Results 1 to 8 of 8
    Jul 13 2014
    1997BMWZ3
    Daly City,CA United States
    Idling problem after downpipe gutted?
    Does anyone have an idling problem after gutting your downpipes? It doesn't happen all the time but the rpm drops around 100 rpm and the car shakes abit then goes back to normal. Went to a mechanic to check if there was an exhaust leak and there wasn't.
    May 16 2008
    WA
    The O2 sensors can get damaged during removal or install, especially if they are old. Also check your intake connections for anything you moved to gain access for removal of the pipes. unmetered air getting in would definitely cause idle issues.
    Tossing any codes? The CEL does not need to be on for codes to be present.
    Jul 13 2014
    1997BMWZ3
    Quote Originally Posted by getslideways View Post
    Thanks I will check on my 02 sensors. Yes I had some codes on thrust hold on both banks. I cleared it and it didn't come back.I cut out my bank 2 sensor 2 02 wires and remember one of the wires i tried to reconnect back only had half the copper stripes left on it. I didn't bother cutting it again because I thought it was fine, not knowing about electrical things. Could that cause the problem? I also replaced bank 1 sensor 2 02 sensor and still had idle problem
    Veteran Member Three Rings jakeoboy67's Avatar
    Oct 21 2013
    mk2 Jetta Tdi
    NB , Canada
    Quote Originally Posted by kevinye77137 View Post
    there's your problem
    May 24 2013
    Charlotte, NC
    Did you disconnect the battery?
    Sensor two behind the cats monitors Cat efficiency and not Air/Fuel.
    Try cleaning your throttle body and resetting the adaptation with a VAG com or if you can't find that the dealer shouldn't charge to much to run the adaptation.
    Jul 13 2014
    1997BMWZ3
    Quote Originally Posted by MyB7S4BlowedUp View Post
    so the 02 sensor 2 on the main cats does not manage air fuel ratio? I disconnected the battery when I did my pre cats. I will try resetting the throttle body tomorrow
    Jul 13 2014
    1997BMWZ3
    Problem solved... I added 02 spacers on the pre-cats 02 sensor which Im not supose to... Dam I feel dumb...
    May 16 2008
    WA
    /\ LOL
    At least you got it sorted. We all have those moments from time to time. Hopefully by you not being shy regarding posting the solution, you will have prevented someone else from doing the same later.
