Results 1 to 7 of 7
Thread: Bad Starter?
    Active Member One Ring Black Fox's Avatar
    Dec 22 2014
    2009 Ford F-150 Platinum, 2004 Harley Davidson 1200C Sportster
    Savannah, GA
    Bad Starter?
    What's up guys,
    I'm having a starting issue with my Audi (1.8T 5sp quattro). I turn the key on, and all the lights and radio turn on, but when I try to start it, I only hear one click and then silence. This happens every time. I was able to push start it, drove it for 30 min, but the same thing happened next time I tried to start it. I want to say it's not a battery issue, and that it's probably a starter issue, but wanted to see what y'all thought first. Thanks for the help! (and i tried pumping the clutch too, but that didn't seem to work either..)
    Ray
    Apr 07 2011
    Check all of your connections between the battery and starter. That was my problem when my car was acting the same.
    Here's my thread. Click
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Yeah, bad connection is my first guess, probably at the battery. Or the battery could be bad too.
    You can try hitting the starter (note-starter, NOT the solenoid) with a hammer LIGHTLY to see it it helps. If it does, you have a bad starter.
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Senior Member Three Rings Cousinphil's Avatar
    Jan 29 2015
    1954 Ford Jubilee Tractor,1986 Ford Diesel Tractor, 2006 GMC One Ton Dump, 1986 Nissan Flatbed Truck
    East Blue Hill Maine
    Sounds like weak battery connections to me. Take off the cables and clean everything with a wire brush. But if it's an old battery that may not help. I get five years out of a battery. Once I got seven. The cold weather definitely brings out any weakness in a battery.
    2004 A4 Avant 1.8T 6 Speed 120,000 miles Summer
    2005 A4 Avant 3.0 Tiptronic 80,000 miles Spring and Fall
    2005 A4 Avant 1.8T Tiptronic 105,000 miles Winter Tires
    Dec 22 2014
    Savannah, GA
    Thanks for the tips guys. I hooked up a battery charger and let it charge to 100%, then tried to start it with the charger still connected, and got the same results. Same thing when I try to jump it off another vehicle. Battery terminals are tight and clean. Also tried tapping the starter with a hammer...nothing. Next thing I'll check are all the connections between the battery and starter.
    Veteran Member Three Rings Let it snow's Avatar
    Aug 24 2014
    02 1.8TQ Sport 5 speed, 05 1.8TQ 6 speed
    Vermont
    If you can check for voltage on the smaller gauge wire on the starter. With the ignition switch turned to start and clutch engaged you should have battery voltage. If you do that eliminates the ignition/clutch switch circuit.
    Veteran Member Four Rings DiertyEuroSpec's Avatar
    Aug 21 2009
    Fairfield County, CT
    Starter issue. Most likely its the cable corroding that runs from solenoid into the starter. That was the issue on my parts car.
    Sent from my LGL33L using Tapatalk
    2003 A4 1.8T Quattro | 18" BBS CH | KW V3 | FT F21 Mixed Flow | MOTOZA | RA4 Stage 1 w/SMFW | Milltek | Uni HFC/3'' DP Combo | 3'' TIP w/MAF | 550cc | TR1.8 FMIC | USP F/R | H-Sport F/R Sway | APR Snub | RS4 Motor Mounts | Stern Trans Mount | Skid Plate | Solid Tie Rod Ends | Short Shifter | Euro Shift Knob | VMR Boost Gauge | S4 F/R Brakes | Tyrolsport Stiffening Kit | ECS S.S. Lines | Hawk HPS Pads | 034 PCV
