Results 1 to 7 of 7
    Veteran Member Three Rings B6_A4_Kid's Avatar
    Dec 07 2015
    89' Land Cruiser
    Salem, Utah
    Time for a boost gauge
    Well I have bought the column mount from ecs, and ordered a glowshift boost gauge for it. I know I know, glowshift sucks, shoulda got whatever, blah blah. It's what I could afford right now, later on I will upgrade but I feel it very important to be able to monitor boost. Today I received the gauge, but the vac line is only 6 foot. I need about 9 so I can run it through the fire wall. It's a soft rubber hose also, I'm just looking for an all around upgrade on that, and don't really want to order it. Do you guys know of anyplace that I can buy maybe the plastic vac line? And a brass t fitting? I've checked a few places but I can't find anything
    Apr 15 2014
    Ottawa/Gatineau Canada
    any auto parts store carries vac line and fittings.
    2004 A4 Avant Quattro. (H&R springs, S100 Nav unit, Neuspeed Cat back, Torque solutions Snub mount, Thor Skid Plate, APR Stage 1, 18" S4 Rims, 2X Podi / Oil Press / Oil Temp / Boost/VAC, Full LED interior, Backup Camera/Screen, Upgraded 2.0 Coil Packs, Vag-Com, B7 Center console/B7 Hand Brake, B7 Aero wiper arms B7 rear headreasts,APR Carbonio intake, Fan washer sprayers,
    2014 VW Tiguan. (bone stock)
    Dec 07 2015
    89' Land Cruiser
    Salem, Utah
    What size is it? Do you happen to know off the top of you head? That is the issue I was running into is not sure what size to use. I think tonight after work I'm just going to take the existing hose that came with it and see if they can match it.
    Dec 07 2015
    89' Land Cruiser
    Salem, Utah
    Hey guys, trying to install my boost guage and everything works, and it lights up perfectly. But I am unable to change its color, and it will flicker when I drive. I believe I have hooked it up right, hoping it's not the guage itself but that wouldn't surprise me. Thanks
    Apr 15 2014
    Quote Originally Posted by B6_A4_Kid View Post
    Vac reading and flickering are 2 seperate systems.
    If the Vac reading works....good.
    The flickering would be an electrical issue. Disconnect it, plug off your vac source and just hook the gauge itself directly to the battery and see if it still flickers. If it flickers you have a bad gauge. If it does not flicker then you have a bad 12v source or connection.
    There are MANY switched 12V sourced in the fuse panel, just tap out of one of those ;)
    Dec 07 2015
    89' Land Cruiser
    Salem, Utah
    I bought a fuse tap and tapped into the one ecs says to use for there boost gauge.
    Apr 15 2014
    Good to know.
