    Nov 01 2012
    1993 Mazda Rx-7
    San Antonio, Texas
    20x10 et 33 or close PIC REQUEST
    As the title said.. i'm wondering if anyone is running this size or anything close to this size on their A6/S6... i have an S6 with is suppose to have +14mm wider fender than the A6. I appreciate it! I'm debating on running with this setup and dropping the car or waiting for the right type of rim and tire combo.
    I've done the math, and i'd run at 255/30/20 on them. to reduce the diameter and make it as close as possible. I just dont have the measurements for the fender,wheel well clearance on the car.
    Veteran Member Three Rings AndreNY's Avatar
    Apr 06 2005
    Boston MA
    on my old S6 I ran 20x10 all around 255/30 and it fit like a glove front and back ET35
    Apr 21 2005
    Alpharetta, GA
    I'm running 20x10 et20 on the regular A6 fenders, but with 235/30/20, so while it will be an aggressive setup, you should be fine. 255 may be a little tight depending on how low you want to go.
    Here is a picture at ride height, they camber in some when airred out:
    Instagram: @riegeltheaters
    2001.5 VW Passat 1.8T | Rest in Pieces
    2002 Audi allroad 2.7T | Sold
    2010 Audi Q5 3.2 S-Line | Sold
    2006 Audi A6 4.2 S-Line | Sold
    2007 Audi A3 3.2 S-Line | Sold
    2008 Audi RS4 | Current
    2008 Mercedes G55 AMG | Current
    Active Member Two Rings JUICE A6's Avatar
    Mar 04 2015
    DETROIT MI
    I like the stance of your car
    Sent from my LGMS395 using Tapatalk
    AKA mccoy540i
    Apr 20 2012
    2004 Audi S4 Avant RIP 1995 Mercedes E320 Wagon 1958 Mercedes 180D
    Winnipeg, MB Canada
    I've got 255/35/20 on 20x10et35 on stock S6 suspension. light rubbing in back on big dips... but otherwise no issues. would recommend 255/30 tho.
    Current
    C6 S6 Phantom Black Pearl
    Milltek Cat Back
    Airlift Performance Struts
    Accuair Elevel w/ Ilevel
    JHM Tune
    JHM Intake Spacers
    Ispiri CSR1D Wheels
