I tried a search but couldn't find anything about it this model. I have a leak which appears every day the car is parked just under the driver side behind the wheel well. I thought it was condensation or AC initially then it was there at times I didn't expect it to be there. Smelled it and it was not anything oily.
Then the windshield fluid warning light came on. Didn't connect the two at first. Then I put in a gallon of fluid, a day later, the light came on again.
I have a 2013 allroad which I assume is pretty much the same car so thought I would post here. Anybody run into this and have some suggestion for how to investigate without going to a dealer or mechanic? I saw some other posts in other body styles about cracked housings or leaks in the headlight washer housing. It's annoying and just in time for the Northeast winter to start...
I didn't want to start pulling stuff apart if the other body styles have a completely different kind of issue.
