Results 1 to 33 of 33
    Veteran Member Four Rings CJ_'s Avatar
    Oct 27 2014
    Flag/Phx, AZ
    Help me Identify this Clutch/PP!
    Hey all!
    Just pulled this off my motor and need help identifying it. PO claimed it was a new 'RS4 clutch/PP' and I have almost no experience with clutches.
    Also if you could tell me what condition its in, and if its worth running still with my build? SRM k24, limited on stock block.
    2001.5 Silver S4 Avant - 6spd swap + BW K04s (Current)
    2001.5 Santorin S4 Sedan - SRM k24 build (Totaled)
    IG: CJ_s4
    Veteran Member Four Rings erykv1's Avatar
    Jul 01 2014
    'murca
    this is what the rs4 clutch / pp looks like.
    -edit- looks like the single mass flywheel conversion kits you can buy for our cars. take a look at the flywheel and see what it is to verify.
    Veteran Member Three Rings slow ride's Avatar
    Apr 20 2005
    New Hartford, IA
    It's the Valeo single mass flywheel/clutch combo. I don't think it's rated much over stick stuff, but not much posted on them. A more aggressive disk would help a lot, but not sure of the clamp force on that plate.
    Oct 27 2014
    Flag/Phx, AZ
    Yep thats got to be it.. Heres the flywheel:
    Is this flywheel compatible with anything that the stock dual mass flywheel is? Any recommendations for clutches then?
    As the op states, k24s limited on stock block, daily driven, no flat shifting, maybe a launch here and there. Looking for a budget clutch that will hold me over til I can build the block one day.
    Was looking at the projectB5 or cm fx400
    IG: CJ_s4
    Veteran Member Three Rings cinimod25461's Avatar
    Dec 04 2013
    CA
    An rs4 clutch is probably the most budget friendly over stock, but I've heard of them not lasting very long, even on k04 cars. I'm loving my AMD setup so far.
    Jun 08 2014
    Vancouver, Washington
    Quote Originally Posted by cinimod25461 View Post
    AMD stage 3 and TTV lightweight flywheel right is what youre running right? Hopefully it holds up with those RS6's ;)
    Dec 04 2013
    CA
    Quote Originally Posted by MarlinFoundNemo View Post
    Yezzir! So far so good.
    Jun 08 2014
    Driven with the clutch in traffic yet? Planning to do a near identical build some day.. only questionable thing is the clutch because theres lots of traffic over here.
    Dec 04 2013
    CA
    I daily my car and have driven it in traffic. A little trickier/grabbier than stock but not to the point where it's a PITA. Are you going to do a 6 speed swap?
    Veteran Member Three Rings Corradovolksb's Avatar
    Aug 29 2013
    2018 VW Atlas
    Phoenix AZ
    Bummer it's not an rs4 but it wouldn't hold the k24 power even if it was. I'm running the southbend stage 3 daily with stock flywheel and it's been great so far. It starts slipping around 500tq so it will hold enough for k24s and stock block.
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    I havent played with one of those fw, but look at it very closely.
    It looks like the dowels are def different and it doesnt have the windows in the step to clear an oem style pp.
    Other things to look at:
    Step height the same?
    Is the whole thing offset more to make up for a thinner pp?
    That thing really could go either way and I wouldnt recommend getting creative unless you really know wtf you are doing.
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
    Jun 08 2014
    Yeah thats on the top of my to-do list right now for the car. I'll likely rebuild the K03's though when I swap since being a HS senior an RS6 build is a pipe dream haha
    Oct 27 2014
    Flag/Phx, AZ
    So I wouldnt be able to just throw in a new clutch disk with that flywheel and pp?
    IG: CJ_s4
    Dec 04 2013
    CA
    Haha I feel it. I'm a college student with a part time job. What I do is save up money and then end up spending most of it on car parts lol. Can't wait to see you start your build.
    Quote Originally Posted by CJ_ View Post
    I'd imagine you could throw a new disk in, as long as it's the same as what was in there before. Like @zillarob said, mixing and matching clutch setups would be risky unless you know what you're doing. What is your clutch/flywheel budget?
    Oct 27 2014
    Flag/Phx, AZ
    The AMD stage 3 is a 8 puck right? Do they work with stock flywheel?
    Quote Originally Posted by Corradovolksb View Post
    Yeah at this point I'm kind of wishing I had a stock flywheel. I guess we'll see how this one plays out.
    IG: CJ_s4
    Dec 04 2013
    CA
    Yes and yes. From what I understand, AMD modifies the pp to work with any flywheel. I'm using mine with a TTV flywheel and there are also guys using it with a stock flywheel.
    Oct 27 2014
    Flag/Phx, AZ
    Im in the same boat lol, Ive got one more year of college. Most of the money for my build came from my summer job.
    I don't really have a budget for a clutch setup, but was hoping to pick up a clutch/pp in the $6-800 range.
    IG: CJ_s4
    Oct 27 2014
    Flag/Phx, AZ
    Hmm.. I wonder if the amd setup would work with this flywheel
    IG: CJ_s4
    Dec 04 2013
    CA
    Haha nice. I actually go to a community college near me and my plan is to transfer to a 4-year in the fall. Can't remember off the top of my head what's out there for $600-800. I think you can get the AMD stage 1 or 2 for under $800; stage 3 and up will be around $860 shipped.
