Results 1 to 9 of 9
    Senior Member Two Rings Phray's Avatar
    Oct 19 2014
    2011 S-Line A3
    Sunroof Sluggish and Stuck Open
    So I opened my sunroof last night, opened extremely sluggishly, and took approximately 30 seconds to a minute to fully open and then close. This morning I tested it to see if it had fixed itself- no luck, and of course it's 10 degrees outside. Currently the sunroof is stuck open a few inches and will either move extremely slowly, or won't budge at all. The dial for each setting also won't work properly (ie: when I set it to setting 2, it will open equivalent to 4, when on closed, it will open equivalent to 2, or something along those lines). Is there any way to close it manually? What else can I try?
    2009 A4 Avant Premium+ 2.0T Quattro
    | APR Stage 2 + R8 Coil Packs + Spullen HFC + AWE DP + AWE Touring Dual Exit (Black Tips) | Rebuilt Engine | Bilstein B12 Pro-Kit | VMR v701 19x9.5 | RS4 Grilles + RS4 Spoiler + Carbon Lip | Tint: 35% Sides + 20% Rear |
    Sep 09 2010
    Destin, FL
    Quote Originally Posted by Phray View Post
    The cold does some crazy things to cars. I've had some odd things happen when those temps drop. I would put the car in the garage, get it warm and see if that works and then keep it closed. If it doesn't, the motor might be giving out or the tracks need to be cleaned and greased.
    Veteran Member Three Rings kdaffy's Avatar
    Apr 17 2014
    MA
    this happens to me intermittantly - curious to hear what people have to say.
    I've found that cleaning the tracks helps a lot with this issue, and also providing a little elbow grease as it closes
    Veteran Member Four Rings JeriQo's Avatar
    Jul 08 2015
    WD-40 should fix your problem
    2012 BB A4 P+ S-line Exterior |FBSW RS Paddles/Pedals|CR-15|AFE Filter|ECS inlet|S4 Dual Exhaust|Ace Convex 19x8.5|ECS 10mm rear|Solowerks S1
    Dec 14 2011
    Chagrin Falls, Ohio
    B7 has emergency manual operation. Don't know about B8. What does the owner's manual say?
    Senior Member Two Rings Demringstho864's Avatar
    Sep 26 2015
    Syracuse NY
    there is you have to open the sunglasses holder, and there is a manual crank iirc
    2009 A4 2.0T Quattro Premium Plus
    Static dropped on 20s, lots of bolt ons, and some appearance stuff
    Oct 19 2014
    2011 S-Line A3
    Quote Originally Posted by Silveravant View Post
    Don't have an owner's manual. I got it fixed by lubricating it a little and using some elbow grease like those above said. Not opening it again, even if to test, until Summer. Lesson learned haha
    Jul 08 2015
    you gotta keep opening and closing that til it gets lubed up nice and good.
    think plowing your girl, the more in and out sliding action, the better it gets
    you cant let that roof go virgin again.
    Veteran Member Four Rings blbroo's Avatar
    Oct 26 2012
    SQ5, Nissan D21, 435i Gone: K04'd B8 A4, M235i, UrS6, B9 SQ5, D21 Nissan 4X4
    St. Louis, MO
    Collector of German things.
    “Whoever said laughter is the best medicine had clearly never tasted scotch.”
