Results 1 to 40 of 43
    Nov 18 2014
    Jersey
    Getting my S-04's installed tomorrow.
    Kind of excited bros
    2018 Jeep GC Trackhawk
    2022 Audi SQ7
    2017 R8 TT. 1370whp.
    2007 Porsche 911 Turbo...Bolt On's
    Jul 21 2004
    South Florida
    lol, i understand. I really liked those tires when I used them and the S03 before them. Wednesdays I should get my TSW Bathurst in the mail so i'm in anticipation mode too.
    Mike
    2018 Audi S5
    Gone-
    Nov 18 2014
    Jersey
    Anything compared to the stock contis will be a huge upgrade.
    Funniest thing.... They are the same size (technically), and they physically measure almost 1.5 inches wider than the stockers.
    Senior Member Three Rings mact3333's Avatar
    Mar 13 2014
    Pacific NW
    mine have been on for 2 weeks now....they seem pretty good so far...no complaints
    Oct 14 2012
    Empty...for now...
    SE PA
    Quote Originally Posted by Rez90 View Post
    Those are summer tires, no? Won't do you much good in New Jersey this time of year!
    SOLD 2015 Daytona Gray S4
    Nov 18 2014
    Jersey
    Quote Originally Posted by SteveYem View Post
    I have a set of Nokian R2's ready to go on as soon as i see snow in the forecast.....not looking too promising though...
    2022 Audi SQ7
    Veteran Member Three Rings yakev724's Avatar
    Jun 26 2014
    Brooklyn
    How do these compare with PSS? Curious since Michelins were always my go-to summer tires.
    Nov 18 2014
    Jersey
    Quote Originally Posted by yakev724 View Post
    On tirerack they are 2nd max performance summer tires behind the PSS's. The car is my DD so i figured for $60 less per tire it would be worth it to try them out. if you compare the reviews and numbers they're literally a few tenth's off of the PSS's in most categories.
    http://www.tirerack.com/tires/tests/...y.jsp?ttid=148
    2022 Audi SQ7
    Veteran Member Four Rings jran76's Avatar
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    I think for the money, they are a really good tire. My second choice behind the PSS. However, they are quite a bit heavier (4 pounds) if that is something you'd be worried about.
    2018 S4 : Daytona Gray : Black Nappa : Carbon Atlas : S Sport : Black Optics : 034 Springs/Rear Sway Bar/Inserts : 19x9.5" BBS CH-R Wheels : EPL tune : Wagner Intercooler
    2002 S4 : Black : Black Leather : 6-Speed : Stage 2+ ...
    2022 Q7 : Mythios Black
    Oct 14 2012
    Empty...for now...
    SE PA
    Quote Originally Posted by jran76 View Post
    When I was shopping for summer tires, I had it down between the PSS and S-02. I was ready to go with the S-02 for the money savings until I read that they were heavier by what I would consider to be a significant amount. And, the additional weight is out at the tire which is the worst place it could be as far as rotational inertia (accelerating and braking) are concerned.
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    No doubt. 99% of people probably don't notice or aren't effected by that on a daily basis. If you are the kind of person that is, or you like to race or whatever, it's something to consider. 16 lbs. or rotating mass is quite a bit, but not the end for most people. Obviously, a higher percentage of people on this forum probably do care, but in terms of the general population, most probably don't.
    Veteran Member Four Rings KRp220's Avatar
    Aug 23 2011
    NH
    any insight (on weight and in general) on the hankook evo12 or whatever they are called? i don't drive that aggressively and was considering making the switch from PSS's to save some $, and considering 20's and may need a lower 'volume' tire
    2013 S4 // ESTORIL BLUE // 6MT// RS BUMPER // GIAC STG 2 // FORGE CC // AWE+SCORPION // ECS INTAKE // BILSTEIN+H&R // VOSSEN VFS5 // PSS 265/30/20 // AK // 034 MOUNTS // SB STAGE 3 CLUTCH // CR 15
    + ECS Diffuser, BFI shift knob, tints, sports diff, j-codes, Akebono pads, SS clutch line, Ceramic Pro...
    GONE 2010 S4 // QUARTZ GREY // 6MT // GIAC STG2 // AWE TRACK // ROC EURO // 034 TRANS MOUNT // H&R OE's // AG M610 FF 19x8.5 // + random stuff
    Veteran Member Four Rings MrFunk's Avatar
    Apr 04 2012
    MSP
    I'd caution running max summers in anything under 45 degrees. One cold night with some frost and presto black ice or similar...
