Results 1 to 28 of 28
    Active Member Four Rings aysix's Avatar
    Feb 06 2012
    Las Vegas
    Some SRM RS4+ Logs
    Logs taken at around 2500ft altitude
    SRM IC's
    SRM RS4+
    550cc EV14 Injectors
    034 85mm MAF maxed out
    91 oct
    I hit 24 psi by 3300rpm but the car performed better running the boost more on a conservative side with the fuel used.
    Then with some tuning...
    Mar 22 2013
    AK
    Are you doing the tuning?
    Jun 14 2007
    2000 S4
    Connecticut
    What does the acceleration graph look like, sir?
    Veteran Member Three Rings gmdiluca's Avatar
    Mar 29 2013
    Ontario, Canada
    opinions compared to your K24 setup you had Dan, or it too early?
    Veteran Member Four Rings ianwpb's Avatar
    Dec 11 2010
    16 S3, 16 Q5 3.0t
    West Palm/ South Florida
    Subscribed...
    Interested in seeing some FATS runs.
    What was the ambient temperature give or take?
    '16 Q5 3.0t S-line Daytona Grey Pearl, Black Optics, APR stage 1, Magnaflow exhaust (Looking for stock exhaust)
    '16 S3 Misano Red Pearl, Black Optics
    Gone -
    '13 Q5 2.0T Premium Plus
    '13 BMW 135Is 6MT Coupe - #387/586
    '01 S4 6MT - SRM K24's, Stock Block, E85 448/392 Mustang Dyno
    '12 A3 TDI Premium Plus
    '10 A3 Premium
    '99 A4 2.8 5MT
    Mar 07 2013
    2015 Mercedes GLK350
    Rancho Cucamonga, CA
    Subscribed too
    2008 Ibis RS4....GETing tuned
    Feb 06 2012
    Las Vegas
    I didn't really have a completely flat place to log it. It did around 3.8~ fats all set and done where i was doing it. I reckon with good fuel it would be low 3 second fats. Ambient temp were about 60 deg, but as you can see it was a bit heat soaked. These turbos are great for a stock motor.
    Jun 14 2007
    2000 S4
    Connecticut
    Find a flat spot I'd be curious to see how the accel holds beyond 4.5-5k compared to K04s.
    I thought you had the larger turbos? Did you change it up?
    Feb 06 2012
    Las Vegas
    This isn't my car. I'm going to be doing the full frame k24+'s.
    Dec 11 2010
    16 S3, 16 Q5 3.0t
    Quote Originally Posted by aysix View Post
    I'm considering scrapping my idea of doing rods for my k24 set up and just throwing a set of these on and enjoying the near instant boost. Hmm...
    Gone -
    '10 A3 Premium
    '99 A4 2.8 5MT
    Veteran Member Four Rings FlyboyS4's Avatar
    Jan 06 2007
    Mk7 Golf R
    FL
    Quote Originally Posted by ianwpb View Post
    I guess it depends on what you consider 'near' instant.
    Jun 14 2007
    2000 S4
    Connecticut
    Quote Originally Posted by FlyboyS4 View Post
    Do you get giddy when you see the chance to argue semantics with someone?
    Veteran Member Four Rings jaychen's Avatar
    Feb 19 2011
    Earth
    ive come to realise, while jeff is knowledgeable and does a lot for the community, he seems to just come off as a fuckwit, 99% of the time.
    2000 Achat S4
    Account Terminated Two Rings
    May 18 2014
    Tucson Arizona
    Jan 06 2007
    Mk7 Golf R
    FL
    Quote Originally Posted by jaychen View Post
    99%? No way.
    Nov 02 2014
    06 9-3 Aero 2.8T, 96 Miata
    Winchester, VA
    Going to need to see some data to back up that claim.
    No issues here with Flyboy. He holds people to a higher standard, and it does a good job of weeding out bunk information. For that, I'm thankful.
    Dec 11 2010
    16 S3, 16 Q5 3.0t
    Sorry to have been so vague. I'd like something that spools quicker...
    Lol - I think most people understood what I was getting at. It was implied that I would like something that spools quicker than my K24's.
