Results 1 to 40 of 41
    Veteran Member Four Rings GRUMPY-S4's Avatar
    Nov 16 2015
    DFW
    Show me your P3 Gauge
    Sepang Blue with Blue interior... Debating what color to get the P3 Gauge in (Blue, Red or White).
    Veteran Member Three Rings MerkurRS's Avatar
    Oct 04 2012
    Four Passat W8's, 2003 allroad 2.7t , Ford Excursion Ltd V10, 1989 Merkur Scorpio, 1987 Merkur XR4Ti
    Berthoud, CO
    Sorry for the poor picture quality- but you get the idea. I really like the white/red version over all red.
    2012 Audi S4 Prestige Glacier White, Alcantara Leather, Titanium/ Black Optics Pkg, Auto/ Driver Assist/ Drive Select/ B&O/ Carbon Inlays, UltraCharger, APR Carbon Intake, Flat-bottom Wheel, 3G+Google Map conversion, Passport 9500ix red/carbon limited edition, Michelin A/S 3's, Armytrix/ Custom Exhaust, Spulen Diff Mount, 034 Trans. Insert, Eurocode Alu-Kreuz, ACNA Member
    Nov 16 2015
    DFW
    I dont like the all Red. Had it on my previous car and it just seemed odd. Debating on going White or Blue.
    Thanks for the Pic!!!!! I had not seen the white version before.
    Nov 16 2015
    DFW
    Seems like the White looks more OEM than the Blue... Thoughts?
    Veteran Member Three Rings StealthBlackA4's Avatar
    Aug 23 2012
    2012 Porsche Carrera 4S
    Erie, PA
    All red here...just did it to match all the interior buttons and what not. If I would have the chance to get another one...it would be the Red/White one instead of just all red.
    Nov 16 2015
    DFW
    Tom @ AP Tuning said there is a Blue option. I have never seen it. Thats why I asked.
    Oct 31 2013
    Morris County, NJ
    Go with white to match stock gauges
    2011 S4 P+ 6mt | AWE Touring | Roc Euro | H&R OE/Bilstein/034 RSB | APR Stage 2 DP + CPS | TSW Bathurst 19X9.5 | Michelin PSS 255/35/19
    Nov 16 2015
    DFW
    Thanks Guys! White it is
    Mar 21 2015
    Be careful not to explode your vent while installing Grumpy. Its painful if you do, scotch tape and very small needle nose pliers will be your best friend. There are a few threads with pics to check out.
    May 22 2015
    DFW
    Here is mine showing ethanol content from the Zeitronix analyzer.
    Senior Member Three Rings Mat@1975's Avatar
    Jun 14 2015
    FRANCE
    Quote Originally Posted by andthen View Post
    Nice and smart !!
    BR
    Mat
    S4 B8.5 AVANT | S-Tronic | Full ADS | Sport Diff | Glacier White
    MRC Stage 2 Tune | MRC TCU Tune | AMS/Alpha Cooler| AWE + AFE filter intake with airbox hole
    KW HAS Springs | H&R Sway bar F&R | Custom 14 mm Front and (13 R / 16 L) mm Rear Spacers | CR-15 Strut Brace
    OEM Rotors | Michelin PSS 255/35/19
    Q5 calipers | Goodridge SS Lines | 2-pieces Girodisc Rotors Front & Rear
    Nov 16 2015
    DFW
    AndThen is gonna help install as he already did his.
    Veteran Member Four Rings krew53's Avatar
    2023 RS6 - 2013 B8.5 S4 - 2003 B6 1.8BT quattro
    Simi Valley, CA
    I originally had red then switched to white.. Both colors look fine but the white is a little more oem looking
    2013 Solar Orange S4
    6MT | APR stage 2+ Ultra | Eurocode Headers | APR CPS | Meisterwerk clutch | Milltek Exhaust (resonated) | KW V3 coilovers | HRE FF01 | Stoptech trophy BBK | Alu Kreuz | Eurocode Sway / Endlinks / Trans & Dif mount | LYKT Control arms | E-Codes | Eurocode Short Shifter | P3 Gauge | Vinyl roof / trim / blades | B&O / JL Sound system | Probably more..
    Nov 16 2015
    DFW
    Thats a sexy pic!
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    I have found that the red reflects against the side window at night and is kinda irritating. With the white, not so much.
    Veteran Member Four Rings AudBoost's Avatar
    Apr 05 2005
    Tampa, FL
    This is a great idea. How hard was it to setup and incorporate the ethanol analyzer into the P3 gauge?
    You should definitely do a write up cause I bet a lot guys would be interested in this.
    2016 S6
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Ethanol content is a great feature, I have seen Eurocode do it on quite a few cars. They could sell you all of the necessary components. The also did nitrous pressure and fuel pressure too.
    I am waiting for somebody to add a thermistor to the supercharger coolant circuit for a more accurate representation of charge temperatures.
    Jun 14 2015
    FRANCE
    Quote Originally Posted by AudBoost View Post
    This is a great idea. How hard was it to setup the ethanol analyzer?
    +1000
    Verry interrested also !!
