Results 1 to 6 of 6
    Veteran Member Four Rings MadAboutCars's Avatar
    Aug 27 2015
    MY18 Audi RS6 P, MY18 Audi SQ5,MY16 Audi S6 (sold), MY12 Audi Q7 4.2L TDI S-line (sold)
    New Zealand
    2016 S6 Throttle Body Alignment
    This has probably been mentioned before, but I thought I would share the method that worked for my C7.5 car. I understand this can be done with VCDS, as well, but a security code is needed.
    With the key in your pocket and the drivers door open or closed:
    1/ With the ignition off, press the accelerator pedal all the way to the floor.
    2/ Press the start/stop button while still holding the pedal on the floor. If the door is open, press the menu button on the steering wheel, to stop the beeping.
    3/ Wait 10 seconds and then press the start/stop button again, to turn off the ignition.
    4/ Hold the pedal on the floor for another 3 seconds and then take your foot off the pedal.
    5/ Wait 2 minutes. In the first 30 seconds you will hear some clicks and clunks, as the throttle is calibrated.
    2018 Audi RS6 Performance - Floret Silver, Titanium styling package, 21" titanium 5 V spoke wheels, Dunlop SP Sport Maxx GT 285/30/21, Black sports seats, Carbon inlays, Sports diff, Sport exhaust, Matrix LED headlights, 360 camera, Head up display, Active lane/side assist with adaptive cruise control, Park assist, Privacy glass, Electric tailgate with foot open
    Mods: Dura-Seal exterior/interior, Audi Sport door lights
    Senior Member Three Rings hubris's Avatar
    Jul 07 2015
    Midwest
    Why would you need to do this?
    2014 S6 | Prestige | Ibis White | APR Stage 2 | Milltek Turbo-back Exhaust, Resonated, ValveSonic, High-Flow Cats | P3 Boost Gauge
    Aug 27 2015
    New Zealand
    I understand that it resets some of the ECU's adaptations, so it should be a good thing to do if you have bought a car second hand and the previous owner didn't drive it very hard. I was also told to do it after switching tunes, but when my tune dealer tried to do it with VCDS, he couldn't because he didn't know the security code. I've also read that it has improved power, in some cases, and fuel economy, for people that thought they were using more than they should.
    I should also point out that it won't work if there are any engine fault codes present, battery voltage is less than 11.5 volts and the engine temperature is outside of the range of 5C to 95C. Also not for diesels, as they don't have a throttle body.
    Veteran Member Four Rings HyperM3's Avatar
    Mar 20 2004
    Lawrenceville, NJ
    Ok, so we now know how to do it but a security code is still needed. Worthless without sharing. Care to share?
    21 S5 Coupe - RacingLine strut brace/034RearSwayBar/CTSTransMount/034 tune/VPS Res Delete/CTSIntake
    10 S4 (gone),13 S6 (gone),14 S6 (gone),14 S6 (gone),16 S6 (gone),17 A4 (gone),19 S4 (gone)
    20 BMW R1250RS
    ACNA Lifetime Member - 26690
    Respond to a post with an answer, they will keep asking questions. Teach them how to RTFM, they will learn to help others.
    Senior Member Three Rings jasonlitka's Avatar
    May 31 2014
    Exton, PA
    Quote Originally Posted by HyperM3 View Post
    You don't need the code for the method above.
    Jason Litka
    2016 Audi S6
    Misano Red Pearl w/ Black Comfort Sport Seats, Layered Aluminum/Black Wood, & Black Headliner
    Prestige/Individual Contour Seating/Sport/Driver Assistance/Cold Weather/Black Optic/Night Vision/Rear Side Airbags
    Mar 20 2004
    Lawrenceville, NJ
    Quote Originally Posted by jasonlitka View Post
    I get it now. I thought you needed to get into VAG in order to get this method to work.
    20 BMW R1250RS