    Gone -
    '10 A3 Premium
    '99 A4 2.8 5MT
    Jan 06 2007
    Mk7 Golf R
    FL
    I think between the F21 and RS4+ it's about a wash in that department, given the limited info I've seen on the SRM product.
    A point that was made to me by one vendor is that the turbo market is somewhat limited in what to put into the RS4 units. I've lowered my hopes about seeing significantly different results between any of the offerings that stick with the RS4 K04 housing. Unless someone tries a K04 center with BB I doubt anything in the K04 housing will spool faster than the pjK04's.
    Registered User Four Rings Doug@FrankenTurbo's Avatar
    Oct 19 2009
    Gary Fisher Sugar 2+, Trek HiFi 29er
    Portlandish
    One of our suppliers has offered a ball bearing variant for use with our turbos but I balked at the loss of stock fitment. But if you're simply that hung up on improving upon our already-fast MF21s, I could look into that for you, Jeff.
    Jan 06 2007
    Mk7 Golf R
    FL
    Quote Originally Posted by Doug@FrankenTurbo View Post
    I'd be interest to hear more about that. Describing me as 'hung up' gives the impression there is no significant difference between a K04 hybrid like the F21 and a pjK04. From what I have observed the difference down low can be an extra 50-100 lb-ft with a k04 (over a limited rpm range), and to me that makes a tangible difference to how the car feels.
    Veteran Member Three Rings slow ride's Avatar
    Apr 20 2005
    New Hartford, IA
    The biggest problem with comparing any of this stuff is the variables in data are a mess. Different car, dyno, road, weather, start of pull, tuning, fuel, hardware, etc etc the results end up so skewed. Not sure if a BB would make a huge difference in these small turbos, but a bb with light wheel/shaft weight and blade pitch could improve things I think. So could it be done, probably, but at what price point and would they sell enough to justify even messing with it.
    00' Laser red S4 RS6 hybrids e85
    02' Corvette ZO6 383 TT 1012whp 990wtq
    02' Tundra
    SOLD 93' AWD Talon 523whp 486wtq
    Veteran Member Four Rings NOTORIOUS VR's Avatar
    Jan 29 2009
    No the biggest problem is that people still think that bigger then K04 turbos are laggy... They're not. No matter how much data that people want to "read" over. Just because you can hit 20 psi sooner on dinky turbos doesn't mean the car is quicker.
    Oct 19 2009
    Portlandish
    Quote Originally Posted by slow ride View Post
    Well put. In fact the most rigorous testing work we did for the MixedFlow design was done on a 20v 1.8T engine. In that case we were able to control test conditions. But I'm hesitant to post such details here in a thread that the OP intended as a promotion for his own competing product.
    Veteran Member Three Rings hotshot32890's Avatar
    Dec 05 2009
    2008 VW Passat. 2000 Audi S4
    Boston, MA
    3.8 fats??Most K04 cars do better...My K04 hybrids did 3.2
    Current:
    IN THE MARKET
    Previous:
    F21 Brilliant black b5s4
    SRM K24 silver b5s4
    Black B5S4: Eurojet Grenade DVs, AWE Twin1
    Eclipse GSX: 16G turbo
    Feb 06 2012
    Las Vegas
    Quote Originally Posted by hotshot32890 View Post
    Yeah, on 93 at sea level.
    Jan 06 2007
    Mk7 Golf R
    FL
    To take that further, failure to adequately control the variables can lead to results that aren't good for making comparisons. The variables you list can be controlled, some more than others, though that seldom seems to be the case with comparison data presented on this forum. More samples will also help to reduce uncertainty with the results.
    Veteran Member Three Rings hazard860's Avatar
    Aug 22 2011
    1984 gti, 2001.5 s4 (stg3)
    Lebanon, CT
    comment for the sake of comment
    Stage 3 2001.5 on E tuned by DynamicEuro
    Established Member Two Rings bruddha's Avatar
    Apr 20 2012
    Tulsa/Ok/USA
    Revisiting. There should be more info out on these by now? Who's got em?
