I have a 2003 a4 1.8t, since it has finally gotten cold out I realized I now have no heat. First thing I did was bleed the heater core and I got a little bit of air out but not much. Still no heat. Next I put the car on vag com and checked for codes. I got five of them;
01841 - Potentiometer/Actuator for temperature flap; left (g220)
30-00 - open to short to plus
01841 - Potentiometer/ Actuator for temperature flap; left (g220)
09-00 - Adaptation limit surpassed
00604 - Potentiometer Positioning Motor for air flow flap; (g113)
30-00 - open or short to plus
01842 - Potentiometer/ Actuator for temperature flap; right (g221)
30-10 - open or short to plus
00819 - high pressure sensor (g65)
07-10 - signal too low - intermittent
I also have noticed that after I shut the car off and have the key out of the ignition that you can hear one of the motors opening and closing repeatedly for about 5 minutes. am I able to recode this stuff and get it to work or is there more to it?