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    Quote Originally Posted by KRp220 View Post
    Per Tire Rack on the 255/35/19 (I don't take these weights as the gospel, but they'll be really close and give you a good idea):
    Michelin PSS is 24 lbs.
    Conti DW 24 lbs.
    Hankook Ventus V12 25 lbs.
    Bridgestone S-04 is 29 lbs.
    Pirelli P-Zero (Audi) is 24 lbs.
    Bridgestone RE-71 is 26 lbs.
    Michelin Sport Cup 2 is 23 lbs.
    20" weights will be similar differences from tire to tire. 255/30/20:
    Hankook Ventus V12 is 24 lbs.
    Michelin PSS is 23 lbs.
    One thing to consider is you'll get probably 1/3 to 1/2 as many miles out of something like the Hankook as opposed to the PSS. The PSS is the only tire in that class with a tread-life warranty, and it's 30k miles on our cars (if you run the same F/R size). Anything below that that you don't get out of the PSS, they'll credit (pro-rated) towards a new set.... You'll get maybe 15k out of the Hankook's. So, you may save some on the front end with something like the Hankooks, but you'll more than make it up in the long-run on the PSS's. I paid $500 for my second set of PSS's....
    Apr 04 2012
    MSP
    I ran Hankook V12's in a 20 for a couple seasons. Not impressed. They were vague and imprecise at 7/10th the limit and more. Fine for farting around town, pretty good in the wet... but with any aggressive driving I was not very thrilled. Their limits were also quite lower than expected and when they broke loose it was sudden...
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    Quote Originally Posted by MrFunk View Post
    I thought there was some value in them when they were really cheap, but they are not that cheap anymore. Relative to other/better options, they are in-line price wise. They do run narrow and stretch well if you're trying to squeeze an aggressive wheel on the car. That's about all I would recommend them for at this point. Not a horrible tire, but there are definitely better options for the money now.
    Aug 23 2011
    NH
    thanks for the insight guys. much appreciated
    Veteran Member Three Rings Jv218's Avatar
    Jun 10 2015
    15 S4, 2012 civic
    Boston
    I'm in the market for a set of summer tires once this winter is over, my main choice would be the S-04 or the PSS just need someone to buy my stock 18 pilot sport 3 at the moment.
    15 Ibis white, Dsg, P+, magma interior, F1 35% pinnacle tint, ECS RS4 grill, AWE Track 90mm tip, 19x9.5inch HRE FF01, ECS Carbon Intake
    Veteran Member Three Rings BigBluu's Avatar
    Feb 25 2010
    '15 S4, '17 A3 e-tron, '18 Model 3
    The City
    Can you elaborate on this? Since you don't have them mounted yet, I'm assuming the 1.5" difference is in the tread width? I'm on 9.5" VMR wheels with the stock Conti's and do not like the stretched look. I was planning to go one size up to 265/35/19 on my next set (planning S-04 as well) within the next couple months. I'm only on H&R OE Sport, so hopefully rubbing won't be an issue.
    2015 S4 S-Tronic Prem+ Sepang/Magma Sports Diff / B&O / Carbon Atlas / 034 ECU & TCU Stage 1 / ECS Intake / Alu Kreuz / CR-15 / 034 Trans Mount / 034 Rear Sway / Moog Links (F&R) / H&R OE / VMR V810 (19x9.5/ET40) / Michelin PS 4S / Opti-Coat Pro
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    Quote Originally Posted by Jv218 View Post
    Hmmm. The stock 18" tires on the 2015 are Pilot Sport 3's? That's pretty nice. My 2012 had the 18" Bridgestone RE050 which I am not a fan of (I like most Bridgestone tires, but not those....).
    Jun 10 2015
    15 S4, 2012 civic
    Boston
    Yup, that's what my car came with anyway when I selected the summer tire option. I believe for the 19in they come with the conti 5p or 3p. I think their not bad but I wouldn't buy for my 19 setup
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    Yeah, the Conti 5P is the newer 19" option. I agree, not horrible, but not what I would choose if buying....
    Jun 10 2015
    15 S4, 2012 civic
    Boston
    I'm leaning mainly towards the pss but for the price the S-04 isn't bad at all. Tried it before on a 335i full bolt on and it felt really planted
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    Quote Originally Posted by BigBluu View Post
    A meaty 265/35 on a 19x9.5" ET40 will probably have some minor rubbing, or you at least need to be prepared for it. Even a meaty 255 is cutting it close.
    I do think the S-04 is a good deal if you aren't concerned about the weight. It's a solid tire.
