Results 1 to 8 of 8
    Nov 11 2015
    Bad Brake Booster, Engine mounts and Rear Main Seal Leak
    My 2006 A 4 has a bad brake booster so the dealer says. The brake pedal would intermittently get hard.. difficult to press but only as im waiting at a light or when the car was parked. But as it got going the pedal would soften up and would be easy to to press down.. The dealer said it was a bad booster.. He also said that I have a rear main seal leak..... and i also need the motor mounts replaced.. He quoted me 2200 dollars.. I said NO Way.. I knocked him down to 1500.. He said he was going to call around for aftermarket parts and get back to me. How much would be a reasonable price to get those items replaced and is it worth it.. the car has 211K miles on it otherwise in good shape..
    I drive mostly highway miles.
    Jan 05 2015
    London
    My rear main oilseal leak was caused by a duff pcv, so I would make sure you change that one. Is the brake Booster the same as the vacuum pump?
    Rear main oil seal was quite a job as it is transmission off job. If you are doing that, may make sense to plan ahead and get clutch etc changed too.
    Feb 24 2004
    Minneapolis
    If you have oil dripping off the back of your engine and leaving a puddle on the floor, maybe you think about the rear main seal. But if you don't even get a puddle back there, some dealer is trying to make a buck.
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
    Sep 11 2009
    A4 B7 2.0T MT, A4 B5 1.8 MT
    South Africa
    Do you have hard break pedal at stops only while the car is cold or it happens all the time?
    Nov 11 2015
    Quote Originally Posted by marlboro View Post
    It happens only at stops or when the car is slow moving less than 5 mph at like a drive thru mcdonalds.
    Nov 11 2015
    another thing .. if i authorize the rear main seal to be done. what else should they do while they are down there? I have bad motor mounts. he said they would replace them for no labor cost.
    Nov 11 2015
    so the job is not done yet. The dealer called me and said in addition to the brake booster there is a vacuum pumpt that needs to be replaced for an additional 295 dollars. Is that bullshit or not?
    Jun 17 2013
    jersey city nj
    Quote Originally Posted by bala1 View Post
    Most likely the vacuum pump was the problem all along
