    Veteran Member Four Rings elijahallen's Avatar
    Nov 12 2006
    Michigan
    B5 Audi RS4 Avant conversion - No Longer Available
    The car is set up very well and one of the best conversions done to date. Email me if you are interested or know someone who is interested. I will not post a for sale add since I hate seeing people bash what a car like this might or might not be worth so I am taking best offer or I will figure out a way to keep it. Here is a short vid and details of car.
    https://www.youtube.com/watch?v=uk6CS0H8m60Details:
    - 2001 S4 Avant
    - 182,000 miles on the chassis
    - Winter Package
    - Sunroof
    - Convenience Package
    - Bose with 6 Disc Changer and Phat Noise (Changer not installed but included)
    Modifications:
    - Full OEM RS4 Widebody conversion (fully documented with hundreds of pictures)
    - Carbon fiber interior trim by oCarbon
    - RS4 interior black door pulls
    - Black RS4 front and rear Seats
    - OE RS4 headlights with 55watt upgraded lights
    - Clear Bra applied to much of the car
    - Wagner Engineering RS4 IC side grills
    - AWE electric boost gauge
    - 30K miles on built short block engine, stock Mahle pistons, Pauter rods w/ oil rifling, new crank and rod bearings balanced to 9500rpm
    - Built Heads:2.8 heads Fully machined and built in Sept. 2015 with SuperTech springs and titanium retainers, new lifters, stock 2.8 cams, new cam seals, new cam plugs, & 2.7T exhaust valves. Kevlar timing belt just done.
    - Just replaced 605.1Tial turbos with new improved 605.2 turbos (same as 770's but not ball bearing so they will last longer) @ 79K
    - RS4 Y-Pipe
    - Custom 4" MAF pipe and filter with 034 heat shield
    - 72lb Bosch injectors
    - Two ECU's, one tuned to 25psi and one to 28psi, tuned by Mike Shiman
    - 4:1 Center Diff
    - 034 Intake shroud and filter
    - Custom Aux. oil cooler
    - Bosch 044 fuel pump
    - APR bi-pipe
    - ER intercoolers with carbon shrouds
    - 710N diverter valves
    - Dahlback 3" downpipes w/ 100 cell race cats
    - Aquamist water/meth injection system with upgraded 160PSI pump
    - Zeitronix Wideband with boost monitoring/logging
    - Aluminum thermostat housing
    - Red powder coated valve covers and various engine pieces
    - Milltek dual exhaust minus middle muffler
    - Autosport DTS
    - RS4 engine and trans mounts
    - AWE lightweight flywheel w/ Southbend Stage 3 clutch
    - Stasis Ohlin Motorsport coilovers with 800F & 900R springs
    - Hotchkis rear swaybar
    - 355 Alcon front brakes. Rotors replaced at 175K
    - Alcon 298mm rear rotors and brackets
    - Stainless Steel front and rear brake lines
    - ADV.1 10.1 custom forged wheels; 19 X 10 ET20 with matte gunmetal powdercoat
    - 265/30-19 Continental ExtremeContact DW (Approx. 3k miles on wheels and tires)
    List Date: 1/6/2016
    For more info, click here to view the original listing: B5 Audi RS4 Avant conversion
    This item is no longer available.
    Senior Member Two Rings BlingOnMyWrist's Avatar
    Sep 27 2010
    Another 2001.5 S4 Avant
    Naples, FL
    At least post pics so we can ogle at it!
    -AJ
    Pearl White B5 S4 6sp Avant w/ RS6s • Black B7 S4 Avant JHM Stage 2
    Quartz B7 A4 Avant w/ 3P 2.7T 0A3 Swap Project • Silver B5 S4 Avant 01E Swap & RS4 WB Project
    Meteor Grey B8 A4 Avant Facelift 3.0T Swap Project • V10 Touareg Stage 2
    PAST: Laser Red B5 S4 6sp | Stage 2
    photos: flickr
    Jan 06 2008
    Dacia Sandero
    Arizona
    B8.5 []S5 . BBS . H&R . AWE . DEVAL . Stërn . 034 . OEM+
    Veteran Member Four Rings Yuppie's Avatar
    Feb 14 2005
    Houston, TX/ Richmond, VA
    Rob's old car. Very well kept. Good luck with the sale and hopefully it goes to someone that will take care of it.
    2001 S4 Sil Sedan ASP Stage 3-Current
    2001.5 S4 Sil Avant Stage 3 IE Rods, CNC 2.8 heads, BW RS6 Turbos-Current
    2001.5 S4 Casa Sedan Built Motor TiAL 770-Current
    2002 S4 Pearl White Avant Stock--SOLD
    2000 S4 Nogaro Sedan EPL Stage III--SOLD
    2000 S4 Brilliant Black Sedan MTM Stage III--SOLD
    2001.5 Nogaro Sedan JFonz Tune Franken F21s--SOLD
    2001.5 Nogaro Sedan AWE Stage III--SOLD
    2001 Brilliant Black Sedan S4-K04/Rs6 Hybrid custom tuned Vast--SOLD
    Veteran Member Four Rings nynoah's Avatar
    Jan 16 2006
    01.5 A4 avant Past cars: 95 S6, 85 Golf II VR6, 2 sciroccos, 92 Corrado VR6, 86 Euro BMW 535 Alpina
    LA CA
    Man I love this car. I hope something like this pops up for sale by the summer. I might pick it up.
    2001.5 black on black avant 5spd, EFR 6758, Pag Parts band manifold, Vibrant GESI High flow CAT, 2.0L 06A, IE intake manifold, built AEB head, 1000cc Boosted Euro Tune, bosch 044, Ringer Racing stage 3 hybrid Organic/Cerametalic 240mm clutch, S4 interior upgrade, full S4 brakes front and rear with lines, 17in OZ Racing Ultraleggera, 034 HD suspension arms, Stern soft mounts, mirimoto bixenon etc. http://www.audizine.com/forum/showth...s-Build-thread