    Senior Member Three Rings kap09's Avatar
    Jun 22 2010
    2017 Grand Cherokee, 2015 Fiat 500e, 2016 eGolf, 1989 Jeep Wagoneer
    Couldn't agree more. Very satisfied with them when I ran them a while ago, but they definitely lack a little something compared to the PSS. If you're not pushing the car hard, I'd save the cash and go S04 all day.
    2014 S4 | DSG | Ibis White | Sport Diff | MMI | Carbon Atlas | B&O | Side Assist | SC Badged
    GIAC Stage 2 v2 | GIAC DSG | Roc-Euro Intake | AWE 102mm | Brembo 380mm | Deval Rear | OZ Leggera | Michelin PSS | OE Sport | AluKruez | H&R Sways | 40% Pinnacle Tint | Hoen Endurance | VCDS Mods | Escort 8500 x50
    Past Rides
    2013 S4 6MT//2010 A4 Quattro//2000 BMW 323i//1991 Integra//1990 Jetta//1993 Civic
    @kap9 on Instagram
    Jun 19 2014
    toronto
    Good tire choice.
    They would be my pick over the PSS. For anyone who tracks, the PSS wears out rapidly, and the shoulders simply cannot take a beating. It doesn't matter if you run 3 degrees of camber, the sidewall is simply too soft...the tire wears out in very weird ways. Not to mention, being such a soft tire, you are trading off feel and steering response. And that there is the key thing to some aspects of tire selection. You aren't only buying grip, but you are buying how the grip is delivered. The S04 is a much more responsive tire than the PSS. I'd pick the S04 over the PSS for occasional track use. Not only is it a more durable tire, but it makes the car handle more sprightly than the PSS can. Yes it's heavier, but you are getting a much firmer sidewall. I will take that trade off in weight any day. See the weight of Z2, Rivals, RE71r et al. Those are all heavy tires. No doubt because of the reinforced tire carcass. For performance driving duty on a 4k lb car, you want a stiff tire. Good pick OP. Sometimes it's not all about the #'s. Driver confidence and feel will affect lap times. And if a tire is delivering grip but doing nothing else but piss you off (because you have to manage sidewall roll over, or shoulder block wear), then it is not worth the hassle.
    PSS is over rated (for track use). #flamesuit on :D
    Jun 26 2014
    Brooklyn
    Quote Originally Posted by boro92 View Post
    Good tire choice.
    no, very good points - appreciate the response. not many have had the experience of running both s-02/3/4 and PS2/3/S in demanding conditions.
    Feb 25 2010
    The City
    Got the S-04's installed over the weekend. My stock Conti's were down to the wear bars with less than 12k miles on the odo. I could've squeezed another thousand or so miles out of them, but with all the rain we're finally getting here in NorCal I didn't want to risk it. Only had them on for a few days with mainly wet weather, but initial impressions are...I love these tires! Excellent grip when dry, confident handling when wet, and oh so damn smooth and quiet on the highway...virtually silent! And they look great too! I went with the stock size based on Rez90's suggestion and glad I did. Stretch look on my 9.5" wheels are gone. Tires are nice and flush now. Can't believe the stock Conti's robbed us of 1.5" of tread width. Only drawback is that they are rubbing ever so slightly at speed over big bumps. Gotta be even more careful now. I'm only lowered on H&R OE too. If these last me at least 20k miles, I'll be happy.
    Jun 05 2014
    2010 A4 6MT Prestige 19" Sport
    Philadelphia Area
    Here comes 1-2 feet of snow this weekend!
    2016 S4 6MT SD BlackedOut B&O Tech
    Veteran Member Four Rings vwblackb5's Avatar
    Jun 26 2007
    New Jersey
    Quote Originally Posted by adk_audi View Post
    I'm super excited to finally get my WS80's mounted tomorrow ...bring on Winter Storm Jonas Brotherssssss
    16 B8.5: S4 | Premium Plus | Ibis White | PNY | PPS | GH2 | 1BL | Black Nappa | CTS
    99.5 B5: K04-015 / GIAC PC-16 / 315cc Genesis / Custom FMIC / 034 TP / TT Downpipe / Jetex Catback / Forge 007P / ECS AFPR @ 2.7Bar / ABD Tuning Intake / Blinktek Heatshield / Koni FSD / Eibach Pro Kit / SouthBend Stage 2 Endurance OFE HD / 312mm Slotted A8 BBK
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    Thanks for the post and update. They look good (and meaty). It's definitely a wide tire, so a little rubbing isn't shocking (and good for all the people that say an ET40 absolutely won't rub). A local guy is running the stock Conti's on a 9.5" and they look like 245's. Just goes to show how much tires can vary....
    Jun 17 2012
    Dallas TX
    Very good points here on both PSS and S-04's.
