I've been searching around looking for ideas on a higher sitting stance. I'm planning on towing my sleds with my avant. I use the term lifted loosely. I wouldn't mind a inch or 2 over stock but stock height would be fine. Here is my issue, stock springs are weak. I'd like something with stronger spring rate. The issue is the Oem rear spring is 1.5in opening. Good aftermarket options are 2.5. I could use a aftermarket spring with a upper threaded mount for Coilovers but what to do for the lower mount? Do you think the spring would stay put on a Oem lower? Any ideas or brainstorming is welcome!
Also at this point I'm stuck with this car so no I'm not trading in for a truck!
Sent from my HTC6525LVW using Tapatalk
