Results 1 to 22 of 22
    Veteran Member Four Rings doowopaudi's Avatar
    Aug 10 2011
    North Whittier
    Should I just get new tires?
    I was pumping gas when I noticed my front RIGHT tire was split at the bead. I'm not low on air, but I'm wondering whether I should be concerned. I don't know how long I've been driving with the tire like that, but if anyone knows exactly what is happening there and can offer some insight and/or advice, I'd greatly appreciate it.
    Last edited by doowopaudi; 01-04-2016 at 11:31 AM. Reason: Should read front "right" instead of front left tire. Fixed.
    ::2010 A4 Premium+ Quattro::6SMT::Meteor Gray Pearl Effect::35% 3M tint all around::Vag mods::debadged::RS4 replica grille w/ fog grilles::LED interior lights and lic. plate lights::ST Coilovers::19x9 OEM A5 Peelers::245/35/19 Achilles ATR Sport::Underseat Storage Bins::Zubehor Diffuser::Door Handle storage bins::LED reverse Lights::
    Former: 2008 A4 S-line::2007 Mazdaspeed3::1991 VW Cabriolet
    Feb 24 2013
    CA
    Go to americas tire if the tires still have alot of thread on them. Get warranty certificates, shouldnt cost more than 150 for all four. Then, go back a couple days later and show them the issue. They will replace the faulty tire with a new on and you only need to buy abother certificate for that tire.
    Veteran Member Four Rings Project Quattro's Avatar
    Mar 24 2014
    1984 Porsche 3.2 Carrera Targa, 2019 Audi SQ5 Prestige (hers)
    Probably. That looks like it's on a seam and will likely get worse. Probably worth sending pictures to the manufacturer to see if they'll cover it or want to take it back to see why it failed.
    Sent from the Pedal Responce Emergency Bat Phone
    2020 Alfa Romeo Giulia Ti Sport Carbon - 1984 Porsche Carrera 3.2 Targa
    Past: 2017 Audi A4 Prem+ 7AT, 2013 BMW 528i xDrive, 2013 Audi A4 Prem+ 6MT Sport, 2009 Audi A4 Premium 6AT
    Chairman Emeritus for the Pedal Responce Team
    Established Member Two Rings Hagasan41's Avatar
    Sep 16 2013
    Orlando
    You should definitely be concerned. How many miles do you have on the tires? You've only had them for around ~8 months, right? Contact the manufacturer, although from their website it looks like that will be difficult. So your seller should assume some responsibility. I would contact "Get your Wheels" and ask for a replacement. This is a real safety hazard, so if you have another set of wheels I'd recommend you swap them over Immediately. Be careful and good luck...
    Let us know how "Get Your Wheels" responds. A real test for a company is the level of service AFTER they have your money.
    Sep 09 2010
    Destin, FL
    Quote Originally Posted by doowopaudi View Post
    I was pumping gas when I noticed my front left tire was split at the bead. I'm not low on air, but I'm wondering whether I should be concerned. I don't know how long I've been driving with the tire like that, but if anyone knows exactly what is happening there and can offer some insight and/or advice, I'd greatly appreciate it.
    Oh damm. It doesn't look like it was pinched or anything so I'd say defect. I would get a new one because who knows how fast you will be going when that hole grows and blows out.
    Veteran Member Four Rings blbroo's Avatar
    Oct 26 2012
    SQ5, Nissan D21, 435i Gone: K04'd B8 A4, M235i, UrS6, B9 SQ5, D21 Nissan 4X4
    St. Louis, MO
    Quote Originally Posted by Slick_B8 View Post
    This place will let you buy warranties for used tires that are on your car already without inspecting them? Or are you saying buy a new tire then go back and tell them the new one split? Seems shady and dishonest. I couldn't do that anymore than I would hit someones car and drive away without telling them.
    OP, I agree with T_I, get that tire off of your car as soon as you can and avoid highway speeds with it until you do. Looks like either a defect or you rubbed against something sharp and cut it.
    No road hazzard warranty on them?
    Collector of German things.
    “Whoever said laughter is the best medicine had clearly never tasted scotch.”
    Aug 10 2011
    North Whittier
    Quote Originally Posted by Hagasan41 View Post
    Quote Originally Posted by The Infiltrator View Post
    Quote Originally Posted by blbroo View Post
    Thank you gentlemen,
    It's 8:45am right now in So Cal and American Tire Depot opens at 9am and they have a special for buying 3 tires and getting the 4th one free. I'm debating whether I should just buy a new set of 4 or simply replace the damaged one. If I get a new set, I'll most likely not go 235/35/19 and go to 245/35/19 because I have a feeling that the stretch is what may have caused it to split.
