I read theres a way to check if you have fuel pressure without a gauge, my pump died and just wanted to double check. If i press the schrader valve, how fast should the fuel spray out?
If it is the pump does anyone have any other suggestions for a drop in other then the 034 040 fuel pump for more flow?
I checked the relay and its fine.
Edit: double checked relay, it's fine. Jumped the connections of the relay and I hear the fuel pump running. I'm guessing it's cam/crank sensor for the no starting condition.
