Results 1 to 33 of 33
    Mar 29 2012
    SF
    Forge DV spacer won't fit
    Here's my DV spacer. It won't fit my stock DV which is a surprise because I never saw any indication on the Forge website or UROtuning that there could be any fitment issues. After some research I've found that this is the DV I have. It's the later model piston design part
    So what's going on? It says on the website that the DV spacer fits my stock DV. Is that meant for the earlier model with the rubber diaphragm? Is there a different DV spacer that will fit my DV?
    Veteran Member Four Rings Denio24's Avatar
    Jan 24 2013
    Chicago
    How is it not fitting properly?
    Garage: 2008 Quartz Gray Audi A4Q 6MT
    Tuning: JHM Tuned Stage 2 93 Octane w/ IE HPFP
    Mar 29 2012
    SF
    It doesn't seat flushed against the DV and there's space in between. The only way to make it fit is to remove the outer cone of the DV. But that definitely doesn't seem right. So I had my mechanic take out the spacer.
    Veteran Member Three Rings ignus99's Avatar
    Nov 08 2009
    Calgary/Alberta/Canada
    I wouldn't recommend using the spacer either way.
    I don't have proof, nor can I say 100% for sure, but I am confident that my forge DV spacer was one of the culprits of my turbo damage from years ago. Improper air movement prevented the turbo from operating correctly and caused an oil leak between the bearings.
    Not saying it will happen, just a friendly FYI.
    - Karl
    Engine: GT28RS by ATP / Turbosmart 38mm dual BOV/Recirc / Carbonio CAI / APR TBE / APR Testpipe / REVO St2+ / Snow Performance ST2 / APR HPFP
    Body/Suspension: KW V2 / DPE ST-10 19x8.5 et35 / Thor Skid Plate
    Pretty Stuff: AWE Vent Boost Gauge / OEM Bixenon + V4 LED / Supertones / Votex SS / CF Hood & Mirrors / RS4 Grille & Fogs
    Junior Member Two Rings
    Oct 29 2015
    Central Florida
    This happened with my gli....I used shorter bolts
    Sent from my 0PJA2 using Tapatalk
    Mar 31 2013
    San Diego
    garbage. dont bother.
    Jun 17 2013
    jersey city nj
    Quote Originally Posted by slappomatt View Post
    Exactly
    Veteran Member Four Rings i3oricua's Avatar
    Sep 17 2006
    2022 Kia Sorento; 2015 Ducati Monster 821 Dark
    Aurora, Colorado
    Quote Originally Posted by inked_up415 View Post
    If you want the sound I say do it. I had this same spacer but I don't think my bolts were that long. Anyways, should bolt right in with no problems, although I had the old DV not this new one.
    Mar 29 2012
    SF
    Is it wrong to enjoy the sound a turbo makes? I could achieve it also by doing an intake but those are overpriced for minimal performance gains. This is just a cheap way to hear your turbo purge I don't see anything wrong with that.
    Veteran Member Four Rings Schweini's Avatar
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    The DV effects the car in a negative way. Its not wrong to enjoy the sound, but at what cost?
    Also, I made my intake for a fraction of the cost of that Forge spacer. You just need a 90 pipe and a cone filter. If you wanna be even cheaper, re-use the black turbo intake pipe thats already there and slap a filter on the end of it.
    2008 A4 S-line 2.0T
    JHM Stage 2
    Mar 29 2012
    SF
    I'm just gonna use a K&N drop in filter for the stock intake box. And how would the DV affect the car negatively? It came stock on all turbo models. I think your thinking of a BOV.
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    Yes, I meant to say DV Spacer
    2008 A4 S-line 2.0T
    JHM Stage 2
    Mar 01 2011
    Nanuet NY
    What does the Forge DV spacer do?
