Results 1 to 10 of 10
    Nov 02 2014
    06 9-3 Aero 2.8T, 96 Miata
    Winchester, VA
    Meth dealers in NoVa area?
    Made you look.
    I got some methanol from a friend a little while ago and went to straight meth from washer fluid + heet.
    Now I'm getting low and don't want to go back. Anyone know where I can snag some? I live in Winchester, and work in Manassas.
    Forum Moderator Four Rings DirtD1ver's Avatar
    Feb 20 2013
    2017 Allroad, 2020 Q7
    MD
    You can try Ptuning.
    Don - Forum Moderator, Audizine
    Current: 2017 Allroad Prestige Manhattan Grey
    Previous:2013 Allroad Prestige Monsoon Grey
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    -20 degree washer fluid is as close as u can get to 50/50 water/methanol by weight (ww fluid has like 2-3% detergents and is split by volume not by weight).
    When i looked around, methanol was pretty pricey around here and I would have to travel far and whatnot, so I just ordered a case of boost juice because it was only slightly more expensive and they are all sealed so the methanol doesn't go bad
    Veteran Member Four Rings i1overice's Avatar
    May 09 2013
    Loads of junk.
    Northern Virginia
    Why hasn't anyone tagged @blackbenz yet?
    Current - 2017 Honda Civic EX-T
    Sold - 2010 Ibis White S5
    Veteran Member Four Rings audistealth's Avatar
    Mar 04 2012
    2012 Audi S4, 2017 Explorer Sport
    Quote Originally Posted by i1overice View Post
    Dunno, that's what I came here to do.
    /// 2012 S4
    RocEuro Intake | AWE/GIAC Stage 2 | 19" Titanium Rotor Wheels 10mm H&R spacers | RS5 BBK & ECS 2pc front/rear wave rotors | Renn RS-51 19x8.5 20.5lbs | JHM LW/HD Pulley | MMI 3G+ rev. G and controls retrofit | vagcom stuff | Jokerz ported coated supercharger | KW V1
    Mid-Atlantic Forum (MD/DC/VA)
    Nov 02 2006
    Alot of junk
    MD
    Someone looking for meth? How much volume are we talking? I got you
    Low and slow
    Veteran Member Four Rings Race Shooter's Avatar
    Dec 22 2006
    Raleigh
    Heisenbenzz?
    2014 Porsche Cayman S Guards Red
    2015 Sepang Blue S4 6MT Gone...easily forgotten.
    2004 Nogaro Blue S4 Avant 6MT Gone...but severly missed .
    Jim Sykes Photography motorsports photography
    Nov 02 2014
    Winchester, VA
    Quote Originally Posted by blackbenzz View Post
    I'd probably hope to snag 5-10 gallons at a time.
    I was running -20* washer fluid plus 4 bottles of heet for a rough 50/50 mix. Then my friend gave me about 8 gallons and I went to 100%.
    Now spraying 2 d07 nozzles of 100% at 25psi and 24* of timing advance up top with only 3* or so of corrections, vs 6-7 I had on 50/50.
    Screw washer fluid, I want the uncut stuff.
    Nov 02 2006
    Alot of junk
    MD
    Quote Originally Posted by Race Shooter View Post
    Heisenbenzz?
    They call me Jessie cuz I'm not dead
    Quote Originally Posted by DieselElectric View Post
    I can get it for you. But I'm not close to you
    Low and slow
    Veteran Member Four Rings Evilevo's Avatar
    May 26 2008
    2018 TTRS, 2014 Q5 TDI, 2020 Supra, 2022 F150, 2004 V70R
    MD
    I have a 5 gallon jug of VP M1. Probably has 4 gallons left in it. I don't need it anymore since I sold my S4. I'd let it go for pretty cheap if you pick it up. I work in Herndon but live in MD. I can bring it to work with me one day if you want.
