Results 1 to 6 of 6
    Feb 25 2011
    Seacoast NH
    Question Local B7 Steering Wheel swap question
    Has anyone local swapped a B7 S4 (tiptronic with paddle shifters) three-spoke steering wheel to B7 A4 that came with a four-spoke steering wheel? I've been getting some conflicting info if the airbag would work fine (plug and play with no issues), or if I would need an airbag adapter to make it work.
    Thanks.
    Feb 25 2011
    Seacoast NH
    bump
    Veteran Member Four Rings Lambda13's Avatar
    Jul 07 2012
    A4, car parts, paint, random sockets, OEM parts.
    Boston, MA
    @ryanhmusic might be able to help.
    My 2009 A4 Prem+ Build thread
    Veteran Member Four Rings ryanhmusic's Avatar
    Aug 05 2014
    jack stands, a power washer, hand tools, bones of my fallen enemies, etc
    Unfortunately I've only swapped from three spoke to three spoke so I can't speak from first hand experience...but everything I've read on the topic seems to support needing to swap the airbag harness over and that's it...it has been done a bunch though so I'm sure you could find someone with first hand experience
    I'm living for the day I can park something Italian inside of my house.
    I had one wild summer on match.com. -some jackass
    01100010 01100001 01101110 01100001 01101110 01100001 00001010
    Veteran Member Three Rings VAGlover's Avatar
    Sep 23 2013
    b6 a4 track rat
    boston
    Probably get a harness for it and code the airbag control module for the s4 wheel. I could probably probably help you with the coding, I'm in allston.
    Sent from my VS985 4G using Tapatalk
    Veteran Member Four Rings wxsgt's Avatar
    Jul 16 2012
    2021 Audi A4 45
    Haverhill, Ma
    3 and 4 spoke airbags are not interchangeable, not only fit, but I believe wiring is slightly different.
    Sent from my SM-G920P using Tapatalk
    2010 Ibis White Audi A4 P+ l Upgrades: RS4 grill, Akebono Brakes, Debadged, Solo Werks S1 Coilovers, Targa Trophy Stickers(guaranteed 10+ HP) l
    2009 Ibis White Audi S5 Coupe | Upgrades: RS Grille |
