Results 1 to 3 of 3
    Veteran Member Four Rings BARRY's Avatar
    Nov 02 2007
    SF Bay Area, CA
    Anybody know how to remove cabin air filter housing?
    gotta check that the gasket is still intact to rule out for wet glove box. last I inspected inside of cabin airbox was wet last rain fall.
    Aug 26 2005
    After removing the filter cover and filter element, you will find several screws that hold the filter housing to the body. Remove the screws then remove the filter housing. Remove the old housing to body gasket, then apply some self stick on window weather sealing strip placed into the gasket groove to reseal the air filter housing to the body. Make sure the selected weather strip is thicker than the depth of the gasket groove.
    Vorsprung durch Technik
    Nov 02 2007
    SF Bay Area, CA
    awesomeeeeeeee! Thank you!
