Herro again azine,
So obviously this is a common symptom of a poorly bled clutch, and I've searched though the forums to see what I would find. I can get all the gears now with the car off, but if the car is on I cannot shift into anything.
Background info: New Fidzanza LWFW & New Clutchmasters FX400 w/ full faced disk, New TOB, New Pilot Bearing / Slave
I've tried bleeding it a million ways, the car is level. I've even tried to use a pressure bleeder but the pedal feel never improves.
I came across this article: http://www.audizine.com/forum/showth...ing-101-by-JHM and I've tried everything JHM recommends.
Could my slave be bad but not leaking? The pedal isn't sinking to the ground and not coming back, but it just feels a little weak. Its the only thing I can think of at this moment... unless somehow the clutch / flywheel / pressure plate stack is at an incorrect height for the TOB to depress? Seems doubtful, as it is a pretty common combo from what I have seen.
Thanks for reading!
