Results 1 to 40 of 48
    Established Member Two Rings kr3w45's Avatar
    Mar 19 2014
    02 a4, 06 a4, 09 a4, yamaha r6
    Boston, MA
    Installed Stage 2 pulley - now P2007 intake manifold flap stuck closed
    [Edit: Problem fixed see below]
    Removed my supercharger today to instal the CTS pulley. Everything was cake until I took the car out for a test drive and after 2 key cycles, CEL P2007. Checked for pinched vacuum lines under supercharger, none, all hoses in correct order. If it were a pinched line I would suspect both banks to throw codes?
    What are the chances one of the flaps is actually stuck closed? When I had the blower off, I started pulling the covers off the valves so I could carbon clean them but didn't feel like dealing with the fuel injectors so I put it back together. Only thing I can think of. Also the purge valve seems to be clicking loud enough to hear but this would typically throw a p0441?
    Any help would be great
    Thanks,
    Automate your Dealership: www.DealerScience.com
    Automotive Technician @ Amherst Autoworks
    B7 A4 - Frankenturbo F23L
    B8 S4 Stage 2
    Nov 18 2014
    Jersey
    did you pull the blower or put the car in service mode?
    2018 Jeep GC Trackhawk
    2022 Audi SQ7
    2017 R8 TT. 1370whp.
    2007 Porsche 911 Turbo...Bolt On's
    Mar 19 2014
    Boston, MA
    I pulled the blower
    B8 S4 Stage 2
    Nov 18 2014
    Jersey
    Odds are you did exactly what i did. The top two vacuum hoses are likely switched. They are at about 1 o'clock in this picture.
    2022 Audi SQ7
    Mar 19 2014
    Boston, MA
    Which hoses? I only see 2 solenoids in your photo I have 3
    B8 S4 Stage 2
    Nov 18 2014
    Jersey
    Not sure. our cars must be different years. but my gut tells me something is reversed/switched. Maybe make another thread with your pic asking for another member with a B8 to take a pic of those hoses to see the order. Mine is a 2015 so i guess something changed along the line....
    2022 Audi SQ7
    Mar 19 2014
    Boston, MA
    Oh okay. Thanks for the input. Did you have the same code and just 1 bank?
    B8 S4 Stage 2
    Nov 18 2014
    Jersey
    Quote Originally Posted by kr3w45 View Post
    after 24 hours i had 2 codes. One was the same as yours and the other was for flaps stuck open....made sense that something was reversed. I was so lucky i took that pic before pulling everything apart.
    2022 Audi SQ7
    Mar 19 2014
    Boston, MA
    Everything seems to line up is why I'm so stumped
    B8 S4 Stage 2
    Nov 18 2014
    Jersey
    hmm. me too. looks correct. Maybe check all the connections one more time?
    wish i could have been more help. best of luck.
    2022 Audi SQ7
    Mar 19 2014
    Boston, MA
    Tripled checked .. Looks like I'll have to take the blower off again and see what's going on. Thanks man
    B8 S4 Stage 2
    Veteran Member Three Rings skiptowncat's Avatar
    Nov 13 2014
    Manchester, England
    Did you reconnect the two hoses that are underneath and to the right of no.3 in the picture
    2015 C7.5 S6//DS1 STAGE 3//SRM INTAKES//034 X-PIPE//H&R SWAYS
    Mar 19 2014
    Boston, MA
    Yes I did, thank you for checking. I've had the supercharger off twice before for the thermostat so I'm pretty confident all hoses are connected in the right order. Just about to take the blower off again to check out the manifold flaps
    B8 S4 Stage 2
    Veteran Member Four Rings schirm's Avatar
    Apr 23 2009
    1999 bmw z3coup M with 5,000 miles Mint
    Forked River nj
    I received this code Friday P0004 same CEL BAnk 1. on a cold start. I received a new motor from Audi last week too. I cleared the CEL, and it has yet to come back.
    Edit, mine says stuck open not closed.