    BR
    Mat
    Mar 21 2015
    Quote Originally Posted by GRUMPY-S4 View Post
    Half of mine exploded, I got lucky. Others have had the whole thing go.
    Nov 16 2015
    DFW
    When you say Explode you mean the vents just pop off and break?
    Mar 21 2015
    The vents and all the little metal pieces that hold the vents in place all come apart. Nothing really breaks unless you give up putting it back together and chuck it in the trash.
    Nov 16 2015
    DFW
    Ahhh so it meant patience to reassemble... Not a new Vent.
    May 22 2015
    DFW
    It's literally one wire from the analyzer control box to the gauge. Then set up p3 to read it on one of the two available analog channels.
    Apr 05 2005
    Tampa, FL
    You purchased the Ethanol Content Analyzer and Flow Through Flex Fuel Sensor from Zeitronix correct? Was there anything tricky about that install?
    2016 S6
    Aug 23 2012
    Erie, PA
    Took me a good hour and a half to reassemble my vent when it exploded...damn was I pissed off. Close the vent...otherwise you'll end up dropping the metal hooks down the air vent. Had a hell of a time trying to get those back!
    Nov 16 2015
    DFW
    So close vent before popping it off?
    Dec 04 2015
    2014 B8.5 S4, 1989 Supra MKIII
    Nor-Cal
    A quick question to all, where are you supposed to plug the Green wire in/which wire to tap for auto dimming. Thanks
    GIAC/AWE Stage 2, GIAC DSG Tune, Roc Euro Intake, Awe Exhaust, KW HAS Springs, Niche 20x10 on Michelin PSS, Enlaes Diffuser & Deck Lid
    May 22 2015
    DFW
    All plug and play for the most part. I bought mine used from a buddy who was parting out. Ran the wire for the P3 via the same route as my boost line. I installed the sensor in the low-pressure fuel line under the hood and mounted it to my roc-euro baffle.
    Oct 04 2012
    Berthoud, CO
    Because there are not enough red/white pics posted, here is another just now taken at night:
    If you have a B8.5, you buy the gauge in the vent as an assembly, if you have a B8, you can but just the gauge or the whole thing. If your signature line existed- I would be able to help direct you and be more specific
    The trick (at least for the B8) is to cautiously remove the dash trim and make sure the ring behind the trim stays attached- it will want to separate. That is not the end of the world, but you will add more than an hour to your installation time.
    Veteran Member Four Rings DGVR6's Avatar
    Aug 03 2014
    Queens
    Pics?
    C7.5 S6 P+ Mythos Black
    [email protected] 103oct Stage 2 100 File/RACECHIP
    [email protected] 100oct Stage 1 93 File
    APR Tuned Stage 2 ECU/TCU | Roc Euro | Catless Downpipes | Milltek Resonated
    Previous
    B8 S4 [email protected] 93/e85 93 map - Unitronic Stage 2 B8 S4 6MT
    Mar 21 2015
    ^Grumpy buy just the gauge for the 8.5 or you're gonna pay a hefty premium with a new vent that you don't need.
    Nov 16 2015
    DFW
    Quote Originally Posted by MerkurRS View Post
    If you have a B8.5, you buy the gauge in the vent as an assembly, if you have a B8, you can but just the gauge or the whole thing..
    They don't offer the preinstalled version for the B8.5.
    Oct 04 2012
    Berthoud, CO
    Yes- I was backwards- you are correct. Vent & gauge for 2012 and earlier. Either way- the gauge w/o vent is the way to go IMHO.
    Plus, get the analog boost tap. I picked mine up when one of the vendors ran a sale for "free boost tap" with P3 purchase. It's not required, but you do get a more accurate reading for supercharger boost.
    Nov 16 2015
    DFW
    Luckilly I still have my analog sensor from my previous P3 on my other car. I ordered the boost tap from ECS. Now I have to figure out how noticeable the E85 sensor will be for when I go get service on my car. Trying to avoid an easy TD1
    Oct 04 2012
    Berthoud, CO
    Quote Originally Posted by garynagra View Post
    I tapped into the wire that illuminates the vent knob. It was easiest since it was right there. (red/blk wire I think???) I used a small wire tap
    Jun 14 2015
    FRANCE
    Hello andthen,
    Could you post some pics f your installation ? especially of the flow through sensor ?
    Thanks !!
    BR
    Mat
    Mar 21 2015
    Dealers dont like the boost tap either.
    May 22 2015
    DFW
    Quote Originally Posted by Mat@1975 View Post
    Hello andthen,
    Thanks !!
    BR
    Mat
    I put the control box in the glove box because my original set up(before I figure out you could use P3) used a cig lighter adapter and separate gauge.
    Jun 14 2015
    FRANCE
    Thanks a lot !
    IT makes me wish i had this Zeitronix device + P3 gauge...
    BR
    Mat
    Apr 05 2005
    Tampa, FL
    Thanks for posting pictures. I am pretty much sold on this idea. I was thinking about mounting the sensor under the car so it can't be easily seen. I'll have get under the car tonight and check it out.
    2016 S6