    I will also contact Get Your Wheels to see what they can do, although they didn't carry the tire but were able to acquire them for me.
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    Yes get NEW tires and yes get 245/35/19's, the 235's failed because they where stretched and did not have the correct weight carry range, a lot worse things could have happened. Minimum weight range is 93.
    Aug 10 2011
    North Whittier
    Quote Originally Posted by o1turbo30v View Post
    I went with a complete set of new 245/35/19 and got road hazards for all of them. The road hazard is good for three years or until the tire reaches 3/32".
    I definitely learned a lesson with this. I'm thankful that nothing worse happened, but wait til I show you guys what happened to the other tires.
    These had an even bigger split on the inner side. The two rear tires were fine.
    Veteran Member Four Rings name.goes.here's Avatar
    Mar 17 2012
    South of Boston
    ^^you were very fortunate driving on those...
    His: 2015 Audi A6/Quattro/Glacier White/Premium Plus/Bose/Cold Weather Package/Sport Package
    Hers: 2016 Infiniti QX50/AWD/Majestic White/Premium Plus Package
    Dec 08 2012
    Moldova
    Made in China :(
    Audi A4 B8, 2.0 TDI. Retrofits: Bi-xenon. Front parking sensors with graphics. OEM Bluetooth. Servotronic - 1N3. Footwell lights. Color DIS. AMI. Audi Drive Select. EGR off. DPF off. 207BHP CAHA remap. Keyless Entry/Go. Lane change assist. B&O. Aux Heater.
    Oct 26 2012
    St. Louis, MO
    Glad you caught the split in time.
    Aug 15 2014
    what brand tire is this?
    Veteran Member Four Rings SleeperCar's Avatar
    Jan 03 2012
    VW Atlas and too many detailing supplies
    Wilmington NC
    OP, FWIW, i tried to get a manufacturer to replace my tires because the tread wires were crossing creating a bumpy ride feeling. It was a nightmare and at the end of the day they didnt cover them because of the incorrect tire size as recommended for my wheel, meaning stretch voids any warranty from my experience.
    2019 S4 Build
    2013 A4 Scuba Blue Metallic - SOLD (never forgotten)
    IG: @steves_s4
    Feb 24 2013
    CA
    LOL just saw the tire brand. I hope you replaced it with something better, otherwise I hope you understand that this is the risk with running a cheap tire.
    Jan 03 2012
    Wilmington NC
    what brand is it?i couldnt even tell???
    2019 S4 Build
    IG: @steves_s4
    Aug 10 2011
    North Whittier
    Quote Originally Posted by Shimmy View Post
    Quote Originally Posted by SleeperCar View Post
    Yep, they were LionHart LH Four tires and to be completely fair, I blame the split on not having run the proper tire weight ratings that our A4's call for.
    I replaced them with Achilles ATR Sports which appear to have great reviews. Either way, I'm covered for 3 years by American Tire Depot and they carry these in stock, so I don't have to deal with manufacturers should a need arise.
    https://www.google.com/search?q=achi...+sport+reviews
    Jan 03 2012
    Wilmington NC
    Never heard of them. Personally I stick with very reputable brands such as continental or hankook
    2019 S4 Build
    IG: @steves_s4
    Sep 09 2010
    Destin, FL
    Same here. Tires, not a good idea to cheap out on.
    Dec 14 2011
    Chagrin Falls, Ohio
    From the tread design (no siping) they don't look like they would be very good in snow. I got Continental DWS 06 for only about $8 more a tire on Black Friday.
    Aug 10 2011
    North Whittier
    Quote Originally Posted by Silveravant View Post
    There's a new version of the ATR Sport called ATR Sport 2. I went with the older version because the tread is suitable for socal weather conditions.
    Aug 10 2011
    North Whittier
    Update: I've been in contact with the Get Your Wheels rep who sold me the tires since Monday of this week. Hagasan, I've actually had the tires since February 2015, making my tires about 11 months old. Anyhow, the rep requested pictures and it looks like I'm getting two new replacement tires. I have to drop off the tires at their warehouse and they will be taking care of all the paperwork for me. I do plan on selling the 2 new tires on craigslist along with the 2 rear used tires that only have inner camber wear since I'll never run 235/35/19 91Y again on my B8.
    By the way, there was no damage on the inside, so that was good to see.