    2004 A4 1.8t | Avant | 6MT | Stock | Atlas gray |
    2010 S4 | Ice Silver Metallic | Sport Diff | 6 speed | 19 5-Tri-Spoke Wheels | Audi Drive Select | B&O | Silver/Black Nappa Sport Seats | Navigation Pkg | Brushed Aluminum Trim | APR Stage 2+ | Hoen Xenonmatch Fogs | 034 Motor mounts | Roc Euro | black RS4 Grille |
    Past
    2007 A4 | Revo Sg 2+
    2005 Subaru Legacy GT 365WHP
    Veteran Member Four Rings AudBoost's Avatar
    Apr 05 2005
    Tampa, FL
    I got this code when I got my car back from having fuel rail recall done. The tech's missed installing the vacuum line to the purge valve. The best way to get to it is from the driver's side and it's right behind the oil filter.
    2016 S6
    Mar 19 2014
    Boston, MA
    Thanks for all the replies everyone. I've confirmed my left side bank manifold flaps are in fact not working properly. Has anyone replaced the vacuum pump for the flaps? Can't even find parts online.
    B8 S4 Stage 2
    Mar 19 2014
    Boston, MA
    Fixed:
    The left side manifold flaps were in fact stuck closed as suspected. I figured that if it were a vacuum line problem I would get P2007 and P2006 because there is only one vacuum line that splits to both vacuum actuators.
    What happened was when I removed the supercharger, I had started removing the fuel rail assembly to clean the valves. When doing so, without applying vacuum to the flap actuator the flaps popped up over the lip when they should be on the other side. I will post photos with my phone so you can see what I'm talking about here to help anyone in the future if this happens to them after removal of the supercharger.
    Thanks for the input!
    Edit: that shiny line is to stop the flaps when vacuum is pulled. The flaps were stuck above the line keeping them closed and not allowing them to open.
    B8 S4 Stage 2
    Apr 23 2009
    Forked River nj
    Fixed:
    Glad you figured it out!
    Any idea why mine would be stuck open? P2004
    Past
    Mar 19 2014
    Boston, MA
    Quote Originally Posted by schirm View Post
    I would be willing to bet its a mechanical issue (if it's only a code for 1 bank, if not vacuum related). Are you comfortable removing the supercharger? I would recommend removing the blower and use a vacuum pump to actuate both of the manifold flaps and you will easily be able to tell what's going on.
    I attached a video too you can check it out
    B8 S4 Stage 2
    Apr 23 2009
    Forked River nj
    Yeah I would be comfortable doing that.,.but my motor was replaced by Audi last week So if it keeps happening I will bring it in. Just curious to what can cause it to happen. I cleared the CEL Friday, it has not came back.
    Past
    Mar 19 2014
    Boston, MA
    Why was your motor replaced?
    B8 S4 Stage 2
    Apr 23 2009
    Forked River nj
    My story is here.
    http://www.audizine.com/forum/showth...ht-running-bad
    Past
    Mar 19 2014
    Boston, MA
    What a nightmare. Did they ever figure out what the initial problem was? If they swapped the original supercharger on the new motor chances are they screwed something up from the sound of that dealership after reading your thread haha
    B8 S4 Stage 2
    Nov 18 2014
    Jersey
    glad it all worked out
    2022 Audi SQ7
    Senior Member Two Rings Wreckm's Avatar
    Oct 30 2013
    San Gabriel California
    Cleeaaar.
    Revived.
    Wondering about the intake flaps anyone have info if you can tuck them back in easily?
    or you have to take that intake manifold part off as well and do it with part off?
    Veteran Member Four Rings theweebabyseamus's Avatar
    May 12 2008
    ‘Intake manifolds’ off
    Oct 30 2013
    dug into alldata.
    Generate vacuum using hand vacuum pump.
    ¤ The intake flaps are opened.
    ¤ If the intake manifold flaps are not opened, they may get jammed when installing the lower intake manifold on the cylinder head.
    Remove hand vacuum pump from intake manifold runner control vacuum actuator.
    So my guess for the fix is take the lower intake manifold off create vacuum make sure flaps are below ridge and reinstall?
