Results 1 to 17 of 17
    Veteran Member Four Rings Fobia's Avatar
    Oct 04 2005
    Minnesota
    Playing in the snow and DSG
    I have only owned manuals so this DSG thing is new to me. I have wondered if manual mode is to harsh on the transmission/computer?
    is it hard on the transmission? i would like to keep this car for a while. Also is there no way to turn the traction control completely off in the new models?
    Thanks
    2010 ibis white s4
    CTS Turbo intake
    Veteran Member Four Rings Johnnycash's Avatar
    Jul 31 2014
    2015 Hyundai Genesis. 1995 impala ss
    Mpls, Mn.
    im kind of confused as to what you are asking?
    dsg = direct shift gearbox, dct= dual clutch transmission
    there is no way to turn off the dsg unless you are referring to manual mode, and if that is your concern then just keep it in auto mode.
    2011 QGM w/black optics, EPL stg1, HRE p43sc w/pss, b-12pro-kit, 034 trans mount, cts intake, stoptech drilled/slotted, akebonos all around, vmr 710 w/nokian r2s, stock rotor wheels w michelin as3+, autostyle custom floormats, 3m paint protection on entire front.
    Oct 04 2005
    Minnesota
    Quote Originally Posted by Johnnycash View Post
    sorry i meant traction control
    2010 ibis white s4
    CTS Turbo intake
    Feb 02 2014
    Focus RS, Audi S4 & S5
    Knoxville, TN
    The DSGs seem to have more reported problems when they are used/subjected to high temps or high temp situation rather than being driven in manual mode for general use. Clearly tracking a DSG has the potential for higher temps but many of the failures have been normal users that had lots of stop and go commutes especially when combined with summer heat or very high ambient conditions. Part of the stop and go related failures (per an Audi tech) is that some people want to drive it like it has a torque converter...simply creeping forward using the brake. Unfortunately these are NOT conventional automatic transmissions and when driven that way the clutch is being continually slipped...heating up the fluids and creating DSG overheating. Simply driving in manual or sport mode is not the likely cause of DSG demise, but inducing high transmission/fluid temps certainly is a/the major factor.
    Veteran Member Three Rings Trent212's Avatar
    Sep 10 2015
    AL
    Well if you turn it all the way off, fun times will be had FOR SURE, but it does get a bit squirrely.
    2018 TT RS - Nogaro Blue | CF Inlays | Black Optic | Design Selection Interior | Red Calipers | Technology Package
    APR E85, Intercooler, Inlet, And intake
    TVS Stage 3 TCU tune
    SRM TB Inlet
    SRM GTX3582
    SRM/Eurocode fuel system
    Veteran Member Four Rings schirm's Avatar
    Apr 23 2009
    1999 bmw z3coup M with 5,000 miles Mint
    Forked River nj
    Quote Originally Posted by Fobia View Post
    Hold the traction button for 5 seconds instead of just pressing it until the second message shows on the screen.
    2004 A4 1.8t | Avant | 6MT | Stock | Atlas gray |
    2010 S4 | Ice Silver Metallic | Sport Diff | 6 speed | 19 5-Tri-Spoke Wheels | Audi Drive Select | B&O | Silver/Black Nappa Sport Seats | Navigation Pkg | Brushed Aluminum Trim | APR Stage 2+ | Hoen Xenonmatch Fogs | 034 Motor mounts | Roc Euro | black RS4 Grille |
    Past
    2007 A4 | Revo Sg 2+
    2005 Subaru Legacy GT 365WHP
    Sep 10 2015
    AL
    Quote Originally Posted by schirm View Post
    +1 and smile and hold onto your butts!
    SRM TB Inlet
    SRM GTX3582
    Jul 31 2014
    Mpls, Mn.
    i dont think there is much you can throw at these cars that they arent designed to take, with that said some people are easier on their cars and some drive them really hard, if something breaks just know that its probably gonna be an expensive repair, but thats no reason to drive the car like a grandma does, german cars are built for the autobahn...
    Veteran Member Four Rings The Fat Kid's Avatar
    Mar 10 2015
    New England
    Quote Originally Posted by Trent212 View Post
    Steer with your knee?
    Apr 23 2009
    Forked River nj
    ^this I drive the shit out of my car and it takes every single beating like a champ. I do not have DSG but I wouldn't worry if I did.
    Past
    Oct 04 2005
    Minnesota
    Sorry guys i baby my car. :( but when it comes to play time it's on! i feel like it's ok for me to do it then because i baby it so much otherwise ;)
    2010 ibis white s4
    CTS Turbo intake
    Veteran Member Four Rings TexasDfwS4's Avatar
    Sep 10 2012
    DFW
    You said traction control.
    2018 S6 Glaser white Black/Optics, Sport, ACC, HUD, CF, etc. NO bang/O
    2017 Q5 3.0 Ibis W/ BO with S-line
    Gone 2018 SQ5
    Gone 2013 B8.5 S4
    Gone 2012 S4
    Gone 2012 Q5
    Gone 2009 Q5
    Sep 10 2015
    AL
    Quote Originally Posted by The Fat Kid View Post
    Only when i have to!
    SRM TB Inlet
    SRM GTX3582
    Mar 21 2015
    Quote Originally Posted by TexasDfwS4 View Post
    He did an edit
    Veteran Member Three Rings hotleadsingergu's Avatar
    Jun 18 2015
    Cleveland
    No need for babying lol take care of it, but the car can handle some abuse. It's not the hard driving that causes problems with the DSG, it's not understanding how a DSG works. Shifting it in manual mode very often reduces the risk of messing up the clutches/transmission, since you're preparing for your driving style better than the computer would (so you'll more-rarely end up coming up to a turn and slipping the clutch heavily because the RPMs are too low for the gear). That and, like someone else said, don't just let off the brake and let the car creepy constantly.
    Veteran Member Four Rings amz's Avatar
    Apr 29 2013
    Ottawa
    Lets clarify two things:
    Traction Control: stops wheel spin.
    Stability Control: keeps the car going in the direction of the steering wheel.
    When you push the traction control button, it will turn traction control off, allowing for a lot of wheel spin...but stability control is still on. If you hold the button for 5s, it will then turn stability control off, allowing you to countersteer and slide around (well, as much as Quattro will let you slide around) For having fun in the streets and playing on the track, turn traction control off but leave stability control on unless you really know what you're doing. For playing in the snow or sliding around in the rain, you'll want to also turn stability control off for good slides.
    2012 S4 ~ Phantom Black - Mustang Brown - B&O - Sport Diff - DSG
    AWE Touring Exhaust | Roc Euro Intake | Eurocode Alu-Kruez | Eurocode USS Swaybars & Solid End Links
    Canada: the land of Quattro
    May 10 2012
    2013 s4, 2008 cbr1000rr
    United States
    Care free snow fun: Do your recommended maintenance. Put it in sport, traction control off-off, drive it like you stole it, repeat.
