Originally Posted by
adamazing
Bump
Were you able to successfully replace the gasket using the ECS part above?
I never ended up ordering that piece because it seems like it doesnt fit our cars based on the fitment guide. But, there is no water getting to the headliner or shorting anything out even though a little water is getting under the antenna. I can push the antenna down and it squeezes some drops of water out from under.
I know for sure its not leaking to the headliner because it rained hard for a week straight last month here in San Diego. I had paper towels there the whole time and nothing got through. I checked every couple of hours everyday it rained.
I probably should replace it anyways but I havent figured out how to get the antenna back on after I take it off since its much harder to get the screw back in place in a tight spot like that.