    May 12 2008
    Just move them into position by hand. They’re all tied to the same rod so you only need to move one.
    Established Member Two Rings JaB6's Avatar
    Jul 14 2016
    Quote Originally Posted by theweebabyseamus View Post
    +1
    Hold the the flaps open a little as you tighten the assembly down, sometimes they'll want to come back to the wrong side before it's all tight
    Veteran Member Three Rings 03redgti's Avatar
    Dec 20 2010
    lancaster, pa
    Bump had my charger off and got these two codes as well. 2006 and 2007 both runners stuck closed . Going to get a vacuum pump tomorrow and Hold them open while I re install the charger. What causes them to get stuck?
    And the line circled in red..is that the one that actuates the flappers?
    2013 S4 | Glacier White | Chestnut Brown Interior 1/13 | Sport Diff | IE Stage 2 | IE Intake | JHM V2 Test Pipes | PLM V2 HE | Custom Magnaflow Exhaust | Solo-Werks S1 | Rohana RF-2 20x10 square | Continental DWS |
    Jan 09 2008
    Winnipeg
    Quote Originally Posted by 03redgti View Post
    The cause is improper installation. When you are putting the manifolds back in you need to hold the flaps open as you are setting it in place, which you can just do by either pressing on the flaps or using the armature that is attached to the diaphragm at the front. No need for a vacuum pump. A lot of people, including myself, have hit this snag...thankfully I remembered the warnings people gave before I got my supercharge back on and just had to pull the manifolds back off and reinstall.
    Once your manifolds are all tightened down, you should be able to press the flaps open. If you can't do that, you have it wrong.
    May 19 2015
    winnipeg
    This is really good info once i do t-stat and water pump!
    Dec 20 2010
    lancaster, pa
    Quote Originally Posted by eurotic View Post
    I didnt touch my manifolds and they did move by hand before I put my charger back on. My issue was I had two vacuum lines reversed. all is well now
    Senior Member Three Rings hmc2261's Avatar
    Nov 25 2019
    Charlotte, NC
    Fixed:
    I know this is super old but I just had the same thing happen during my stage 2 install, shop pulled the supercharger so I’m guessing I’ll need the same fix you had to do.
    The car doesn’t seem to produce much power at all, it doesn’t pull. When you fixed the issues I’m assuming all of the power came back as normal?
    Oct 19 2008
    Ontario%20Canada
    I feel like I've read that there needs to be some kind of reset / vcds / coding type thing that happens to these intake flaps when the lower manifolds are removed... am I wrong?
    Jun 05 2015
    a few interesting items
    Quote Originally Posted by wes8398 View Post
    Bump for interest
    Sent from my LYA-L0C using Tapatalk
    May 27 2020
    Indiana
    I'm having the exact same problem. I pulled it all apart replaced pcv and thermostat. Put it all back together and getting the same code. I have plans of pulling it all apart again today and doing a carbon cleaning on the valves. I need to reset the intake flaps. It's a 2012 A7 111k miles stage 2. I was chasing down a mystery coolant leak. Hoping I fixed it.
    Oct 19 2008
    Ontario%20Canada
    Quote Originally Posted by mkl101 View Post
    Fingers are crossed for you!
    Mar 08 2021
    Corby UK
    Have you sort that mate ? Im also after pcv waterpump and thermostat replacement and got p2006
    Oct 19 2008
    Ontario%20Canada
    Quote Originally Posted by Mpharm View Post
    Have you done ANY of your own reading on this? It's literally one Google search away. Your intake runners weren't re-installed correctly. The flaps are stuck, so your intake runners is only allowing about 30% of the airflow it would when the flaps are open.
    2011 S4 - Ibis White - 3 pedals - daily driver
    2.95 PR, EPL software, Merc Racing HX, Eurocode inserts, Koni Yellows, H&R OE Sports, beefy RSB, homebrew CR15, stainless brake & clutch lines, custom FBSW by FlyDesigns, P3 Multi Gauge
