Results 1 to 36 of 36
    Feb 20 2010
    TT225, Touareg, Tiguan, TDI, A3, RS6, Jetta
    Brighton, MI
    Allroad: Touchscreen Bluetooth Radio options
    What radio options do we have for our Allroad that 'fit the bill' below?
    Install photos?
    Links?
    Make/model?
    Prices?
    Looking for Symphony 1 replacement (died) for my 2001 Allroad.
    Desired:
    - good match to dash lights and interior
    - good fit into existing opening
    - easy install
    - bluetooth
    - works with Android app Torque
    - back up camera option
    01 Allroad Tiptronic, TCU tune, mild stg 3 (350 HP) tune (stock injectors) KraftwerkTurbo TM1. Lower, Wider. Custom tip vent pod with Podi
    02 Allroad 6 spd, Kraftwerk Turbo TM6, 750cc, 3" MAF, piggy, FMIC, CM stg 5 (hate). 30 psi at 3600 rpm. Needs stronger rods (coming).
    05 Golf TDI
    Looking for 2001 A4 1.8T quattro manual with blown motor
    www.regulatorfix.com
    www.kraftwerkturbo.com
    Veteran Member Three Rings a4kamila6's Avatar
    Sep 30 2015
    Think theres the audi RNS or some kind of bluetooth touchscreen radio of OEM quality, but its expensive i imagine. Then theres aftermarket route, and that isnt cheap at all. some say once changing head unit, might as well put in amp and probably new speakers to get full effect of system. If you already have the bose system, which i think is good enough, you should try finding the nav unit thats supposed to be in our cars. Someone who has one will definitely chime in.
    Feb 20 2010
    Brighton, MI
    RNS-E is overpriced for its capabilities.
    Factory GPS that came with our cars is a joke today (some arrows pointing you were to go, pack lunch if you want to enter a destination address). Well, its 15 years old, so no surprise.
    Some aftermarket look cheesy, they don't even TRY to make it look decent (non matching black trim, poor fit, etc).
    The added features (toys) cannot justify any ugliness.
    If it doesn't even look decent (OEM quality look and fit), may as well get a used OEM and stay with the Symphony 1.
    05 Golf TDI
    Senior Member Two Rings mr_dave's Avatar
    Apr 20 2013
    C5 RS6
    MN
    Aug 04 2009
    Glen Ellyn, IL
    You can get gen I RNS-E for 3-400 and gen II for 8-900. It cannot be bested for quality, fit, integration and cool factor. You can have bluetooth, satellite radio, live traffic updates and automatic route changes to avoid traffic, backup camera, play movies, watch TV, build in hdd style music with the two SD cards up to 64GB and all controlled from your steering wheel.
    Pretty solid option.
    Touch screen seems like a good idea but imagine you're on a bumpy road and you're trying to press a button a flat screen, also it requires looking at the screen unlike hard buttons that can be found by feel. The screen is placed too low IMO to be looking down there for touch screen buttons.
    Just my thoughts, otherwise there in an Android based RNS-E-ish unit that B7 guys use a lot if you must go the touch screen route.
    OEM+ work in progress allroad
    Unicorn Society member #8
    @fourings | Build
    Active Member Four Rings alien_brain's Avatar
    Jun 04 2013
    SE MI
    torque is great on my android head unit
    Veteran Member Four Rings R490's Avatar
    Mar 04 2014
    2024 Ford Bronco
    Northern Virginia
    There's a lot of great options out there,
    There's also a lot of horrible options out there. Don't buy ANY Jensen head unit. I had one in my A6 for less than a month before I got extremely frustrated by it being a piece of shit and ripped the thing out and dumped it in a box somewhere. This was after taking an entire day to install it while being poorly advised by Crutchfield onto how to solder the harness to get it to work on the car that they already said it would work on.
    /Rant
    2003 Audi S6 Avant
    2005 Audi S4 6MT SOLD, 2001.5 S4 6MT SOLD, 2001.5 S4 Tip SOLD, '00 A6 2.7t Quattro 6mt SOLD, '97 A4 2.8 Quattro 5mt SOLD
    Veteran Member Four Rings Racin2redline's Avatar
    Aug 19 2012
    1997 Yamaha razz 50 (sik)
    Long island
    I vote appradio4
    I hate aftermarket stuff but this is the cleanest option I've seen
    Sent from my SM-G900P using Tapatalk
    IG: d3bel1o
    Jun 04 2013
    SE MI
    i think this is the a6 version of the one in my a4:
    http://www.ebay.com/itm/S160-1080P-Q...kAAOSwAKxWanTV
    Aug 04 2009
    Glen Ellyn, IL
    That's the one I was thinking of ^
    @fourings | Build
    Sep 11 2009
    NE
    Full android ebay radio, this is with enfig kit (hard plastic on 01 hard plastic center console and yes, I like apples):
    Veteran Member Four Rings LakeTahoeQuattr's Avatar
    Jan 04 2013
    '07 JHM S6, '21 TTRS, '06 CTT, '20 Supra GR
    Zephyr Cove NV
    Quote Originally Posted by julex View Post
    I spy with my little eye a meth controller. I wanted to put mine there
    21 TTRS - track whip 1
    20 Supra GR - track whip 2
    06 Cayenne TT
    07 S6 Thread
    SOLD 14 JHM Q7
    SOLD 04 D3L
    SOLD 02 ar Thread
    Sep 11 2009
    NE
    Yeah, I don't smoke so I don't care about ashtrays .
