Code:
005489 - Left engine mount solenoid valve (N144) P1571 - 001 - Short to plus
I had the car towed to CarMax, who in turn sent it off to the local Audi dealer. The dealer said both motor mounts were leaking hydraulic fluid, and one of them had caused an electrical short which in turn caused the ECM to freak out and the car to run like crap.
This sounded really fishy to me, but some Google searches turned up other instances of this with other Audi owners. There were several cases with cars that had electrohydraulic engine mounts. Not just B8s. This is an ad for upgraded solid mounts, but so far it's the best picture I've seen that shows what the stock ones look like inside. I'm trying to find some kind of factory literature that explains how they work. From what I understand, there's a valve that closes and makes the mounts stiffer (since fluid cannot compress) at higher RPM. At lower RPM, the fluid is allowed to flow between two chambers, making for a more compliant mount.
This is the dealer's description of the problem on the repair order.
Check and advice car started to sputter then would not stay running. Found fault P1571 left electro hydrolic solenoid valve. Inspected and found both motor mounts leaking causing short to ground. Replaced both mounts, completed alignment.
I haven't driven it much since I got it back, but so far it seems perfect. Maybe even a little better than before. We'll see what happens as I put some more time and mileage on it. I'll update this thread if anything changes.