    Apr 04 2015
    B5 S4, 92' SC300', 84 Cressida
    Valeo made the kit so that you only can run valeo discs and plates, and they have a specific replacement part number too I believe.
    01 B5 S4
    Autospeed DTS, Forge DVs, APR BiPipe, APR Snub mount, Stasis/Alcon Mono4 355mm BBK, Unknown Short Shifter, Blitz TT, NefMoto Stage2, SSAC v2, TTV Steel FW, CM FX300
    16 A3 e-Tron
    Stock for now
    Nov 16 2010
    WetSide, WA
    It wouldnt really be a bolt on deal because of the dowels, and maybe the other things I mentioned.
    My guess is it could be made to work pretty easily though.
    Veteran Member Four Rings f4m0u5's Avatar
    Aug 04 2014
    Gloucester MA USA
    When i bought my s4 the clutch was fine till i qent from stage 1 to stage 2 then it started slipping. The previous owner said it was a new clutch. I put in a new clutch and what do you know. There was the same valeo combo and it doesnt hold for shit. My mechanic said it was still like new just couldnt handle the torque
    I would either buy a new stock dmfw from rock auto for a lottle over $300 or a light weight flywherl. I personally bought a new dmfw off rock auto
    Apr 20 2005
    New Hartford, IA
    Well, that's not a good sign in it's torque capacity and for the price I'm sure it's a cast iron flywheel also. I remember back in the day someone sold a billet single mass flywheel for these cars on ebay for way less than it should of been, but I doubt many people bothered with it. I can see the ttv flywheel being worth the price, but places wanting $700-800 for them is a little nuts. The 2.7t just doesn't have enough numbers on the road to bring prices down.
    00' Laser red S4 RS6 hybrids e85
    02' Corvette ZO6 383 TT 1012whp 990wtq
    02' Tundra
    SOLD 93' AWD Talon 523whp 486wtq
    Sep 11 2009
    NE
    That's why you buy TTV Racing billet FW which is shipped from england and costs in high 400s once said and done. That's a good $300 less than any reasonable offering in USA and just about what others want for a decent aluminum FW (which is inferior to billet steel in many ways).
    Oct 27 2014
    Flag/Phx, AZ
    Okay, so I'm thinking of buying the LUK dmfw off of rock auto for $300, and either going with the AMD stage 3 or ProjectB5 stage-X.. That would put me right at about $1000-1100. Does anyone have any other recommendations in that price range?
    IG: CJ_s4
    Jul 01 2014
    'murca
    i think i paid around that much for a fidanza lwfw and a clutch masters fx400. have a few friends running it on stage 3+ cars with no problems. one just rolled 60k on it with very spirited driving.
    Jan 17 2015
    2001 Noggy S4
    toledo, OH
    Im about to be in the same boat, kinda, sorta. Doing a 6-speed swap soon and I still need to choose a flywheel, pp, and disk... pretty much already had my mind set on that TTV flywheel because ive heard good things.
    Aug 24 2014
    Newport Beach, CA
    Quote Originally Posted by erykv1 View Post
    How much traffic/stop and go do you sit in? I'm thinking about the FX400 but concerned it won't last long enough with the amount of traffic I sit in commuting.
    2024 M3 Comp xDrive
    Oct 27 2014
    Flag/Phx, AZ
    I was not wanting to go with a aluminum fw because of the chatter. Does that setup chatter at all?
    IG: CJ_s4
    Jul 01 2014
    'murca
    Quote Originally Posted by christianb5s4 View Post
    I haven't done much driving yet as I'm still wrapping up some final hiccups with my build. The other s4 that has this clutch sits in 30+ mins of traffic a day. As long as you get a full faced disk you should be fine. Pedal feel is very close to stock and very manageable.
    Yes there is some slight chatter under 2k RPM. I dont think you can go wrong with either. I don't have much experience with the TTV but it looks like a really well built unit.
    Veteran Member Three Rings okkim's Avatar
    Dec 07 2004
    Finland
    That is not true. I know few RS6'd cars with a lots of torque and they have driven hard more than 100 000 km's!
    Jan 17 2015
    2001 Noggy S4
    toledo, OH
    Veteran Member Three Rings Wagonholic's Avatar
    Mar 01 2014
    2001 B5 S4 Avant (Laser Red)
    Los Angeles, CA
    RS4 clutch is a lot stronger than most people think. most of the time it's because of improper break-in, or clutch abuse lol. I've got close to 30k on mine daily driving, and it's held up quite great to launches surprisingly. K04s + meth.
    I have a friend who has an F21 car on E85 and is running a LUK RS4 setup with 65k on it. and 150+ antilag launches too. Still running it.
    But I will agree, that anything above that and you're probably better off with a stronger setup. But the RS4 setup is proven, cheap, and great to daily drive with. I'm probably gonna get flamed for saying this, but I've heard from friends that the $75 eBay disc holds up quite well too lol.
    Justin
    I have a major problem, I'm a boost addict and a wagon addict
    #toomuchboost #racewagon #becauseracecar
    B5 S4 Avant - Laser Red. 6-speed Manual. 1 of 18. Unleashed by STUKLR
    Going big or going home. Doing a garage build. View my build thread.
    #YEengineering