    Nov 29 2015
    2001 Allroad
    Texas
    We're you able to keep the steering wheel controls working with this radio?
    Sep 11 2009
    NE
    Quote Originally Posted by tewnick View Post
    I would if I invested in about $100 more of stuff from enfig. Considering the radio was just a hair over $200, and the fact that I don't care for allroad clumsy buttons anyway, I decided to not implement this at this point of time. .
    Sep 30 2015
    Hey julex the meth controller is for a water/meth injection kit? how long does the mixture last you, and if you run out, what happens? Sorry for my noobness but i was wondering how this type of thing works.
    Veteran Member Four Rings V1nny's Avatar
    Dec 04 2012
    Arlington VA
    Quote Originally Posted by 4rings2turbos View Post
    I think this is pretty much nails it down, except second generation could be found for little less on ebay, if you patient. My favorite feature on Gen II RNS-E is TMC, real time traffic updates, no monthly fees. Also I sort of disagree that touch screen is just a matter of taste. To me its a safety issue, and I would prefer not to be hit by someone paying too much attention to touch screen selections while distracted from driving. Physical buttons are great, especially with RNS-E layout, you do not need to look at them, all basic function could be controlled based on your tactile feedback, due to positions of buttons and knobs of two different sizes. Lastly, second generation of RNS-E is 5 year old technology, not 15, and QNX operations system its running still the best. Wish someone ported Torq to run on it (should be possible just like Blackberry being able to run Android apps).
    Sep 11 2009
    NE
    To me it is a matter of cost really... Do I put $1500+ unit into $3k car or simply do generic chinese item for $300 after said and done. I could not reasonably make myself to buy newest RNSE and have all the head aches of properly installing it which is another project to do properly. Sure the RNSE units are nice but only the new ones, old ones, let's face it, are pointless to install imho unless I could get it for $100 or something.
    After having full android unit in my car for most of this past year and having access to any app and functionality you can imagine, I can tell you what I used it for the most.... pandora streaming with my phone as teether. With very occasional FM radio usage... NO OTHER USE.
    I have satellite radio in my wife's car but not using it at all since I really don't like inferior quality of it (my ears cringe) and the blackouts when any concrete is over my head. Sure it probably works fine for rural settings, but not for me, thus not having it is not a problem for me and even it is was an option with android, I would never ever pay for it lol.
    I still prefer phone for navigation by far because it is simply much easier to use, I just talk to the thing and it does everything without touching it and so on. Kids are watching their own stuff on drop down monitors in back anyway, and I have my music.
    So.... what I am getting at is: just make a choice based on what $$$ you have available. Can't go wrong with any option.
    Aug 04 2009
    Glen Ellyn, IL
    As a devout BlackBerry user I appreciate the credibility you've given them, as well as actually knowing anything about the brand's capabilities and systems they own/use.
    They used to be $1500 a few years ago but they're much less, I guess even less than I thought according to Vinny. I understand only spending a couple hundred when more is out of the budget or you won't use the features, but I do want to clarify that if you have an 02 on and get the correct harness then installing a gen II takes as much time as removing old headunit, plugging car pigtails into the quadlock harness then quadlock harness into the nav. Done.
    When we decided to put RNS-E into our then family hauler we did it because touching your phone is illegal in our state as well as potentially dangerous and we had our firstborn on his way. We needed fully integrated bluetooth and quality navigation integrated. One of the best features is the phonebook and navigation directions in the DIS, don't even have to look down at the somewhat low main screen. For bluetooth and navigation it's simply the best and most integrated option bar none. Also beautiful clean.
    ^personal experiences and opinions there, certainly understanding where you're coming from Julex.
    I'm a details guy and one final nail in the aftermarket coffin is that I CANNOT STAND the BS robotic voice on aftermarket and phone navigation systems. I'm a calm guy and those make me angry. They also drone on and on about the same information. I.E. if I enter a highway on ramp aftermarket will tell me to merge with the highway at the end of it. I DO NOT NEED THIS INFORMATION, THIS IS A GIVEN AS IT IS MY ONLY OPTION. For crying out loud.
    OP is getting more information than he bargained for, but he'll make one heck of an informed decision lol.
    @fourings | Build
    Jun 04 2013
    SE MI
    could you possibly provide links to your selections please? thank you!
