Went through a bunch of repairs to remedy a misfire problem. Changed coils and plugs first. Seemed to fix the problem. Great.
Plugs were fouled and there was oil in the IC pipe so I replaced the valve cover gasket shortly after. About a week later, the misfire problem returned. After searching decided to replace the injectors.
Injectors replaced, misfire continues. Checked compression to find zero compression in cylinder 1. Removed the intake manifold (again) and cleaned as much carbon build up as I could. Wasn’t too bad but just in case it was causing the valves not to seat properly.
Removed the valve cover and checked the valves for cylinder 1. Seems to be seated. No gap or play in the springs.
At this point, not sure what to do next? I’m guessing possibilities are:
- Bent valve
- Rings
- Cracked piston.
Could it be anything else? I think if it’s the bottom end, I’d rather opt for a replacement engine.
Car has about 63k miles. Throwing codes P0300 and P0301
Thoroughly frustrated.