    I just switched from PSS to S-04's recently and so far I am enjoying them but there's definitely a different driving experience with the PSS that is unmatched.
    For the price point S-04's are a great option.
    Nov 12 2015
    Here
    That was not my experience at all. I went through 2 sets of PSS's on my B7 and, even with regular rotation, hit the wear bars well before 20k both times. Switched to the Hankook Evos on my last set as owner and they still had plenty of tread left at 20k. The Hankooks may have other issues, but wear aint one.
    Mein ist grau
    Mar 12 2014
    Long Island, NY
    I couldn't agree more.. I had PSS on my 335 and once the temperature dropped under 45 degrees the compound hardened up and it was like driving on black ice.. horrible idea for right now especially in jersey.
    2013 B8.5 S4| APR Stage 2+ w/ UltraCharger on E40 | APR Dual Pulley | APR DSG Update | APR CPS | Awe Non-Resonated Downpipes | JHM Test Pipes | AWE Touring Exhaust 102mm | Alu-Kruez | JHM 2-Piece F&R | H&R Sport Springs
    Veteran Member Four Rings Vogz's Avatar
    Jul 17 2010
    996 Turbo
    Batavia, IL
    I've had S-04s for two seasons now and absolutely love them. I had the Dunlop Sport Maxx GTs from the factory, and they were actually a decent tire. The S-04s are even better. For a daily driven S4 they are perfect IMO. They give up a little ultimate grip and response vs. the PSS, but they are quieter and ride better while still gripping really well when you want to dig into some corners.
    SOLD - 2011 S4 Sprint Blue 6MT Ti - GIAC Stage 2 - Sachs XTend clutch - AWE exhaust - Bilstein B12 suspension - strat short shifter
    [email protected] 1.85 60' (stock)
    [email protected] 1.74 60' (stage 2 - 93 octane)
    [email protected] 1.71 60' (stage 2 - 104 octane)
    2020 Tesla Model 3 Performance
    2003 Porsche 911 Turbo - SpeedTech, Cobb, Bilstein, H&R and TPC goodies
    11.69@123mph 1.82 60' (RWD on street tires)
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    Quote Originally Posted by SportVier View Post
    Milage will vary, but you are right, the Hankook has decent treadlife. The point I was trying to make (and didn't do a great job) is the PSS is the only tire in it's class with a treadwear warranty, and that's a big deal. I only got 14k out of mine (could of gotten a few thousand more), and I got my next set for basically 50% off with the warranty.
    Tire rack surveys rate the treadlife of the PSS as 8.3, and the Hankook as 7.4 (I don't put a ton of weight into the surveys, but it's a pretty big delta). The results from people running them on an AWD vehicle like the S4 seem a little better than that in terms of tire life.
    Feb 12 2013
    Boston, MA
    Uh treadwear warranty. If you anly got 2/3 of the life then you should have gotten the next set at 30% off.
    Once you factor in treadlife, tread warranty and performance, there is no logical choice besides PSS (for a DD) even though the initial cost can be higher, the cost per mile is lower.
    Sep 30 2009
    b
    +1 looks great
    Jun 22 2013
    E30 325i 6cyl. - sold. 2013 Golf TDI 4dr DSG
    Bellingham, WA
    Thanks for sharing pics! I got ~25k miles out of my first set of S-04's on my A6 2.7T here in rainy northwest Washington. 20k on the higher HP car is more than reasonable with proper inflation & alignment. Watch out for inner camber wear in the front! Wet grip and hydroplane resistance is exceptionally good with these tires, as is road response. 235/35/19's are quite stiff...Beefy sidewalls indeed. Tread noise remained super quiet all the way down to wear bars.
    Im looking forward to running a set of S-04's when i get into an S4 - especially seeing as how perfect 255's look on a 9.5 wheel. Dissappointed they dont come in 255/30/20 as I'd love to run them for summers/car show season. PSS will do well for 20" fitment, though their price seems excessive for an AWD casual daily driver. Only other option in that size are V12's which dont interest me much after my excellent experience with these Bridgestones.
    Jan 09 2008
    Winnipeg
    Good tire choice.
    I've never had the opportunity to test tire back to back but I think I wouldn't be able to feel the difference between a heavy tire and lighter tire. Of course, I usually only switch over my tires in the off season so each spring I'm on new summers...I can't remember how the car felt 6 months prior.
    Glad to hear from someone like boro that he'd take the heavy tire over the PSS and that there are benefits of the stiff sidewall. Most of the time I only hear people talk about the benefits of the lighter tire. Now we just need a tire manufacturer to give use a stiff sidewalled tire that is light.