    Oct 24 2015
    Perth, WA
    If you want the sound, look at the GFB DV+
    My respray thread
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    Quote Originally Posted by reno808 View Post
    Vents metered air to atmosphere,when our cars work on a recirculating system instead
    2008 A4 S-line 2.0T
    JHM Stage 2
    Veteran Member Four Rings klrider44's Avatar
    Aug 20 2014
    Doylestown PA
    Quote Originally Posted by Okedokey View Post
    ^^^^ this does not give you any sound. Take out the stock air box and get a cone filter. That will give you some sound. The spacer will also give you sound, but everyone says it's bad for your turbo. Not sure if that is actually the case, but why risk it. When I had my spacer on it just made a mess with oil because my turbo seals had gone bad (not due to the spacer though)
    Mar 01 2011
    Nanuet NY
    sounds like a gimmick to me. If you don't the recirculating system in place it will cause your tune to do funny things and may cause idle problems. if you want to run atmospheric then you need a tune and proper setup to do. For what 99.9% of the guys run here they wont see any gains but actually make things bad or worse.
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    Its not so much a gimmick, since it works and does what its intended to do. Its just not suitable in our application
    2008 A4 S-line 2.0T
    JHM Stage 2
    Mar 01 2011
    Nanuet NY
    what is it intended to do ? make noise? then i suppose.
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    BOVs have their place in the world, the design and purpose of them isn't gimmicky whatsoever
    2008 A4 S-line 2.0T
    JHM Stage 2
    Nov 08 2009
    Quote Originally Posted by Schweini View Post
    I agree, but if you have a DV and are modifying it to perform like a BOV, then it is gimmicky.
    - Karl
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    Exactly, which just brings me back to my first statement
    "Its not so much a gimmick, since it works and does what its intended to do. Its just not suitable in our application"
    I was just having fun drawing out this conversation as long as I could lol. Im not particularly a fan of telling ppl to search and look it up, even though they should
    2008 A4 S-line 2.0T
    JHM Stage 2
    Oct 24 2015
    Perth, WA
    Quote Originally Posted by klrider44 View Post
    Really, then why when i installed mine i heard a noticeable BOV sound compared to stock?
    My respray thread
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    Not trying to start anything, just found this funny
    2008 A4 S-line 2.0T
    JHM Stage 2
    Senior Member Two Rings Who_vierno's Avatar
    Apr 26 2014
    Funny thing is my friend has the GFB DV+
    on his DV and the the turbo sounds even better. I have a custom
    made intakw, once insinstl the GFB dv+ ill put to the test these myths. also our other friend is running the forge spacer the sounds are almost identical.
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    Theres really no myths here in need of testing. I have the dv+ in my car currently, sounds nothing like a BOV. Ive also had the forge BOV paired with my dv+. Not sure you you guys are getting forge spacer noises from it lol. I too have a custom intake, that will immediately give plenty of audible for anyone wanting more turbo noises without a spacer
    Now, the dv+ certainly does have a tiny whistle to it compared to stock, but its absolutely nothing in comparison to a spacer
    2008 A4 S-line 2.0T
    JHM Stage 2
    Aug 20 2014
    Doylestown PA
    Did you install anything else at the same time. I put on my DV+ amd there was literally no change in sound after install. Then I put the spacer on and there was noise everytime I let off of the throttle
    Oct 24 2015
    Perth, WA
    No, the DV+ was the first install. It definitely increased the 'chirp' sound when coming off the throttle.
    My respray thread
    Apr 26 2014
    are you guys tuned?
    Oct 24 2015
    Perth, WA
    I am
    My respray thread
    Aug 20 2014
    Doylestown PA
    yes I was tuned
    Sep 17 2006
    Aurora, Colorado
    I ran the forge spacer for about 9 years. I got the gfb dv+ a few months ago because I got the JHM tune and had never even upgraded my stock diverter valve. When I changed it out I had no tears and I never once had a problem with my car. That's after owning this exact car in Germany, 100's of autobahn drives, Nurburgring, and beating it up around here in the US in different states and different weather. I'm probably 1 of 6 people (I just made that up) on this forum that has had that thing and enjoyed the sound.
    I say put it in if you want the sound. I never had a problem with it. Doesn't matter what link you provide, I'm still gonna do what I want and you should too.
    Jun 17 2013
    jersey city nj
    Yep, Tuned
