Results 1 to 9 of 9
    Sep 30 2015
    NJ/NYC
    OEM Vs Aftermarket Wheel weights
    Hello Forum,
    As some of you might have seen in my other thread I'm a new A6 owner and already have begun modding the car. I'm looking at wheels but I'm having a hard time finding the weight of the stock 18x8 wheels and those of some of the ones I'm looking to replace it with. I don't want to reduce performance with adding heavy wheels to the car. Anyone have a link or any resources on oem rotor wheels, peelers, etc. Thanks.
    Jan 30 2014
    1st gen Q45s
    FL, USA
    Quote Originally Posted by M3andAMG View Post
    Hello Forum,
    I measured my stock 18x8 speedlines with the original (but worn to 6/32) conti pro contact rubber at 49.8 lb.
    Sep 30 2015
    NJ/NYC
    Quote Originally Posted by FL C6 Avant View Post
    Thanks for the info. I'm looking for a 19 x 8.5 setup that is close to or lighter than the OEM set up, any ideas?
    Oct 31 2013
    Land Rover LR3, Harley Dyna Fat Bob, Triumph Speed Triple
    Washington DC / NoVa
    I just put on a set of 19 inch Hartmans replacing my OEM 18 inch wheels. Not sure of the exact weight difference but I could defiantly notice the weight reduction.
    Jul 17 2011
    Sin City, USA
    Quote Originally Posted by AFONE View Post
    Why would any weight reduction cause you to DEFIANTLY notice?? <in a whiney voice> "I don't want to notice it; I DONT!!" Damn auto-correct!! JK
    IIRC Hartman reps are in the same ball park as OEM wheels of the same design. If you want to reduce weight, moving from a cast wheel to a forged wheel will save weight as it takes more material in a cast wheel to achieve the same strength as a forged wheel. Unfortunately, moving into forged wheels increases $$.
    '09 C6.5 A6
    Sep 30 2015
    NJ/NYC
    You have any idea on how heavy the stock 19" oem Audi wheels weight? For what I am seeing going from 18" to 19" is going to add weight. The tires alone weigh 3 LBS more going from 245-40-18 to 255-35-19 so I'm not sure how afone says he feels the weight reduction? Unless I'm wrong and the stock 19s weight less than 18s?
    Jul 17 2011
    Sin City, USA
    I have a 19"X8.5 OEM wheel with 255/35/19 tire mounted that I can weigh and report back.
    '09 C6.5 A6
    Jul 17 2011
    Sin City, USA
    This wheel and tire combo weighed in at just under 55lbs
    '09 C6.5 A6
    Sep 30 2015
    NJ/NYC
    Thank you for the info. So I'm thinking the wheels probably weigh about 29Lbs a rim. Any idea if the rotors or peelers weigh more or less?
