Results 1 to 21 of 21
    Veteran Member Four Rings cjt671's Avatar
    Dec 14 2014
    B5 S4 sedan, 2018 Q5
    PNW
    Driver side inner tire alignment issue
    Just want some feedback before I get an alignment. My options in the area are a local alignment and brake shop, and a les schwab...
    The pic is the driver side front tire off my old wheels, new set of wheels is showing the same kind of wear just not through to the belt yet. Do you guys think it's a toe issue?
    Veteran Member Four Rings Turbo_B5's Avatar
    Oct 09 2012
    abunch of useless shit
    Notnomde Atrebla Adanac
    Alignment printout?
    EH F0UR 2001 A4 1.8TqM
    = Parked cause its junk.
    2002 Golf TDI
    = FASTER THEN YOUR B5.
    2018 Suzuki GSX-R750
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    1997 A4 1.8TqM SPORT
    @Turbo_B5
    Dec 10 2013
    Borden, Ontario, Canada
    Toe out issue. Guaranteed
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    Nov 04 2013
    stg 3 widebody, 1990 miata, '05 gsxr 1000
    Palo Alto, CA
    uh, lol. that's a camber issue bro. not a toe issue. toe can exacerbate it (and does), but ultimately that's too much negative camber for you. If you take alot of corners at race pace, that would even out, but for most drivers having more than 1degree of negative camber will result in the above. camber is not adjustable on stock control arms. Lowering the car causes this. can correct with adjustable control arms and an alignment, or raise the car back up.
    Dec 10 2013
    Quote Originally Posted by james 408 View Post
    No, he's not even that low. Plus, it would also present itself on the passenger side but it's isolated to the driver side.
    I guarantee it'll be toe out when he gets new tires and the alignment sheet.
    My A4 was about his height and the front wheels wore very even. I didn't align the rear when I did the coilovers. So when it dropped, it toed out the rear and gave similar wear to what he is experiencing.
    Everything graciously mispelled by Android
    IG: 24_et
    Sold:
    RIP:
    Nov 04 2013
    Palo Alto, CA
    i hear ya.
    camber isn't even between sides necessarily stock. you can shift the cradle to even it out. camber is the measure of the top of the tire relative to the bottom of the tire -- the direct measurement that causes tire wear to be too far to the inside or the outside.
    toe is the angle of the front vs rear of the tire, if it were out, it would cause the front of the tires to face outwards. this could in theory cause the tire to roll towards the inside and wear the inside, but toe just causes the tire to scrub more, and i've never seen the impact of wearing the inside more than the outside independently of a camber issue. Absent the car having never been aligned, i wouldn't expect that to be the case as this is the only thing alignment shops ever do unless you force them to. driving a car without an alignment is just craziness.
    I've run cars with 3/8" toe out, and negative 2 degrees camber, and still worn the outside edges of the tires. Driving patterns matter too. So it's entirely possible he's just hitting too many left handed corners.
    Dec 14 2014
    PNW
    Quote Originally Posted by King_ View Post
    Alignment printout?
    Haven't got one yet, I'm not to savvy on alignments and I dislike taking my car to shops so I just want as much info as possible before I go in on Wednesday to get it checked out
    Dec 14 2014
    PNW
    Quote Originally Posted by Bordom View Post
    I'll post the sheet up when I get it, I'm sure the local shop should be able to handle adjusting the toe.. And I'll talk to them to see if they can check raised toe value as well.. I just don't want to have some shop touch the car because it drives perfectly .-.
    Dec 14 2014
    PNW
    i hear ya.
    Thanks for the input man, The car tracks straight and handles perfectly fine imo which is why I wanted some insight because I had assumed that if I had an alignment issue I would be able to feel it in the way the car drives, also I don't consider my self to be an aggressive driver... But that's all relative
    Dec 14 2014
    PNW
    Like bordom said, my car is far from low enough to have created enough negative camber to be considered detrimental to tire wear. It's slightly lower than sport suspension.. I've seen negative camber wear and this just doesn't look like it to me.. It's not a patch of the inner tread worn lower than the outer tread but a section of the inner shoulder worn to the belts..
    Dec 14 2014
    PNW
    Got an appointment Thursday to get everything checked out. will post results
    Active Member Two Rings MikeK's Avatar
    May 14 2011
    2011 A6 3.0T, 2002 S6, 2007 VW Passat 2.0T, 1970 Buick Skylark convertible, 1999 Suburban
    San Diego, CA
    Did you ever post any results?
    My C6 series A6 has the same wear pattern - completely stock and driven by my wife. Car tracks and steers without issue. The inside corners of both front tires are worn to the belts - didn't notice it until I got under the car to check the inner pads. I'd like to have an idea of the root cause before I take it to a shop.
    Aug 06 2008
    Canadia
    if it was toe then both would be worn evenly and the steering wheel would be off center, if one side is out the tires will naturally point themselves at the same angle.
    im going to say the front subframe is shifted all the way over to one side so you have one wheel standing up and the other one is leaned in.
    alignment on these cars is done by shifting the subframe to make camber the same on both sides, then the toe is set, then the car is raised up 30MM by the subframe and the raised toe alignment is done where the tire rods are adjusted vertically (the bolt on the top of the end of the tie rod is there to assist with this). this is done so that as the front wheels move up and down over bumps, accelerating and braking the toe remains relativity consistent. it will add an extra half to 1 hour to the job, book time is about 2 hours for a 4 wheel alignment on a B5.
    the B5 S4 is like the mafia... there is only one way out!
    May 20 2012
    San Jose
    Relativity? I don't think he'll get close enough to the speed of light for it to matter.
    Established Member Two Rings Uber's Avatar
    Nov 29 2014
    Cbr1100XX Blackbird
    cazadero,ca.United States
    Check upper a-arm bushings
    Sent from my SM-G900V using Tapatalk
    Nov 04 2013
    Palo Alto, CA
    just looks like he overheaded the inside treaad block and it separated. inspect parts, get a proper alignment. problem solved.
    Dec 14 2014
    PNW
    Quote Originally Posted by MikeK View Post
    I ended up not being able to get an alignment yet
    I plan to get it checked out this week when I get the car running.
    Dec 14 2014
    PNW
    Got it all checked out today. Didn't see anything too off.. Looks like previous owner who did the suspension modifications aligned it pretty similar to the rs4 specs at -1 degree of camber all around and factory toe settings which makes me think the owner after him and before me probably just never rotated the tires..
    I don't understand how the dealership sold me the car like that though...
    Jul 04 2012
    Woodbridge, VA
    Quote Originally Posted by cjt671 View Post
    Unfortunately you don't know the history of the tires. Maybe he bought them that way. Maybe he swapped them from a friends ride. Maybe it had bad tire wear BEFORE fixing the suspension. You just don't know.
    Nov 04 2013
    Palo Alto, CA
    yeah, without the history you're flying blind. Even with a good alignment, sometimes tire pressure needs to be changed in rain vs dry etc to make it even. My last 10 sets are all over the map in terms of which edge/center is wearing, gotta read your tires regularly.
    Dec 14 2014
    PNW
    Yeah not knowing the enact history has been the main thing with this car.. Especially the lifter failure.. but thankfully it's all sorted out... For now at least lol
