Results 1 to 15 of 15
    Aug 09 2012
    2013 S4 phantom pearl
    IL
    will the older 2.8 B5 A4 16" alloy rim clear the caliper on the B5 S4? need a cheap
    set of winters and came across one from the above car
    Veteran Member Four Rings CELison's Avatar
    Feb 23 2010
    Emmaus Pa
    Nah fam. That being said, I have a full set with tires if you're interested.
    B5 S4- K24s, built bottom end, E85 - Gone
    B9 S4- EPL/AWE
    996TT X50 - Marski 700hp
    Aug 09 2012
    IL
    Quote Originally Posted by CELison View Post
    well,, of different wheels? or the same 16"/ers. if it's the latter, LOL thanks for the offer.. they're an offset of 45. I thought the S4 was 43.. that little bit doesn't clear huh?
    Feb 23 2010
    Emmaus Pa
    Nope. They won't clear.
    B9 S4- EPL/AWE
    Aug 09 2012
    IL
    damn
    Nov 23 2004
    B5 S4 Built Motor GTX28's
    NH
    There is a set of 16" A4 wheels that clear hp2. Just not sure which set
    Feb 23 2010
    Emmaus Pa
    I didn't think any cleared. Well I have a perfectly good set with tires off my old 96 2.8 if those happen to be the ticket
    B9 S4- EPL/AWE
    Aug 09 2012
    IL
    here's the part number: 8D0601025C. if that helps. can't find anyone who has tried them or knows
    Feb 23 2010
    Emmaus Pa
    Pretty sure that's what I have. Pm me if you're interested. I'll let them go for cheap
    B9 S4- EPL/AWE
    Veteran Member Three Rings Heavy Winter's Avatar
    Jan 27 2013
    Boulder, CO
    Here's some info on 16 inchers for the B5 S4. I've personally run some Mille Milgalia 16" Spyders as a winter set and they worked fine.
    http://audisrs.com/archive/16-inch-e...__t_22077.html
    If you are willing to run spacers then you will *probably* have more options. But since my experience is limited others will have to chime in.
    Good luck!
    Aug 09 2012
    IL
    you're in PA?
    - - - Updated - - -
    Quote Originally Posted by Heavy Winter View Post
    Good luck!
    awesome thanks for the link.. I'll run through it
    Feb 23 2010
    Emmaus Pa
    Yeah, east pa. Hour north of philly.
    B9 S4- EPL/AWE
    Aug 09 2012
    IL
    I'm in the Chicago area. I'd take you up on them, but it would probably cost as much to ship as the ones I can buy here
    Feb 23 2010
    Emmaus Pa
    Yeah I don't blame you.
    B9 S4- EPL/AWE
    Jul 20 2011
    Providence - RI
    I think you need et35 to clear the front calipers. Even then it depends on the wheel design.
    I am not certain on that et number though
