Results 1 to 18 of 18
    Veteran Member Four Rings BlownOne's Avatar
    Dec 30 2015
    Sacramento, Ca
    Rs4 grill install ?
    So I'm putting it back together and I don't know if everyone is using the foam behind the grill or not. My foam is on but the passenger side is super tight and not wanting to go on. The grill is touching the foam. I could paint the aluminum bean black or maybe trim the foam...not sure.
    Any quick help would be appreciated...trying to watch the UFC fights lol.
    Will
    2011 CtsV Blk/Blk Loaded
    StageX 10.51@135mph E85
    2011 S4 Quartz/Blk Loaded
    034 Stg1 12.31@111mph 91octane +660Da
    034 Stg2 11.84@118mph 91/E85 +2200Da
    034 Stg3 11.55@119mph 91/E85 +1360Da
    Mar 21 2015
    Most go without the foam and paint or plasti dip the crash bar from what I've seen. Painted the bar on my buddy's S5.
    Veteran Member Three Rings StealthBlackA4's Avatar
    Aug 23 2012
    2012 Porsche Carrera 4S
    Erie, PA
    Don't use foam. Paint the crash bar. If you use the foam or leave the bar "raw", it won't look very good. Grab a can of plastidip and dip it.
    Dec 30 2015
    Sacramento, Ca
    Ok fellas thanks for the quick responses!!
    Veteran Member Four Rings pdqgp's Avatar
    Mar 06 2015
    a 12 Second boat, & Wife's Lincoln
    Columbus, Ohio
    No foam here. I need to remove mine in the spring and plan to hit it with bed liner from a rattle can. I hit it with cheap black paint initially because that's all I had at the time. starting to chip which is not surprising. Easy fix though.
    2018 Midnight Black Metallic AWD Infiniti Q50S Red Sport | Burger MS JB4 | 395awhp/430awtq
    2018 Ruby Red Metallic Lincoln MK-C Reserve | AWD 2.3l EcoBoost - Wife's
    2014 Brilliant Black S4 | S-Tronic | 187mm APR Stage 2 Dual Pulley & APR TCU Tunes | APR CPS - SOLD
    Dec 30 2015
    Sacramento, Ca
    Quote Originally Posted by pdqgp View Post
    Yea I figured black paint would chip so I used black plasti dip. That shits really durable even on exposed pieces so it should hold up fine. Thanks for the input brotha!
    Mar 21 2015
    Well wheres the pics?
    Dec 30 2015
    Sacramento, Ca
    When I ran out to get the dip, I got a pizza and ate the whole thing hahaha. Needless to say, I didn't put her back together last night, I fell asleep. I'm headed out to the garage in a bit so I'll post pics after.
    Veteran Member Four Rings fitzydude's Avatar
    Jul 05 2014
    Houston
    I'm in the middle of my grill install today too. Im planning on using the foam crash bar. I don't want to retouch chips in the painted bumper support. If it doesn't quite fit I'll end up taking some foam off. I'll report back on how I made it work!
    2010 S4 / 6MT / 034 RSWB & Motor Mounts / AMS Cooling / EC Alu Kreuz & inserts / B12 suspension / CTS SC & JHM OD Pulley (PR:3.139) / JHM STS & Stg 4 clutch / Magnaflow w/cutouts / CTS Downpipes / V710 / Eventuri-Euro / USP clutch line / E35 / Chipwerke 3-1 / Revo - 467 awhp
    Veteran Member Four Rings jl87's Avatar
    Jul 25 2010
    WI/IL
    No foam here either, I dippped the crash bar then got a sheet of black HDPE and cut it to fit so the contours on the crash bar are hidden.
    Mar 06 2015
    Columbus, Ohio
    Quote Originally Posted by jl87 View Post
    I like that. I thought I saw somewhere here on AZ where someone wrapped their crash bar with a rubber tubing too. All one piece and very clean like. Hmmmm.
    Aug 23 2015
    Texas
    Just installed mine today. Of course, when I went to remove the chrome rings, a few of the plastic tabs broke. Ordered a new front chrome emblem which should be here later in the week. Also couldn't figure out how to install the S4 badge. Thinking about getting one with 3M backing.
    Aug 23 2012
    Erie, PA
    Quote Originally Posted by omegis83 View Post
    I somehow superglued mine on...don't ask how, but it was some crazy ass glue I found. Solid as a rock on the grille!
    Aug 23 2015
    Texas
    Quote Originally Posted by StealthBlackA4 View Post
    That gave me a great idea. I wrapped electrical tape between two holes to make a backing, sanded down the back of the S4 emblem, and then super glued it to the tape. Can't see the tape and it's holding on great.
    Jul 05 2014
    Houston
    Well I tried to fit the foam and couldn't quite get it to work unmodified. Before I modified the foam to fit I wanted to trim my black filler piece and attach it to the grill.
    So.... I really like the filler plate and I dont need bother with the foam or painting the bar with it. I'll just leave it as is =)
    Dec 30 2015
    Sacramento, Ca
    So it was the foam holding the bumper off! Got it back together super easy without it in in the way. Got creative and zip tied the home link box (not in the tripod case) under the intake scoop. I also broke a few tabs on the rings when removing from the stock grill, but it still locked in place just fine. I think most people were peeling and reattaching the s4 emblem to the rs4 clip omegis.
    Dec 30 2015
    Sacramento, Ca
    Dec 30 2015
    Sacramento, Ca
