Hello:
I have an issue with the heat coming out of the vents that's seems to be not hot enough even though I turn the temps all the way up. Here's the detail:
Engine warm up. If I keep the engine revving while stopped or the car is being driven, the heat from the vent is hotter. If I just let it idle, I can almost immediately feel the air coming from the vent to be cooler and not as warm. Could this be an issue with the water pump not spinning fast enough to recirculate the water through the heater core? Could the heater core somewhat have a blockage?
I have already done the how-to unclog heater core twice and each time right after the process, the air blows very hot which is what i want . But after a while, the air from the vent is not as hot as it was initially when unclogged.
I'm stuck and not sure on what to do to get a constant hot air from the vent when I turn up the heat. Please help as it's getting very very cold here in the Northeast!
