    Jan 04 2016
    glasgow
    B8 Avant 2011 power steering airlocking its self ?
    hi guys/gals
    well decided to buy my self an audi as somthing more pratical than my vauxhall cavalier
    i purchased a 2011 audi a4 avant(estate) 2.0 tdi model about 3 months ago
    millage is abnout 96500 mls
    over the past few weeks the steering has become a little stiff with stiff spots (like air in the system)
    but ive never done anything to the steering for it to become air locked
    i checked the steering shaft between the rack and the column . but its ok with no play (gave it a spray both ends with wd40 anyways)
    checked the power steering reservoir and its showing its sitting on max .
    now tonight i done lock to lock and it cleared and gave me back the light steering i was used to
    took a drive for food and it came back again (done lock to lock and its cleared it again)
    ive had all the plastics off and theres no leaks or nosies to say the pump is on its way out
    the fluid on the little dip stick looks quite new
    have yous any idea why it would be air locking its self . As i said ive not had a problem with it for the 2 months before
    thanks again for any help its much appreciated
    kev.
    Veteran Member Four Rings bluetori's Avatar
    Jan 14 2010
    Discovery 4, RR7, SP Fireblade
    Georgia
    There is a tsb for the power steering hoses mine did only,do it backing out of a space after it that nothing, has it replaced u,see warrnty it went away but came back slightly more recently.
    Jan 04 2016
    glasgow
    sorry bluetori whats a tsb ?
    ive checked our goverment site over here for recalls but nothings came up with steering
    from what i can see everything is still original and theres no paper work to say any steering component had been replaced
    thanks again kev.
    Veteran Member Four Rings jfo's Avatar
    Nov 17 2010
    Courtenay, BC, Canada
    I believe he is referring to a Technical Service Bulletin for 2009 and perhaps 2010 models that were experiencing a stutter in the steering at low speed. if so, this TSB did not apply to the 2011 model since it already has the new hose.
    2011 A4 Avant
    Senior Member Two Rings Lockon_B7's Avatar
    Oct 17 2014
    New Jersey
    Could also be the intermediate steering shaft binding. That system is self bleeding so there should be no air in the lines. You could also see how new the serpentine belt is. I've seen a worn serp belt cause poor PS feel. (Mostly on 3.2L's) but it might still be worth a look.
    2016 A4 auto P+ Daily driver
    2016 S3 Sepang Blue Sold
    2009 A4 2.0T, 6MT, P+, Sport Package, Meteor Grey. Sold
    2008 A4 2.0T 6MT RIP
