Hi all, I'm new to the forum. I have searched/read the threads on what to do about this code, but I was hoping I could get some back-up on my troubleshooting process.
CEL came on a week ago; rough idle, long starting time, etc. Used the BAFX OBD2 scanner and Torque App to pull fault code P0171 (System Too Lean Bank 1).
Put a new MAF sensor in, as it seemed the tests were showing O2 sensors good. After installing MAF, CEL went away, but after a few miles of driving, I got a PENDING P0171 fault with no CEL.
I have used the Torque App real-time data to look at vacuum (as I assumed this reading would help indicate if I had leaks). I am showing 23-25" of vacuum at idle, drops to around 5" with a quick throttle, then quickly rises back to 23-25" vacuum. So, I assume there isn't a significant leak. I also don't notice any obviously cracked hoses.
Since I have installed a new MAF, my next thought is a possible faulty before-Cat O2 sensor. My little knowledge of the O2 sensors is that there is one before the Cat and one after. I thought the before Cat O2 sensor gave loop feedback to fuel/air mixture system and the after Cat determined emissions/efficiency of Cat.
I also have a screenshot of a graph of O2 Sensor Volts for Bank 1 Sensor 1 and Bank 1 Sensor 2 that I will attach. NOTE: O2 Volts Bank 1 Sensor 1 seems to not be plotting?
I really appreciate any help I get. Thank you.
Data from Torque App is as follows:
Fault log report generated by Torque for Android
Vehicle VIN:
Vehicle Manufacturer:
Vehicle Calibration ID:
Current Fault Log
ECU reports no current faults
Pending Fault Log
P0171: System too Lean (Bank 1)
Historic Fault Log
ECU reports no historic faults
Other discovered fault codes
(possibly pending, current or manufacturer specific)
ECU reports no other fault codes logged
End of report.
Mode $06 report generated by Torque for Android
Vehicle VIN:
Vehicle Manufacturer: Audi
Vehicle Calibration ID: 8E0
Test report:
MID:$01 TID:$83
- O2 Bank 1 Sensor 1
Max: 1.99882 Min: 0.3499
Test result value: 1.05725
PASS
MID:$02 TID:$07
Minimum sensor Voltage for test cycle(calculated) - O2 Bank 1 Sensor 2
Max: 0.44969V Min: 0V
Test result value: 0V
PASS
MID:$02 TID:$08
Maximum sensor Voltage for test cycle(calculated) - O2 Bank 1 Sensor 2
Max: 1.29906V Min: 0.44969V
Test result value: 0.86449V
PASS
MID:$02 TID:$81
Max: 0.64514V Min: 0V
Test result value: 0.63538V
PASS
MID:$02 TID:$82
Max: 1.29906V Min: 0.64514V
Test result value: 0.6549V
PASS
MID:$02 TID:$83
Test incomplete or dependant test failed
MID:$21 TID:$84
- Catalyst Monitor Bank 1
MID:$3b TID:$82
- EVAP Monitor (0.090")
MID:$3c TID:$81
- EVAP Monitor (0.040")
MID:$3d TID:$80
- EVAP Monitor (0.020")
MID:$3d TID:$86
Max: 0.07167 Min: 0.06954
Test result value: 0.07167
PASS
MID:$41 TID:$85
- O2 Heater Monitor Bank 1 - Sensor 1
Max: 1,239.90002°C Min: 754.90002°C
Test result value: 819.90002°C
PASS
MID:$42 TID:$81
- O2 Heater Monitor Bank 1 - Sensor 2
Screenshot of 02 Voltages and Equivalence.
http://imgur.com/rxCdgGF