    Sep 11 2009
    NE
    http://forums.quattroworld.com/allro...3.phtml#228542
    http://forums.quattroworld.com/allro...4.phtml#229455
    Bottom line is that the exact model I have I cannot recommend (it has problems) but there are LITERALLY 100s of 2 din models to pick from as far as android units go. Just browse A/V forums and ebay and get some headache pain killers ready (way too many to choose from). Anything rectangular 2din unit will fit in with enfig face/cage kit.
    Active Member Two Rings s2carlo's Avatar
    Jun 07 2012
    Netherlands
    Quote Originally Posted by alien_brain View Post
    Meanwhile the S4 got swapped for an A6 4.2 with a lot of options.
    for this car, this was what I am looking at as well to replace the factory RNS-D, but they did not get it to work with the steeringwheel controls.
    Also automatic on/off with ignition (canbus) did not go....
    Did anyone get a similar unit to work with all options in the car?
    Sep 11 2009
    NE
    Quote Originally Posted by s2carlo View Post
    contact enfig, they make control modules that will translate audi's signals to resistance style control that generics use.
    Jun 10 2013
    United States
    I have a pioneer unit and it is mounted and hooked up with the enfig mount and adapter. It works very well. The volume and up/down on the left of the steering wheel work. The left/right at bottom do not do anything. Enfig said it was supposed to answer the phone but it doesn't.
    The radio stays on after you turn the car off until you pull the key out.
    It works great with factory bose and should work with non bose amp.
    Now that I have all of the equipment adapters I can change out my head unit easily as new tech comes along. Win/win in my book.
    Jan 04 2013
    Zephyr Cove NV
    I have wanted this one for days. Problem is I think the faceplate will not work since it is for an a4. There are also a bunch of different ones on alibaba that fit the a6. Problem is that there are very few reviews on them. I have talked to a few people who have owned them and they have been some what happy with them but I hear often that the sound quality is not very good also.
    http://r.ebay.com/Dm4ert
    I would rather have this over an rnse, but it looks like I will end up getting an rnse because it will fit better
    06 Cayenne TT
    07 S6 Thread
    SOLD 14 JHM Q7
    SOLD 04 D3L
    SOLD 02 ar Thread
    Jan 04 2013
    Zephyr Cove NV
    Also looking at this one:
    http://www.alibaba.com/product-detai....30.141.3AwjB7
    I just don't want to make a $400 mistake and order some POS thing and have it not work well or have the face plate be a different color.
    06 Cayenne TT
    07 S6 Thread
    SOLD 14 JHM Q7
    SOLD 04 D3L
    SOLD 02 ar Thread
    Sep 30 2015
    You can get a radio, a face plate, the whole 9 yards. Will steering wheel controls work? Probably not. Would the system sound better with all new speakers and new amp? Yes. Just changing the head unit for aftermarket is kinda pointless in my opinion. For me its rnse, symphony 2, or full blown soundsystem with headunit, amp, speakers, extra battery maybe, a sub. to each his own though. crutchfield should have the faceplate adapters in stock.
    Jun 04 2013
    SE MI
    Quote Originally Posted by LakeTahoeQuattr View Post
    i think youll be happy with how it works, maybe no so much the build quality. the knobs are somewhat squirrely. the color is spot on. ive never noticed bad sound tho.
    Jan 04 2013
    Zephyr Cove NV
    Post a picture of yours. You have this same one?
    06 Cayenne TT
    07 S6 Thread
    SOLD 14 JHM Q7
    SOLD 04 D3L
    SOLD 02 ar Thread
    Aug 04 2009
    Glen Ellyn, IL
    Forgot to mention but the gen II is a really nice sound upgrade from Symphony II with Bose.
    @fourings | Build
    Jun 10 2013
    United States
    Quote Originally Posted by a4kamila6 View Post
    The main reason to update to a newer head unit is bluetooth integration, both for calling and music streaming.
    4/6 steering controls work with Enfig cable. Maybe more depending on head unit.
    Sep 30 2015
    Right, for the calling feature i guess you need a new radio but if you just want bluetooth integration, they make adapter kits for our symphony radios. I was itching to get an aftermarket unit and after doing my research i figured im better off finding a nice second gen rnse. The good aftermarket radios cost almost as much if not as much as rnse. Not saying you cant get a 250 dollar radio and call it a day.
    Mar 09 2008
    Torrington, CT
    Quote Originally Posted by Racin2redline View Post
    I vote appradio4
    How do you like the appradio? How well does it work with navigation like waze? Can you use any iOS app on it or only specific CarPlay published ones?
    Aug 19 2012
    Long island
    it's not mine, its my friends but he loves it and yeah it mirrors your iPhone display because apple carplay
    IG: d3bel1o
    Jun 04 2013
    SE MI
    i have one made by the same company. they are all manufactured by the same company and rebranded and sold by fly by night companies... i think they dont pay google to use android.
    Sep 11 2009
    NE
    all made by HuiFei
