Results 1 to 11 of 11
    Sep 17 2015
    Halifax NS
    B8 S4 winter tire fitment question...
    Hey all! Just have a quick question so hoping someone can help me out. I have a 2012 S4 that uses the stock 19 inch peeler wheel setup. Well I'm getting winter tires for my car and thought about going down to 18 inch for winter. Anyways I found 18 inch wheels that have a ET measurement of 35. The peelers are 47 ET. I'm wondering if these will fit with no problem or will I need spacers? Thank you for any help.
    Veteran Member Four Rings zcspec's Avatar
    Aug 10 2015
    Need VAG-COM work, IM me
    Orange County
    The lower ET you go, the FURTHER out from the car, your rim will be. The setup in question is 12mm more "aggressive" and from what I've read with other A4/S4 owners, you'll be fine with the ET35. On a side note, I would go with a narrow tire so that it "CUTS" through snow better because you do not want a wider tire width in deep snow.
    Oct 14 2012
    Empty...for now...
    SE PA
    Quote Originally Posted by CraZcane View Post
    What is the width of the 18" et35 wheel? My winter setup is 18x8 et35 with 245/40-18 tires (Michelin Alpin PA4). There is no tire rubbing with this fitment, and I am lower than stock ride height:
    This season I added 5mm spacers front and rear and still have no rubbing (but the photo above is without spacers). BTW the stock peelers are 19x8.5 et 43, not et 47.
    SOLD 2015 Daytona Gray S4
    Veteran Member Three Rings mjr034's Avatar
    Jul 07 2014
    2015 Mazda 3i GT
    Michigan
    I have 18in wheels for sale made specifically by Audi as one of their winter wheel packages for the S4. If you'e interested, shoot me a PM.
    2013 S5 3.0 TFSI ~ Prestige | DSG | Brilliant Black | Carbon Atlas
    | 034 | APR | AWE | BBS | BFI | BILSTEIN | ECS | VORSTEINER |
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    They will be fine! I got 18x9 et35 on stock height. Looks great, no rubbing.
    2021 Audi S4, P34 Intake
    Veteran Member Four Rings AWDLover's Avatar
    Feb 07 2012
    For winter I ran 18x8 et35, 5mm spacer in the rear, and 245/40/18. Slightly lowered and no issues
    2010 A4 Quartz Grey (click) | APR | Eurocode | GFB | 034 Motorsports | Eibach | H&R | VMR | P3Cars | aFe
    Sep 17 2015
    Halifax NS
    Thanks for all the responses guys, helped a ton. :)
    I knew I shouldn't have trusted my dealership when they told me the ET for peelers was 47 lol
    mjr, I appreciate the offer and I will definitely look into that once I know the total cost of the wheels/tires I'm looking at.
    Jul 07 2014
    2015 Mazda 3i GT
    Michigan
    sounds good! let me know.
    Mar 25 2015
    Calgary
    This winter I bought a set of VMR V810's, in 18x8 et 45. I considered the et35, but I wanted to keep as much of the tire within the wheel well to prevent chipping the side of the car with all the gravel.
    Sep 17 2015
    Halifax NS
    Hey guys, just another quick question...
    I picked these wheels out, http://www.1010tires.com/Wheels/DAI+...R3718814104066
    As you can see, the ET for these wheels is 40mm and the hub bore is 66.50 (the b8 s4 has a hub bore of 66.6 IIRC)
    My question is this, will the slight discrepancy in the hub bore matter? Also will 40 ET cause rubbing on 225/40/18 tires?
    Thank again for your help :)
    Veteran Member Three Rings Tweakophyte's Avatar
    Feb 15 2012
    Boulder, CO
    The ET on the stock 18" wheels actually is ET47.
    See post #5 here:
    I went with ET45 (vs the ET35) for the winter wheels I (finally) just put on the car. My logic was simply that slightly-in would spray less snow-crud than slightly-out. Of course, that was after much toil and bench-racing via the forum.
    MY12 Ibis, Titanium, 6MT, Sport Diff, Leather, Prestige : 35% tint, AK, SC Badges... CPO (kind of a mod)
    RSNav (S4), CR15
