilot Super Sports | Forgestar F14 18x9 wheels | Stoptech Powerslot rotors | EBC yellowstuff pads | Bilstein PSS10 - SOLD | aFe Pro Dry Filter
    Me @ Laguna Seca Raceway - https://www.youtube.com/watch?v=z7s8S1Uh7uc
    Sep 09 2010
    Destin, FL
    I used a lift with the flat rubber pads for years without an issue. I use my jack with the flat pad all the time without an issue and I'm pretty sure you're fine. Here's some options if you're not good with that answer.
    https://www.google.com/search?q=lift...ft+pad+adapter
    Veteran Member Four Rings B G 8er's Avatar
    Sep 28 2011
    2011 A4 Quattro Premium 6MT, 2016 VW Golf Sportwagen SEL Gone: 2013 Q5 2.0 Prem.
    Valencia, CA
    This is a really good discussion because i am quite sure the tire shop I go to just jacks them up without any pad with those rolling floor jacks and the place I used to go would jack my cars up by the rear diff!
    Veteran Member Four Rings MacFady's Avatar
    Aug 10 2011
    330i ZHP
    Prince Edward Island
    I just use the pinch weld, where I would with a floor jack.
    Veteran Member Four Rings blbroo's Avatar
    Oct 26 2012
    SQ5, Nissan D21, 435i Gone: K04'd B8 A4, M235i, UrS6, B9 SQ5, D21 Nissan 4X4
    St. Louis, MO
    Quote Originally Posted by MacFady View Post
    +1
    Collector of German things.
    “Whoever said laughter is the best medicine had clearly never tasted scotch.”
    Senior Member Three Rings slacktide's Avatar
    Mar 01 2015
    Seattle WA
    Like so: $15 on eBay. Or cut a slot in a hockey puck.
    Sent from my iPad using Audizine mobile app
    1993 Audi 90 Quattro 2.8 5MT - Sold with 245,000 miles on it.
    2002 Audi A4 Avant Quattro 3.0 6MT - Retired commuter, Dog Car, Costco runner, Snowmobile.
    2014 Audi S4 Quattro Sport Diff 6MT - Daily Driver. CR-15, Chipwerke, minor cosmetic mods. Eventually I'll get around to the audio build.
    Veteran Member Four Rings bluetori's Avatar
    Jan 14 2010
    Discovery 4, RR7, SP Fireblade
    Georgia
    That's what it's for no need for pads.
    Veteran Member Four Rings Dub_prime's Avatar
    Sep 10 2012
    2010 A4, 2008 Passat, 2002 GTI
    Bham AL
    I take about 5 mins and remove the 2 back under trays and jack it up on the actually jack pads from the factory just in front of the rear wheels. In the front I put it on ramps and then jack from the sub-frame, I trust the pinch welds to hold the body panels on, in my opinion they aren't made for repeated use.
    Oct 26 2012
    St. Louis, MO
    Quote Originally Posted by Dub_prime View Post
    I have had mine up on all four pinch welds numerous times. No sign of any bending or issue with them.
    Sep 10 2012
    Bham AL
    Quote Originally Posted by blbroo View Post
    Jacking it by the pinch weld with the standard jack has pulled some paint and undercoating, so I just err on the side of caution and take a bit more time.
    Veteran Member Four Rings Chanman94's Avatar
    Jun 09 2014
    Calgary, AB, Canada
    I'd imagine the pinch welds will get destroyed eventually without a proper jack pad. I always used a hockey puck with a slot in the middle cut out, never thought about what the shops would you use though.
    - Richard
    2017 Audi A4 Allroad - Mythos Black - 034 Dynamic+ Springs - Volk Racing TE37 Ultras
    2021 Lexus NX300 - Ultra White - BBS Evo X Wheels
    2017 Honda Civic Touring - Lunar Silver - Sold
    2018 Volkswagen Golf R - Oryx White Pearl - Sold
    RIP - 2010 Audi A4 - Monza Silver
    - Apparently not resting in peace anymore.
    Oct 26 2012
    St. Louis, MO
    Jacking it by the pinch weld with the standard jack, has pulled some paint and undercoating, so I just err on the side of caution and take a bit more time.
    Good point. I should get the pucks.
    Sep 10 2012
    Bham AL
    If you pull the back under tray sections off there is a solid 3" x 5" or so jack pad built into the frame.
    Apr 08 2012
    South OC, SoCal
    Funny I just bought some hockey pucks at Play it Again Sports. $2 for one. Used of course but it's a hockey puck. Haha
    Your SoCal realtor
    I'm never too busy for your referrals
    Sep 26 2013
    San Jose
    Quote Originally Posted by slacktide View Post
    Yeah i like this pad, will buy an official one. Prefer not to go MacGyver on a hockey puck when my car is 7ft in the air though.
    Quote Originally Posted by The Infiltrator View Post
    What's the "flat rubber pad"? The shop lifts were a flat metal plate, you think they have rubber pieces I can put on them? I'll call and ask.
    Sep 09 2010
    Destin, FL
    Quote Originally Posted by audiAYYY4 View Post
    This is what I meant and my floor jack is about the same. You'll be fine as long as you stay on the jack points. Or you can get the rubber pucks like the other guys mentioned.
    Sep 26 2013
    San Jose
    Thanks! I understand now.
    Dec 30 2014
    Vacationland
    I cut a slot in an old hockey puck.
